Fwd: OpenSCAD Customizer
SS
Shaina Sabarwal
Fri, Mar 20, 2015 7:56 AM
Hey,
I am Shaina Sabarwal, one who worked on OpenSCAD GUI last year in
GSoC. This year I was thinking to work on Customizer feature
(currently implemented in meta-data-2) branch. For planning purposes I
need some use cases and examples on where can this feature be used and
as an openscad user what improvement or enhancement would you like to
see ?
You can have a gist of current implementation from following videos
http://files.openscad.org/video/screencast-parameter-window.webm
http://files.openscad.org/video/screencast-library-window.webm
Thanks.
Shaina Sabarwal
blog: shainasabarwal.wordpress.com
github: github.com/shaina7837
You don't have to be great to start but start to be great.
Hey, I am Shaina Sabarwal, one who worked on OpenSCAD GUI last year in GSoC. This year I was thinking to work on Customizer feature (currently implemented in meta-data-2) branch. For planning purposes I need some use cases and examples on where can this feature be used and as an openscad user what improvement or enhancement would you like to see ? You can have a gist of current implementation from following videos http://files.openscad.org/video/screencast-parameter-window.webm http://files.openscad.org/video/screencast-library-window.webm Thanks. -- Shaina Sabarwal blog: shainasabarwal.wordpress.com github: github.com/shaina7837 You don't have to be great to start but start to be great.
MH
Miro Hrončok
Fri, Mar 20, 2015 11:46 AM
the drag and drop thing seems very non-intuitive to me. Also it's
weird that you have to drag and drop it over the 3D canvas area. I
would prefer Paste button.
Miro Hrončok
Telefon: +420777974800
2015-03-20 8:56 GMT+01:00 Shaina Sabarwal iamshainasabarwal@gmail.com:
Hey,
see ?
Thanks.
Shaina Sabarwal
Hi, the drag and drop thing seems very non-intuitive to me. Also it's weird that you have to drag and drop it over the 3D canvas area. I would prefer *Paste* button. Miro Hrončok Telefon: +420777974800 2015-03-20 8:56 GMT+01:00 Shaina Sabarwal <iamshainasabarwal@gmail.com>: > Hey, > > I am Shaina Sabarwal, one who worked on OpenSCAD GUI last year in > GSoC. This year I was thinking to work on Customizer feature > (currently implemented in meta-data-2) branch. For planning purposes I > need some use cases and examples on where can this feature be used and > as an openscad user what improvement or enhancement would you like to > see ? > > You can have a gist of current implementation from following videos > http://files.openscad.org/video/screencast-parameter-window.webm > http://files.openscad.org/video/screencast-library-window.webm > > Thanks. > > -- > Shaina Sabarwal > blog: shainasabarwal.wordpress.com > github: github.com/shaina7837 > > You don't have to be great to start but start to be great. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Fri, Mar 20, 2015 5:50 PM
see ?
Just to comment on what's already there... it's basically prototyping
code for two use cases.
  1. Define Parameters for a specific Model
    We have a simple keychain that needs some basic features to be
    configurable for other people to use, e.g.
    • The length, width and height of the keychain
    • The text to write on it
    • The diameter of the hole
    This is essentially what the Thingiverse customizer is doing
  2. Define Parameters for Parts in a Library
    This refers to libraries like MCAD and maybe even more BOLTS. Right
    now, there is no UI support for using those. For example using
    a M4 bolt from BOLTS is:
    include <BOLTS/BOLTS.scad>
    ISO4014(key = "M4", l = 20);
    So you have to know what parameters are needed / possible. BOLTS
    has a very good documentation, but I think it would be even more
    user friendly if we can just add the include<>, start the compile
    and now a list of all library parts is available with included
    documentation for the parts and the parameters.
    Later we might even have that available via web with some kind of
    library index, but that's a different topic :-).
I'm sure there are more use cases and/or additional variations to the
two described above (e.g, saving parameter sets for the models from use
case 1).
On 03/20/2015 08:56 AM, Shaina Sabarwal wrote: > I am Shaina Sabarwal, one who worked on OpenSCAD GUI last year in > GSoC. This year I was thinking to work on Customizer feature > (currently implemented in meta-data-2) branch. For planning purposes I > need some use cases and examples on where can this feature be used and > as an openscad user what improvement or enhancement would you like to > see ? > Just to comment on what's already there... it's basically prototyping code for two use cases. 1) Define Parameters for a specific Model We have a simple keychain that needs some basic features to be configurable for other people to use, e.g. - The length, width and height of the keychain - The text to write on it - The diameter of the hole This is essentially what the Thingiverse customizer is doing 2) Define Parameters for Parts in a Library This refers to libraries like MCAD and maybe even more BOLTS. Right now, there is no UI support for using those. For example using a M4 bolt from BOLTS is: include <BOLTS/BOLTS.scad> ISO4014(key = "M4", l = 20); So you have to know what parameters are needed / possible. BOLTS has a very good documentation, but I think it would be even more user friendly if we can just add the include<>, start the compile and now a list of all library parts is available with included documentation for the parts and the parameters. Later we might even have that available via web with some kind of library index, but that's a different topic :-). I'm sure there are more use cases and/or additional variations to the two described above (e.g, saving parameter sets for the models from use case 1). ciao, Torsten.
PF
Peter Falke
Fri, Mar 20, 2015 6:48 PM
Nice work.
Very nice work!
Nice work. Very nice work!
PF
Peter Falke
Sun, Mar 22, 2015 2:48 PM
Have a look at:  https://www.youtube.com/watch?v=DRS6dhyvU-E
This is some impressive costumisation.
2015-03-20 19:48 GMT+01:00 Peter Falke stempeldergeschichte@googlemail.com
Nice work.
Very nice work!
schreiben.
Enjoy!
Have a look at: https://www.youtube.com/watch?v=DRS6dhyvU-E This is some impressive costumisation. 2015-03-20 19:48 GMT+01:00 Peter Falke <stempeldergeschichte@googlemail.com> : > Nice work. > Very nice work! > > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
Sun, Mar 22, 2015 3:16 PM
Ahh, nice example. I guess that's pretty much what we could do when saving
sets of model parameters along with the model itself.
A table view seems to be quite a useful thing, I hope it's not possible to
patent such a thing?
2015-03-20 19:48 GMT+01:00 Peter Falke <stempeldergeschichte@googlemail.com mailto:stempeldergeschichte@googlemail.com>:
 Nice work.
 Very nice work!
stempeldergeschichte@googlemail.com mailto:karsten@rohrbach.de
Enjoy!
Ahh, nice example. I guess that's pretty much what we could do when saving sets of model parameters along with the model itself. A table view seems to be quite a useful thing, I hope it's not possible to patent such a thing? ciao, Torsten. On 03/22/2015 03:48 PM, Peter Falke wrote: > Have a look at: https://www.youtube.com/watch?v=DRS6dhyvU-E > > This is some impressive costumisation. > > > 2015-03-20 19:48 GMT+01:00 Peter Falke <stempeldergeschichte@googlemail.com <mailto:stempeldergeschichte@googlemail.com>>: > > Nice work. > Very nice work! > > > > > -- > stempeldergeschichte@googlemail.com <mailto:karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Sun, Mar 22, 2015 9:23 PM
Hey,
GSoC.
Thanks for you efforts last year BTW, OpenSCAD is now a lot more user
friendly and starting to look professional.
View this message in context: http://forum.openscad.org/Fwd-OpenSCAD-Customizer-tp12090p12142.html
Shaina Sabarwal wrote > Hey, > > I am Shaina Sabarwal, one who worked on OpenSCAD GUI last year in > GSoC. Thanks for you efforts last year BTW, OpenSCAD is now a lot more user friendly and starting to look professional. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Fwd-OpenSCAD-Customizer-tp12090p12142.html Sent from the OpenSCAD mailing list archive at Nabble.com.
mitch
Tue, Mar 24, 2015 9:28 PM
Nice work Shaina! I also want to thank you for your contributions to the
interface last year. It's very nice and I look forward to your next
contribution.
I'm looking to contribute to the MCAD library this summer. I think the
standard parts library would be much more useful if it were integrated with
a customizer-like interface. We should collaborate. I am especially
interested in the abstraction and association of key parameters.
I have a ton of ideas for how this might work but I'm not sure they're ready
for the world. I was hoping there would be a bigger response to your post -
something to set the tone/expectations. Is this forum where that discussion
should be, or are there threads on github? If not, let's figure out a good
way to plan this out. (mockups, narratives, polls, etc?)
I apologize if this discussion concern is a solved problem, or if I'm doing
it wrong. I'm new to the community and I think this aspect of the project is
very important.
Thanks!
Mitch
View this message in context: http://forum.openscad.org/Fwd-OpenSCAD-Customizer-tp12090p12189.html
Nice work Shaina! I also want to thank you for your contributions to the interface last year. It's very nice and I look forward to your next contribution. I'm looking to contribute to the MCAD library this summer. I think the standard parts library would be much more useful if it were integrated with a customizer-like interface. We should collaborate. I am especially interested in the abstraction and association of key parameters. I have a ton of ideas for how this might work but I'm not sure they're ready for the world. I was hoping there would be a bigger response to your post - something to set the tone/expectations. Is this forum where that discussion should be, or are there threads on github? If not, let's figure out a good way to plan this out. (mockups, narratives, polls, etc?) I apologize if this discussion concern is a solved problem, or if I'm doing it wrong. I'm new to the community and I think this aspect of the project is very important. Thanks! Mitch -- View this message in context: http://forum.openscad.org/Fwd-OpenSCAD-Customizer-tp12090p12189.html Sent from the OpenSCAD mailing list archive at Nabble.com.
SS
Shaina Sabarwal
Tue, Mar 24, 2015 10:09 PM
I wish we could, but I have moved to other project for this summer, as
the Customizer of the OpenSCAD is at its first step and it requires
more discussions before implementing new features. That's what
understood by talking to mentors.
Shaina Sabarwal
On Wed, Mar 25, 2015 at 2:58 AM, mitch <mtchkll@gmail.com> wrote: > I'm looking to contribute to the MCAD library this summer. I think the > standard parts library would be much more useful if it were integrated with > a customizer-like interface. We should collaborate. I am especially > interested in the abstraction and association of key parameters. I wish we could, but I have moved to other project for this summer, as the Customizer of the OpenSCAD is at its first step and it requires more discussions before implementing new features. That's what understood by talking to mentors. -- Shaina Sabarwal blog: shainasabarwal.wordpress.com github: github.com/shaina7837 You don't have to be great to start but start to be great.
Tue, Mar 24, 2015 11:05 PM
Yes, it would probably possible to forward the work on this but with the
discussions needed, the timeline is hard to set. Also it's unlikely to
get to a state that could go into a release after the 3 month of GSoC
project. Having things merged is no requirement for GSoC results but I
think the chance of getting the work merged is a nice additional
motivation.
So while it's not an ideal GSoC project, we still can get the discussion
going. Especially regarding libraries it would be nice to collect things
that would make usage much more user friendly than just "use <library.scad>".
On 03/24/2015 11:09 PM, Shaina Sabarwal wrote: > On Wed, Mar 25, 2015 at 2:58 AM, mitch <mtchkll@gmail.com> wrote: >> I'm looking to contribute to the MCAD library this summer. I think the >> standard parts library would be much more useful if it were integrated with >> a customizer-like interface. We should collaborate. I am especially >> interested in the abstraction and association of key parameters. >> > I wish we could, but I have moved to other project for this summer, as > the Customizer of the OpenSCAD is at its first step and it requires > more discussions before implementing new features. That's what > understood by talking to mentors. > Yes, it would probably possible to forward the work on this but with the discussions needed, the timeline is hard to set. Also it's unlikely to get to a state that could go into a release after the 3 month of GSoC project. Having things merged is no requirement for GSoC results but I think the chance of getting the work merged is a nice additional motivation. So while it's not an ideal GSoC project, we still can get the discussion going. Especially regarding libraries it would be nice to collect things that would make usage much more user friendly than just "use <library.scad>". ciao, Torsten.
