WARNING: Ignoring unknown function 'select'
VB
Verachten Bruno
Thu, Dec 31, 2020 2:52 PM
Hi there,
I'm trying to create sub vectors, and am having an issue.
WARNING: Ignoring unknown function 'select' in file boards adapter
utils.scad, line 21
The line 21 is            selectVector = select(points, selector);
First, I tried to use directly a range, but it failed (undef).
Now, I convert the range into a vector so that I get:
ECHO:[[17.445, 2.695, 0], [59.555, 2.695, 0], [17.445, 42.805, 0],
[59.555, 42.805, 0], [0, 0, 0], [77, 0, 0], [14, 45.5, 0], [63, 45.5,
0]]
ECHO:[1, 2, 3, 4, 5, 6, 7]
ECHO:"Select Vector", undef
ECHO:"Point 0 ", []
function range2vector(r) = [ for (i=r) i];
module getNearestPoints(points) {
for (idx = [0 : len(points) - 1]) {
if (idx == 0) {
echo(points);
selector = range2vector([1:len(points)-1]);
echo(selector);
21            selectVector = select(points, selector);
echo("Select Vector", selectVector);
echo("Point 0 ", getAllDistances(points[0], selectVector));
} else if (idx == len(points)-1) {
selectVector = select(points, [0:len(points)-2]);
echo("Last point ", getAllDistances(points[idx], selectVector));
} else {
concat([0:idx-1],[idx+1:len(points)-1]));
echo("Point #", idx, getAllDistances(points[idx], selectVector));
getDistance(points[idx], points[idx + 1]);
Could it be linked to previous warnings happening earlier in the file?
Thanks.
Bruno Verachten
Hi there, I'm trying to create sub vectors, and am having an issue. WARNING: Ignoring unknown function 'select' in file boards adapter utils.scad, line 21 The line 21 is selectVector = select(points, selector); First, I tried to use directly a range, but it failed (undef). Now, I convert the range into a vector so that I get: ECHO:[[17.445, 2.695, 0], [59.555, 2.695, 0], [17.445, 42.805, 0], [59.555, 42.805, 0], [0, 0, 0], [77, 0, 0], [14, 45.5, 0], [63, 45.5, 0]] ECHO:[1, 2, 3, 4, 5, 6, 7] ECHO:"Select Vector", undef ECHO:"Point 0 ", [] function range2vector(r) = [ for (i=r) i]; module getNearestPoints(points) { for (idx = [0 : len(points) - 1]) { if (idx == 0) { echo(points); selector = range2vector([1:len(points)-1]); echo(selector); 21 selectVector = select(points, selector); echo("Select Vector", selectVector); echo("Point 0 ", getAllDistances(points[0], selectVector)); } else if (idx == len(points)-1) { selectVector = select(points, [0:len(points)-2]); echo("Last point ", getAllDistances(points[idx], selectVector)); } else { selectVector = select(points, concat([0:idx-1],[idx+1:len(points)-1])); echo("Point #", idx, getAllDistances(points[idx], selectVector)); } getDistance(points[idx], points[idx + 1]); } } Could it be linked to previous warnings happening earlier in the file? Thanks. -- Bruno Verachten
G
gounthar
Thu, Dec 31, 2020 2:59 PM
My bad, I wronly read the documentation...
You have to define yourself the select function.
function select(vector, indices) = [ for (index = indices) vector[index] ];
My bad, I wronly read the documentation... You have to define yourself the select function. function select(vector, indices) = [ for (index = indices) vector[index] ]; -- Sent from: http://forum.openscad.org/
