Expected behavior when referencing undefined field of object?
Jeff Barr
Tue, Nov 25, 2025 10:01 PM
Quick question about the (relatively) new and experimental object feature -- what is the expected behavior when referencing an undefined field?
Right now the final pair of echos print "undef":
x = object([["abc", 123]]);
// These all work as expected
echo(x.abc);
echo(x["abc"]);
// Should these fail?
echo(x.def);
echo(x["def"]);
While I can catch this in my code, I was surprised to find that the references did not raise an error. I did RTFM and the discussion and could not find this documented or debated either way.
Thanks,
Jeff;
Quick question about the (relatively) new and experimental object feature -- what is the expected behavior when referencing an undefined field? Right now the final pair of echos print "undef": x = object([["abc", 123]]); // These all work as expected echo(x.abc); echo(x["abc"]); // Should these fail? echo(x.def); echo(x["def"]); While I can catch this in my code, I was surprised to find that the references did not raise an error. I did RTFM and the discussion and could not find this documented or debated either way. Thanks, Jeff;
Wed, Nov 26, 2025 12:14 AM
field?
Yields undef.
Oops.  I've added a sentence to the section on retrieving values from
objects.
I stole the semantics from JavaScript, where an undefined member
yields undefined, rather than Python where it yields a KeyError error.
Partly that's because I've written enormously more JS than Python and so
that's the semantic I'm more familiar with.  In JS, that yields simple
idioms like (obj.mem || "default") to get a default value, rather than
needing the more complex ('mem' in obj ? obj.mem : "default").  However,
since OpenSCAD doesn't have JS semantics for ||, you're still stuck
with (obj.mem ? obj.mem : "default").
(And yes, because of falsiness semantics JS's || is an imperfect way to
get defaults... but it's good most of the time.)
Anyhow, I'm not morally opposed to the Python semantic; if people
overwhelmingly prefer it, I'm OK with switching.
On 11/25/2025 2:01 PM, Jeff Barr via Discuss wrote: > Quick question about the (relatively) new and experimental object > feature -- what is the expected behavior when referencing an undefined > field? Yields undef. > While I can catch this in my code, I was surprised to find that the > references did not raise an error. I did RTFM and the discussion and > could not find this documented or debated either way. Oops.  I've added a sentence to the section on retrieving values from objects. I stole the semantics from JavaScript, where an undefined member yields undefined, rather than Python where it yields a KeyError error.  Partly that's because I've written enormously more JS than Python and so that's the semantic I'm more familiar with.  In JS, that yields simple idioms like (obj.mem || "default") to get a default value, rather than needing the more complex ('mem' in obj ? obj.mem : "default").  However, since OpenSCAD doesn't have JS semantics for ||, you're still stuck with (obj.mem ? obj.mem : "default"). (And yes, because of falsiness semantics JS's || is an imperfect way to get defaults... but it's good most of the time.) Anyhow, I'm not morally opposed to the Python semantic; if people overwhelmingly prefer it, I'm OK with switching.
Wed, Nov 26, 2025 12:37 AM
In Openscad, foo[x] gives undef when x is out of bounds.  It seems like
this means that obj["notvalid"] needs to also produce undef for language
consistency.
On Tue, Nov 25, 2025 at 7:14 PM Jordan Brown via Discuss <
Yields undef.
objects.
In Openscad, foo[x] gives undef when x is out of bounds. It seems like this means that obj["notvalid"] needs to also produce undef for language consistency. On Tue, Nov 25, 2025 at 7:14 PM Jordan Brown via Discuss < discuss@lists.openscad.org> wrote: > On 11/25/2025 2:01 PM, Jeff Barr via Discuss wrote: > > Quick question about the (relatively) new and experimental object feature > -- what is the expected behavior when referencing an undefined field? > > > Yields undef. > > While I can catch this in my code, I was surprised to find that the > references did not raise an error. I did RTFM and the discussion and could > not find this documented or debated either way. > > > Oops. I've added a sentence to the section on retrieving values from > objects. > > I stole the semantics from JavaScript, where an undefined member yields > undefined, rather than Python where it yields a KeyError error. Partly > that's because I've written enormously more JS than Python and so that's > the semantic I'm more familiar with. In JS, that yields simple idioms like (obj.mem > || "default") to get a default value, rather than needing the more > complex ('mem' in obj ? obj.mem : "default"). However, since OpenSCAD > doesn't have JS semantics for ||, you're still stuck with (obj.mem ? > obj.mem : "default"). > > (And yes, because of falsiness semantics JS's || is an imperfect way to > get defaults... but it's good most of the time.) > > Anyhow, I'm not morally opposed to the Python semantic; if people > overwhelmingly prefer it, I'm OK with switching. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Wed, Nov 26, 2025 12:43 AM
I concur.
-Revar
On Nov 25, 2025, at 4:37 PM, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote:
On Tue, Nov 25, 2025 at 7:14 PM Jordan Brown via Discuss <discuss@lists.openscad.org> wrote:
Yields undef.
Wed, Nov 26, 2025 1:05 AM
Huh.  So it does.  I remembered it giving an out-of-bounds warning and
then undef.  I don't know where I got that.  (Maybe it did for a while?)
And yes, that fact does push for an undefined object member yielding undef.
On 11/25/2025 4:37 PM, Adrian Mariano via Discuss wrote: > In Openscad, foo[x] gives undef when x is out of bounds.  It seems > like this means that obj["notvalid"] needs to also produce undef for > language consistency.   Huh.  So it does.  I remembered it giving an out-of-bounds warning and *then* undef.  I don't know where I got that.  (Maybe it did for a while?) And yes, that fact does push for an undefined object member yielding undef.
