Re: Is it possible to make the x y z indicator the same size as the axes numbers.
Roger Whiteley
Mon, Nov 9, 2026 8:43 AM
FWIW, larger would be appreciated.
Could the size be simply an option in .config/OpenSCAD/OpenSCAD.conf ?,
if its there, use it, if it's not, well, don't....
FWIW, larger would be appreciated. Could the size be simply an option in .config/OpenSCAD/OpenSCAD.conf ?, if its there, use it, if it's not, well, don't.... Roger.
Mon, Nov 9, 2026 9:15 PM
That answer in particular... probably not.  Config data is stored
differently on different systems, and I don't think we want people
mucking with it directly.  (Not that it's that hard to do, just that
it's a support minefield.)  On Windows, for instance, it's in the
Registry and you need to be an administrator to muck with it directly.
Could we make it be configurable?  Of course.
Do we really want to have a thousand little configurable things?  I
don't think so, and the road to a thousand little configurable things is
paved with "just this one".
On 11/9/2026 12:43 AM, Roger Whiteley via Discuss wrote: > FWIW, larger would be appreciated. > > Could the size be simply an option in .config/OpenSCAD/OpenSCAD.conf > ?, if its there, use it, if it's not, well, don't.... That answer in particular... probably not.  Config data is stored differently on different systems, and I don't think we want people mucking with it directly.  (Not that it's that hard to do, just that it's a support minefield.)  On Windows, for instance, it's in the Registry and you need to be an administrator to muck with it directly. Could we make it be configurable?  Of course. Do we really want to have a thousand little configurable things?  I don't think so, and the road to a thousand little configurable things is paved with "just this one".
GB
Glenn Butcher
Mon, Nov 9, 2026 9:25 PM
Okay then, just hard-code it a bit bigger.  It's too hard to read as-is.
Okay then, just hard-code it a bit bigger.  It's too hard to read as-is. On 11/9/2026 2:15 PM, Jordan Brown via Discuss wrote: > On 11/9/2026 12:43 AM, Roger Whiteley via Discuss wrote: >> FWIW, larger would be appreciated. >> >> Could the size be simply an option in .config/OpenSCAD/OpenSCAD.conf >> ?, if its there, use it, if it's not, well, don't.... > > That answer in particular... probably not.  Config data is stored > differently on different systems, and I don't think we want people > mucking with it directly.  (Not that it's that hard to do, just that > it's a support minefield.)  On Windows, for instance, it's in the > Registry and you need to be an administrator to muck with it directly. > > Could we make it be configurable?  Of course. > > Do we really want to have a thousand little configurable things? I > don't think so, and the road to a thousand little configurable things > is paved with "just this one". > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Mon, Nov 9, 2026 9:34 PM
Bigger than the current release, or bigger than the "slightly bigger" in
my development build?
See the images in https://github.com/openscad/openscad/pull/7197
On 11/9/2026 1:25 PM, Glenn Butcher via Discuss wrote: > Okay then, just hard-code it a bit bigger.  It's too hard to read as-is. Bigger than the current release, or bigger than the "slightly bigger" in my development build? See the images in https://github.com/openscad/openscad/pull/7197
SL
Steve Lelievre
Mon, Nov 9, 2026 11:37 PM
For me, your "slightly bugger" is enough.
Steve
For me, your "slightly bugger" is enough. Steve On 2026-11-09 2:34 PM, Jordan Brown via Discuss wrote: > On 11/9/2026 1:25 PM, Glenn Butcher via Discuss wrote: >> Okay then, just hard-code it a bit bigger.  It's too hard to read as-is. > > Bigger than the current release, or bigger than the "slightly bigger" > in my development build? > > See the images in https://github.com/openscad/openscad/pull/7197 > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
GB
Glenn Butcher
Tue, Nov 10, 2026 12:26 AM
The images in the PR would be a big improvement, that is, 'big enough'
for my particular angst.
The images in the PR would be a big improvement, that is, 'big enough' for my particular angst. On 11/9/2026 2:34 PM, Jordan Brown wrote: > On 11/9/2026 1:25 PM, Glenn Butcher via Discuss wrote: >> Okay then, just hard-code it a bit bigger.  It's too hard to read as-is. > > Bigger than the current release, or bigger than the "slightly bigger" > in my development build? > > See the images in https://github.com/openscad/openscad/pull/7197 >
