Could someone give me an example of passing multiple arguments to -D in
command line?
Passing this works:
-D value_type=100
But this:
-D "value_type=100,value_two_type=2"
Or
-D value_type=100 value_two_type=2
And similar variations, cause an error.
What is the proper syntax?
Thanks,
Boris
View this message in context: http://forum.openscad.org/Multiple-arguments-to-D-in-command-line-tp13472.html
Think of the ‘-D’ option as appending code to the end of the file, not passing a variable value in:
openscad -D “value1=1;value2=\”a string\”” myCode.scad
Try this:
openscad -D “cube();” dummy.scad -o cube.stl
…where “dummy.scad” only contains a comment.
Very handy for dynamically generating content.
Andrew.
command line?
Passing this works:
-D value_type=100
But this:
Or
Thanks,
Boris
Ah thank you for clarifying! This is infinitely more useful than I originally
thought!
View this message in context: http://forum.openscad.org/Multiple-arguments-to-D-in-command-line-tp13472p13474.html
I just tried it,
it works with:
openscad -D v1=100 -D v2=50 -D v3=10 somefile.scad
Jerry
Extra Ham Operator: K7AZJ
Registered Linux User: 275424
I
Anonymous
excellent code requires no comments at all!- Ken Thompson
originally
thought!
