This type of script generating a huge amount of operations is not
going to work with the release version. It's really just causing
lots of calculations that are slow in the geometry engine.
It does render in less than a minute for me using the dev snapshot
with the "fast-csg" experimental features enabled.
Don't do CSG. OpenSCAD tempts you to do it, but don't. Instead, do this in
2D, linear_extrude it, and attach the appropriate-sized square to the
bottom.
r_min = 164;
r_max = 179;
rminsq = r_min * r_min;
rmaxsq = r_max * r_max;
s60 = sin(60); // If OpenSCAD caches function calls, this won't help
c60 = cos(60); // Ditto
linear_extrude(0.4) {
// translate([0,0,-5])
square([400,400], center = true);
for(i=[-500:1.6:500], j=[-500:1.6:500])
if(rminsq < (js6)^2 + (i+jc60)^2 && (js60)^2 + (i+jc60)^2 <
rmaxsq)
translate([js6,i+jc60])
resize(1.2, 1.6) circle($fn = 6, r = 1);
You've got a lot of rotational symmetry to use too, although that 60 degree
angle makes it harder. If you can get this down to quadrants or (even
better) octants, you can speed it up that way too.
Hey now no dissing the hextents... hexagons are the bestagons!
bottom.
r_min = 164;
r_max = 179;
rmaxsq)
degree angle makes it harder. If you can get this down to quadrants or
(even better) octants, you can speed it up that way too.
Oddly, circle() doesn't allow for differing radiuses. It makes life a
little trickier.
in 2D, linear_extrude it, and attach the appropriate-sized square to the
bottom.
r_min = 164;
r_max = 179;
rmaxsq)
Thank you very much, Torsten, Father Horton and Joe for your clarifications!
Your ideas solved the problem; i was able to reduce the computational load enough.
I failed in compiling OpenSCAD from source, but that is another problem. I don't know if i am ready to tackle that…
Just for the case, that it was something obvious; i had to compile and install cmake (3.20.0), CGAL-5.4.1 and gmp-6.2.1 … When i use check-dependencies.sh it shows evrything as OK but gives warnings:
Warning: you have a copy of CGAL under /usr/local/include
Warning: you have a copy of gmp.h under /usr/local/include
Warning: you have pkgconfig under /usr/local/lib
But when i try to "make" OpenSCAD, a fatal error occurs a 8%:
In file included from /usr/local/include/CGAL/Surface_mesh/Surface_mesh.h:24:0,
from /usr/local/include/CGAL/Surface_mesh.h:18,
from /home/bloemle/Downloads/openscad/src/geometry/cgal/cgal.h:24,
from /home/bloemle/Downloads/openscad/src/geometry/cgal/CGAL_Nef_polyhedron.h:3,
from /home/bloemle/Downloads/openscad/src/openscad.cc:60:
/usr/local/include/CGAL/boost/graph/copy_face_graph.h:28:10: fatal error: boost/iterator/function_output_iterator.hpp: Datei oder Verzeichnis nicht gefunden
#include <boost/iterator/function_output_iterator.hpp>
compilation terminated.
Is there something obvious, that i missed?
Thank you
Orkus
Am Mittwoch, 29. Juni 2022 um 00:35:58 MESZ hat Father Horton <fatherhorton@gmail.com> Folgendes geschrieben:
Oddly, circle() doesn't allow for differing radiuses. It makes life a little trickier.
Don't do CSG. OpenSCAD tempts you to do it, but don't. Instead, do this in 2D, linear_extrude it, and attach the appropriate-sized square to the bottom.
r_min = 164;
r_max = 179;
if(rminsq < (js6)^2 + (i+jc60)^2 && (js60)^2 + (i+jc60)^2 < rmaxsq)
You've got a lot of rotational symmetry to use too, although that 60 degree angle makes it harder. If you can get this down to quadrants or (even better) octants, you can speed it up that way too._______________________________________________
