Is there a way to do this in openSCAD?
Let's say a point matrix (array) is created
boundArray = [ for( i = pathArray ) pointlist_bounds( i ) ];
Is there a way to save the boundArray variable to a text file and then read
it back in?
Something maybe like:
saveValue( boundArray, <filename> );
boundArray = getValue( <filename> );
No.
and then read it back in?
Yes, in the nightly builds you can read structures from JSON files.
Otherwise you can create OpenSCAD formatted files to include<>.
If you just want to see the data and then manipulate it manually then use echo(boundArray); to put the values out to the console.
The console content can be manually saved to a text file in the GUI version or redirected to a file if you use a command line - edit the output and then use one of Paul’s methods was saying to get it back in.
Is there a way to save the boundArray variable to a text file and then read it back in?
Your steps are pretty much what I've been doing.
Saves a ton of time when developing many path and vnf data matrices from
svg files to create objects. I generate the arrays and then save them to
files. Instead of recreating them each time when developing the object, I
simply load them from the file include <filename>. This saves a ton of
development time.
read it back in?
