On Tuesday 07 September 2021 02:19:34 MichaelAtOz wrote:
A picture is worth a thousand words.
Sounds like you want outside thickness.
No, inside TBE.
Similar to this triangular example (lower corrected one) from:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Primitive_Solids#Mi
s-ordered_faces
But neither triangular example shown there claims to be correct.
That I had whupped until I removed the top and bottom faces I don't need,
which should allow me to do and see more construction inside, using rest
of line // comments. Then the innards turned burple/magenta, but looked
out of order because I was effectively looking at the back side when I
was seeing the inside walls. That of course converts the direction from
cw to ccw.
So I next defined an inner polyhedron to be 1.5 mm smaller in xy and
declared a union of the bigger one and the smaller one inside it. but I
didn't get the expected solid walls, but a smaller box within the first
one. Then I tried to re-define that smaller box by adding or subtracting
two vars to make up the x,y parts. Is there a syntax that does allow a
point x,y,z to be stated as (ignore the parens)
[-var1+var2 (x position), var3-var4(y position), var5(z position)],
Or must I predefine each one with an assign starement that does allow the
math, putting only the resultant var in the x,y,z positions?
polyhedron
(points = [
[0, -10, 60], [0, 10, 60], [0, 10, 0], [0, -10, 0], [60,
-10, 60], [60, 10, 60],
[10, -10, 50], [10, 10, 50], [10, 10, 30], [10, -10, 30],
[30, -10, 50], [30, 10, 50]
faces = [
[0,3,2], [0,2,1], [4,0,5], [5,0,1], [5,2,4],
[4,2,3],
[6,8,9], [6,7,8], [6,10,11],[6,11,7], [10,8,11],
[10,9,8], [3,0,9], [9,0,6], [10,6, 0],[0,4,10],
[3,9,10], [3,10,4], [1,7,11], [1,11,5], [1,8,7],
[2,8,1], [8,2,11], [5,11,2]
Thank you MichaelAtOz.
-Ed Howdershelt (Author)
On Tuesday 07 September 2021 03:54:58 Ronaldo Persiano wrote:
It is not clear to me why you need a polyhedron with missing faces but
to get it just drop the faces you don't want from the list of faces of
the polyhedron.
However, it should be clear that the incomplete
polyhedron, which doesn't enclose a volume, will not be rendered (F6)
and so no STL is possible to be produced although OpenSCAD is able to
produce the expected image in a preview (F5).
So in other words, I must define each wall as a separate polyhedron.
Nominaly 1.35mm thick to duplicate the steel part, within which I build
the piece I want to print and insert into the steel part. That way,
each wall will be a sealed, selfcontained polyhedron, 4 of them to get
the box I desire. front, back, and both sides.
What I had intended to do was to make one bounding box to define the
working limits and shape of a box whose top and bottom are open, and
when I had the part itself built, which I should be able to do with 3
complete, closed polyhedrons, fitting exactly inside this bounding box,
and for the final render, comment out this outlining box, leaving the
part I need. Or, if because its open and won't render just leave it be,
since the openness will remove it from the .stl anyway.
But I've a disaster brewing, my coffee cup is empty and so is the pot,
first things first.
First question is, how much space do I need between the bounding box, and
the outer walls of what I'm making, to be assured that removal of the
bounding box will not affect what I build inside of it? Enough space to
prevent a merging IOW.
Thank you Ronaldo.
Note also that a cube without the top face unioned with a similar cube
positioned on top of it but without its bottom face will not be
assembled as a valid object. Each polyhedron in a boolean operation
(union, intersection or difference) should be valid by itself, that
is, enclose a volume.
Got it. Finally... I hope.
For each polyhedron you define, check it with View/Thrown Together.
Faces with inconsistent windings will be shown with different colors.
On 9/7/2021 7:09 AM, Gene Heskett wrote:
Is there a syntax that does allow a point x,y,z to be stated as
(ignore the parens)
You're overthinking it. It's just an array; the elements can be any
expression.
[ -var1+var2, var3-var4, var5 ]
Others have said, but maybe not as simply and with examples: you want
to define a polyhedron A that's the outside of the box, and another
polyhedron B that's the inside of the box (and out through the top and
bottom), and subtract B from A.
If you wanted to do this with cubes, you'd do something like:
cube([10,10,10]);
translate([1,1,-1]) cube([8,8,12]);
The concept is the same with polyhedra; they're just individually harder
to define:
// Outer polyhedron
polyhedron(points=[
// bottom points
[ 0,0,0 ],
[ 10,0,0 ],
[ 10,10,0 ],
[ 0,10,0 ],
// top points
[ 0,0,10 ],
[ 10,0,10 ],
[ 10,10,10 ],
[ 0,10,10 ],
], faces=[
[0,1,2,3], // bottom
[0,4,5,1], // front
[1,5,6,2], // right
[2,6,7,3], // back
[3,7,4,0], // left
[4,7,6,5], // top
// Inner polyhedron
polyhedron(points=[
// bottom points
[ 1,1,-1 ],
[ 9,1,-1 ],
[ 9,9,-1 ],
[ 1,9,-1 ],
// top points
[ 1,1,11 ],
[ 9,1,11 ],
[ 9,9,11 ],
[ 1,9,11 ],
], faces=[
[0,4,5,1], // front
[1,5,6,2], // right
[2,6,7,3], // back
[3,7,4,0], // left
[4,7,6,5], // top
You could, if you really wanted to, directly define the polyhedron that
is the box, complete with both the outside faces, the inside faces, the
top faces, and the bottom faces, but that's a little more intricate:
polyhedron(points=[
// bottom outer points
[ 0,0,0 ],
[ 10,0,0 ],
[ 10,10,0 ],
[ 0,10,0 ],
// top outer points
[ 0,0,10 ],
[ 10,0,10 ],
[ 10,10,10 ],
[ 0,10,10 ],
// bottom inner points
[ 1,1,0 ],
[ 9,1,0 ],
[ 9,9,0 ],
[ 1,9,0 ],
// top inner points
[ 1,1,10 ],
[ 9,1,10 ],
[ 9,9,10 ],
[ 1,9,10 ],
], faces=[
// Outer faces
[0,4,5,1],
[1,5,6,2],
[2,6,7,3],
[3,7,4,0],
// Inner faces
[8,9,13,12],
[9,10,14,13],
[10,11,15,14],
[11,8,12,15],
// top faces
[ 4,12,13,5 ],
[ 5,13,14,6 ],
[ 6,14,15,7 ],
[ 7,15,12,4 ],
// bottom faces
[ 0,1,9,8 ],
[ 1,2,10,9 ],
[ 2,3,11,10 ],
[ 3,0,8,11 ],
I don't build polyhedra very often, because they can be very complex to
build, but when I do I find them strangely satisfying, placing each
point exactly where I want it and connecting them exactly as I want them
connected. And they're really really fast.
(ignore the parens)
expression.
cube([10,10,10]);
harder to define:
// Outer polyhedron
polyhedron(points=[
// bottom points
[ 0,0,0 ],
[ 10,0,0 ],
[ 10,10,0 ],
[ 0,10,0 ],
// top points
[ 0,0,10 ],
[ 10,0,10 ],
[ 10,10,10 ],
[ 0,10,10 ],
], faces=[
[0,4,5,1], // front
[1,5,6,2], // right
[2,6,7,3], // back
[3,7,4,0], // left
[4,7,6,5], // top
// Inner polyhedron
polyhedron(points=[
// bottom points
[ 1,1,-1 ],
[ 9,1,-1 ],
[ 9,9,-1 ],
[ 1,9,-1 ],
// top points
[ 1,1,11 ],
[ 9,1,11 ],
[ 9,9,11 ],
[ 1,9,11 ],
], faces=[
[0,4,5,1], // front
[1,5,6,2], // right
[2,6,7,3], // back
[3,7,4,0], // left
[4,7,6,5], // top
that is the box, complete with both the outside faces, the inside
faces, the top faces, and the bottom faces, but that's a little more
intricate:
polyhedron(points=[
[ 0,0,0 ],
[ 10,0,0 ],
[ 10,10,0 ],
[ 0,10,0 ],
// top outer points
[ 0,0,10 ],
[ 10,0,10 ],
[ 10,10,10 ],
[ 0,10,10 ],
[ 1,1,0 ],
[ 9,1,0 ],
[ 9,9,0 ],
[ 1,9,0 ],
// top inner points
[ 1,1,10 ],
[ 9,1,10 ],
[ 9,9,10 ],
[ 1,9,10 ],
], faces=[
// Outer faces
[0,4,5,1],
[1,5,6,2],
[2,6,7,3],
[3,7,4,0],
// Inner faces
[8,9,13,12],
[9,10,14,13],
[10,11,15,14],
[11,8,12,15],
// top faces
[ 4,12,13,5 ],
[ 5,13,14,6 ],
[ 6,14,15,7 ],
[ 7,15,12,4 ],
// bottom faces
[ 0,1,9,8 ],
[ 1,2,10,9 ],
[ 2,3,11,10 ],
[ 3,0,8,11 ],
to build, but when I do I find them strangely satisfying, placing each
them connected. And they're really really fast.
So I've already noted.
But I changed my strategy since each piece has to be a closed piece or it
won't render. And I started with the empty space in front, filling it
up with a 3d block, but I can't get the back face list order correct
even playing the 10,000 monkeys with those 4 face points. If I get that
block working, then I make 2 wings that project to the rear, as mirrors
of each other, with a union() tying the common or overlapping edges
together into one printable piece. And of course there's a width (+-y)
taper error that is exagerating the width taper a noticeable bit, so
that has to be run down and fixed. I just fixed a similar z problem so I
will eventually find the magic twanger and print a test sample. And I
need more sleep than I got last night, which is not helping.
Thanks Jordan. Take care and stay well.
Polyhedron definitions were very frustrating until I found this web page:
https://gusmith.wordpress.com/2015/09/18/simple-tool-for-creating-polyhedrons-in-openscad/
I have been able to build some quite useful polyhedra since using this
tool/approach. It is slow work, but steady. The logic of building the
shape is better understood by going in small, verifiable steps at a
time, and hence debugging unintended results becomes much easier as
well. The overall designs for me were much quicker to create and errors
weren't buried in a soup of triangles.
Rob
On 7/9/21 10:07 pm, nop head wrote:
You can't take a face of the polyhedron to get an open box. It is not
a manifold solid because the walls would infinitely thin. If it is an
irregular shape that can't be linear_extruded then make two solid
polyhedra, one for the outside and one for the inside and subtract them.
You don't need variables for each point in the polyhedra, they can be
any expression.
On Tue, 7 Sept 2021 at 12:35, Ray West <raywest@raywest.com
mailto:raywest@raywest.com> wrote:
On 07/09/2021 08:54, Ronaldo Persiano wrote:
So how do I reorder
to leave out the top and bottom, all I want are the sides which will
then be built up on the inside to do the job, effectively
winding up on
the printer as a half box with a big difference removing about
half the
box.
I'm still not sure what it looks like to you, but to me, from the
above
description, it would be two polygons (not polyhedron) , one
inside the
other, extruded, and top and bottom chopped off however you want by
differences. That will give a solid, and you can add
features/whatever,
as you wish.
I know this is offtopic but close to the problem "I don't get polyhedron to
work".
I am too lazy for the Polyhedron chaos. If you do too, and have a lot of
points with something simple like a cube I suggest using hull() with small
spheres. It is, compared to the polyhedron, VERY simple. For example I take
the points in Robs link:
p = [
[-5,-5,0]
, [15,-5,0]
, [-5,15,0]
, [15,15,0]
, [0,0,10]
, [0,10,10]
, [10, 0,10]
, [10,10,10]
, [5,5,15]
// sphere diameter. To get the correct dimension it should be 0 but you
need something >0
d = 0.0001;
// this takes all points (in any order) and makes a 3D object:
hull() {
for (i=[0 : 1 : len(p)-1]) {
translate(p[i]) sphere(d);
This is not correct because it is always oversized. But in case of 3D-Print
or something similar +0.0001 doesn't matter and you don't need to build a
3D object first to understand the points and geometry to be able to
construct the virtual 3D object to get the right polyhedron. :)
Am Mi., 8. Sept. 2021 um 07:14 Uhr schrieb Rob Ward rl.ward@bigpond.com:
tool/approach. It is slow work, but steady. The logic of building the shape
is better understood by going in small, verifiable steps at a time, and
hence debugging unintended results becomes much easier as well. The overall
designs for me were much quicker to create and errors weren't buried in a
soup of triangles.
Rob
You can't take a face of the polyhedron to get an open box. It is not a
You don't need variables for each point in the polyhedra, they can be any
expression.
So how do I reorder
then be built up on the inside to do the job, effectively winding up on
the printer as a half box with a big difference removing about half the
box.
I'm still not sure what it looks like to you, but to me, from the above
description, it would be two polygons (not polyhedron) , one inside the
differences. That will give a solid, and you can add features/whatever,
as you wish.
The downside is that hulls are slow.
polyhedron to work".
p = [
[-5,-5,0]
, [15,-5,0]
, [-5,15,0]
, [15,15,0]
, [0,0,10]
, [0,10,10]
, [10, 0,10]
, [10,10,10]
, [5,5,15]
need something >0
d = 0.0001;
hull() {
3D-Print or something similar +0.0001 doesn't matter and you don't need to
build a 3D object first to understand the points and geometry to be able to
soup of triangles.
Rob
expression.
So how do I reorder
box.
as you wish.
They are only slow if the objects inside need to be unioned. It is the CGAL
union that is slow. Turning on lazy union might speed it up.
If you translate all the spheres individually then the unionin is avoided
and it is fast. E.g.
translate(p[0]) sphere(d);
translate(p[1]) sphere(d);
translate(p[8]) sphere(d);
But that is tedious if it is a list.
p = [
[-5,-5,0]
, [15,-5,0]
, [-5,15,0]
, [15,15,0]
, [0,0,10]
, [0,10,10]
, [10, 0,10]
, [10,10,10]
, [5,5,15]
need something >0
d = 0.0001;
hull() {
Am Mi., 8. Sept. 2021 um 07:14 Uhr schrieb Rob Ward <rl.ward@bigpond.com
soup of triangles.
Rob
any expression.
So how do I reorder
on
box.
features/whatever,
as you wish.
Right, because now you no longer have a valid solid. You just have four
faces with zero thickness.
Yep. That's the next step.
one.
Union() combines two objects, so what you got /is/ the expected result.
You want the difference() of the two objects instead.
page:
Thank you very much for the above link, Rob, that showed me how to fix
the faces order rather precisely in about 15 minutes including typing it
in. A very useful tool indeed. Now I can concentrate on fine tuning the
points to get the tapers under control and get this show on the road.
errors weren't buried in a soup of triangles.
Rob
not a manifold solid because the walls would infinitely thin. If it
is an irregular shape that can't be linear_extruded then make two
solid polyhedra, one for the outside and one for the inside and
subtract them.
For this 3d print job, once the vars are properly defined, a union of 3
polyhedra will do it as the last 2 should be y, -y mirrors of each
other.
be any expression.
Yes, I have since found the syntax that works, but its better to
predefine it, calculating it once, than to calculate it for every point
in an list array.
Reusable pre-defined vars are the way to accurate work IMO. You omly have
to do it right once.
You make mirrors by putting a - sign in front of the varname.
So how do I reorder
which will then be built up on the inside to do the job,
effectively
winding up on
half the
box.
That idea is in the dustbin. Just unioning the 3 polyhedra should be able
to do it. As a math challenged old fart, I may have to ask a trig
question before I'm done. But right now I can go back to bed for the
rest of the night with a BWG on my face. Thank you.
