Is the OpenSCAD file small enough to share?
On Mon, May 2, 2022 at 5:23 PM Jan Öhman via Discuss <
To: OpenSCAD General Discussion discuss@lists.openscad.org
Cc:
Bcc:
Date: Mon, 2 May 2022 22:23:28 +0000 (UTC)
Subject: [OpenSCAD] Export to .stl or .3mf - Error - nothing to export.
Thought to check out what a 3D print from openSCAD would cost.
The company can only handle .stl, .3mf, stp
The openSCAD can export to .stl and .3mf
(I don't know the difference).
When "F5" is pressed - no problems occur.
When I select "File" / "Export" / "Export as STL" (F7)
The following message is displayed .:
"ERROR: Nothing to export! Try rendering first (press F6)"
I press "F6"
"WARNING: No top level geometry to render"
The same thing happens when I try to export to ".3MF"
Why / What to do?
From: "Jan Öhman via Discuss" discuss@lists.openscad.org
Cc: "Jan Öhman" jan_ohman@yahoo.com
Bcc:
The 3D-product can probably be created in a more efficient way, but this is what this code looks like now.
=======================include <BOSL2/std.scad>fn = 150;
placering="left";// placering="right"
box(0, 0, 0, placering, "#C0C0C0", fn); // (X, Y, Z, left/right, colorName)
// Monteringsplattan// mountingPlate(0, 0, 0, placering);
// LED belysning// LEDlampa(0, 0, 0, placering);
// - - - - - - - - - - - - - - - - - - - - - - - - - - - - - // - - - - m o d u l e r - - - - - - - - - - - - - - - - - -
---===module box(posX=0, posY=0, posZ=0, mountSide="left", colorName="#00FF00", fn=24){ side = mountSide == "left" ? 0 : mountSide == "right" ? 1 : assert(false,"invalid moutSide value"); // message if no case worked color(colorName) translate([posX, posY, posZ]) mirror([side, 0, 0]) difference() { union() { // Skapa konturer på bottenplattan - x, y, r, angles, [grader], början // Rotation medurs - vänster lamphållare (bakant saknas) points1 = circSect( 140, 0, 0, [0, 0], "right", 1, fn); // böj nere till höger points2 = circSect( 60, 5, 5, [0, 5], "bottom", 1, fn); // brytpunkt längst ned points3 = circSect( 10, 13, 10, [0, 90], "bottom", 1, fn); // böj nere till vänster points4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // böj uppe till vänster points5 = circSect( 140, 80, 5, [0, 1], "top", 1, fn); // böj uppe till höger edge = concat(points1, points2, points3, points4, points5); path = path3d(reverse(edge)); section = wall(); path_sweep( section, path, closed=false);
// Skapa bakkant lite högre och smalare i topp bottom1 = concat(points5, points1); polygon(bottom1); path1 = path3d(reverse(bottom1)); section1 = wall1(); // lite högre bakvägg wall(b=4, f=8, h=15, t=3.5) path_sweep( section1, path1, closed=false);
// fyll upp bottenplattansbaksida linear_extrude(4) // Bottomplate - fill up polygon(concat(points1, points2, points3, points4, points5)); // skapa Utskjutande del under (tänk spegelvänt) pt1 = circSect( 19.5, 85, 0, [0, 50], "top", 1, fn); // Uppe till höger - moturs pt2 = circSect( 39, 1.35, .1, [-5, 90], "right", 1, fn); // Nere till höger pt3 = circSect( 10, 13.05, 10, [0, 90], "bottom", 1, fn); // Nere till vänster pt4 = circSect( 5, 80, 5, [0, 90], "left", 1, fn); // Uppe till vänster translate([0, 0, -2]) linear_extrude(2.1) polygon(concat(pt1, pt2, pt3, pt4));
// utgången för kabeln på baksidan (diam 10mm) - pekar lite nedåt cableExit(65, 35, 0, 15, "cyan", $fn=100); } // skapa ett borrhål i bakkant translate([132,60,15]) { rotate([0, 90, 0]) { cylinder(h=10, d=2, $fn=100); cylinder(h=4, d=9, $fn=100); } } // skapa en borrmarkering i bakkant translate([139,25,15]) { rotate([0, 90, 0]) cylinder(h=2, d1=1, d2=2.5, $fn=100); } // ingravera årtalet på baksidan translate([10, 80, -0.5]) { mirror([side, 0, 0]) { rotate([0, 180, 0]) { linear_extrude(3) text("2022", size=12, direction="ttb", font="Comic Sans MS:style=Bold"); } } } /* // Markera skruvhål på bakkant borr=3; bredd=140; hojd=8; avstNed=20; translate([bredd, avstNed, hojd]) { rotate([0,90,0]) cylinder(h=2, d1=0.5, d2=borr, center=true, $fn=50); } */ // borrhål mountingHole(20, 36, 0, 7, 90.1, 15); // posX, posY, posZ, diam, dist, deep, $fn=50 }}//======== Slut box
---================//====== cableExit
---==============================module cableExit(posX, posY, posZ, angle, colorName){ diamHole = 7; diamHolder = 9.8; hight = 12; topRad = diamHolder/2; topDiam = diamHolder/2-topRad/2; bowRad = 7; offs1 = 0.1;
color(colorName) translate([posX, posY, posZ]) { rotate([180, 0, 180-angle]) { difference() { hull() { cylinder(h=hight, d=diamHolder, center=false); translate([0, 0, hight]) // rundad topp rotate_extrude(angle=360, convexity=2) translate([topDiam, 0, 0]) // yttre diam topp circle(d=topRad); // radie topp } inpHight = 2; // ett värde som styr var utgångshålet hamnar translate([0, 0, -offs1]) cylinder(h=inpHight+offs1, d=diamHole, center=false); // Bottenhål translate([-bowRad, 0, inpHight-offs1]) // böjen { rotate([90, 0, 0]) rotate_extrude(angle=90, convexity=10) translate([bowRad, 0, 0]) // ställ in radien på kabelböjen circle(d=diamHole); } } } }}//====== slut cableExit
---================//====== mountingHole
---===========================module mountingHole(posX=0, posY=0, posZ=0, diam=7, dist=90, deep=5, $fn=50){ // diam = 6; // [mm] // dist = 90; // [mm] // deep = 12; // [mm]
translate([posX, posY, posZ]) { translate([0, 0, -10]) cylinder(h=deep, d=diam); // fästhål 1 //cableHold1(dist/2, 0, .2, "#D5D5D5"); // Kabelgenomföring translate([dist/2, 0, 0]) { hull() { cylinder(h=5, d=6); // fästhål 1 sphere(d=7.5); } } translate([dist, 0, -10]) cylinder(h=deep, d=diam); // fästhål 2 }}//====== slut mountingHole
---================//====== LEDlampa
---===============================// module LEDlampa(posX=8, posY=10, posZ=0)module LEDlampa(posX=0, posY=0, posZ=0, mountSide="left"){ side = mountSide == "left" ? 0 : mountSide == "right" ? 1 : assert(false,"invalid moutSide value"); // message if no case worked xpos = mountSide == "left" ? 121 : mountSide == "right" ? -10 : assert(false,"invalid moutSide value"); // message if no case worked /* ypos = mountSide == "left" ? 10.5 : mountSide == "right" ? 10.5 : assert(false,"invalid moutSide value"); // message if no case worked zpos = mountSide == "left" ? 5 : mountSide == "right" ? 5 : assert(false,"invalid moutSide value"); // message if no case worked*/// echo(xpos,ypos,zpos); // translate([xpos, ypos, zpos]) translate([xpos, 10.5, 5]) mirror([1, 0, 0]) translate([posX, posY, posZ]) { LEDbottom(); translate([0, 0, 11]) LEDglas(); }}//====== Slut LEDlampa
---================//====== LEDglas
---================================module LEDglas(){ // Variabler botten length = 111; // längd mm wideMid = 50.5; // bredd i mitten mm cornRad = 10; // Radien i alla hörn wideCorn = 48; // Bredd i kanterna diamHole = 6; // håldiameter i mm colorBot = "gray"; colorTop = "orange"; // Variabler top cornHigh = 5; //Höjd i ändarna midHigh = 8; highTop = cornHigh + 1; // höjd mm p1tx = 10; // the start value p1ty = 49.25; p2tx = 55.5; // the middle value p2ty = 50.5; p3tx = 101; // the end value p3ty = p1ty; p4tx = 101; // the start value p4ty = 1.25; p5tx = 55.5; // the middle value p5ty = 0.0; p6tx = 10; // the end value p6ty = p4ty; // Ger ovalt glas points1 = 3points_arc([p1tx,p1ty], [p2tx,p2ty], [p3tx,p3ty], fn=100); points2 = 3points_arc([p4tx,p4ty], [p5tx,p5ty], [p6tx,p6ty], fn=100); color("orange") linear_extrude(height=cornHigh+.1) difference() { polygon(concat(points1, points2)); translate([length-10 , wideMid / 2, -.2]) circle(d=6); translate([10 , wideMid / 2, -.2]) circle(d=6); } // Top color(colorTop) difference() { hull() { // hörn1 translate([cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [10,39] cylinder(h=cornHigh, d=cornRad2, center=false); // hörn2 translate([cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) // [10,12] cylinder(h=cornHigh, d=cornRad2, center=false); // hörn3 translate([length - cornRad, wideMid - ((wideMid-wideCorn)/2) - cornRad, 0]) // [101 ,39] cylinder(h=cornHigh, d=cornRad2, center=false); // hörn4 translate([length - cornRad, cornRad + ((wideMid-wideCorn)/2), 0]) // cylinder(h=cornHigh, d=cornRad2, center=false); } union() { // Monteringshål 1 & 2 translate([length-10 , wideMid / 2, -.2]) cylinder(d=diamHole, h=highTop+.5, center=false); translate([10 , wideMid / 2, -.2]) cylinder(d=diamHole, h=highTop+.5, center=false); } }}//======== Slut LEDglas
---================//====== LEDbottom
---==============================module LEDbottom(){ p1x = 10; // the start value p1y = 49.25; p2x = 55.5; // the middle value p2y = 50.5; p3x = 101; // the end value p3y = p1y;
p4x = 101; // the start value p4y = 1.25; p5x = 55.5; // the middle value p5y = 0.0; p6x = 10; // the end value p6y = p4y; // Variabler botten för borrhålen length = 111; // längd mm wideMid = 50.5; // bredd i mitten mm diamHole = 6; // håldiameter i mm cornHigh = 5; //Höjd i ändarna midHigh = 8; highTop = cornHigh + 1; // höjd mm // offs1 = 0.1; heightHole = 15; //mm height = 11; //mm points1 = circSect( 10, 11.25, 10, [0, 90], "bottom", 1, fn); // Hörn nere till vänster points2 = circSect( 10, 39.25, 10, [0, 90], "left", 1, fn); // Hörn uppe till vänster points3 = 3points_arc([p1x,p1y], [p2x,p2y], [p3x,p3y], fn); points4 = circSect( 101, 39.25, 10, [0, 90], "top", 1, fn); // Hörn uppe till höger points5 = circSect( 101, 11.25, 10, [0, 90], "right", 1, fn); // Hörn nere till höger points6 = 3points_arc([p4x,p4y], [p5x,p5y], [p6x,p6y], fn);
// The base plate for the LED lamp
difference() { color("gray", 0.5) linear_extrude(height=height) polygon(concat(points1, points2, points3, points4, points5, points6));
// union() { // Monteringshål 1 & 2 translate([length-10 , wideMid / 2, -.2]) cylinder(d=diamHole, h=heightHole, center=false); translate([10 , wideMid / 2, -.2]) cylinder(d=diamHole, h=heightHole, center=false); } }}//======== Slut LEDbottom
---================//====== circleSect
---=============================// Create rounded corners 2D// https://openhome.cc/eGossip/OpenSCAD/SectorArc.html// ange .: x, y, radien,// [från, till] vinkel,// var vinkeln startar, (left, bottom, right, top)// vilken rotation (-1=medsol, 1=motsols)function circSect(x=0, y=0, radius=10, angles=[0,270], startRef="bottom", rotate=1, fn=24) = let( startAngel = (startRef == "left") ? 0 : (startRef == "bottom") ? 90 : (startRef == "right") ? 180 : (startRef == "top") ? 270 : startRef, // valfri vinkel // : assert(false,"invalid moutSide value"); // Error message if no case worked //: undef, r = radius, //r = radius / cos(180 / fn), step = 360 / fn, // points = [[x, y], points = [ for(a = [angles[0]-startAngel : step : angles[1]-startAngel]) [-rotate * r * cos(a)+x, r * sin(a)+y]] ) points;//======== Slut circleSect
---================//====== 3points_arc
---============================// Create an arc with three points 2Dfunction 3points_arc(p0, p1, p2, fn=10) = // an alternative expression for D // D = 2 * ( (p1-p0).x * (p2-p0).y - (p1-p0).y * (p2-p0).x ) let( D = 2 * cross(p1-p0, (p2-p0)) ) assert( abs(D)>1e-9, "The 3 points should not be collinear." ) let( Ux = ( (p2-p0).y*(p1-p0)(p1-p0) - (p1-p0).y(p2-p0)(p2-p0) )/D, Uy = ( (p1-p0).x(p2-p0)(p2-p0) - (p2-p0).x(p1-p0)(p1-p0) )/D, radius = norm([Ux,Uy]), center = [Ux,Uy] + p0, ang0 = atan2( (p0-center).y, (p0-center).x ), ang2 = atan2( (p2-center).y, (p2-center).x ), // the points are in a cw winding iff D<0 // the angular difference between vectors p2-center and p0-center // measured from p0-center; dang is positive iff D is negative dang = D<0 ? ang2<ang0 ? ang2-ang0 : ang2-ang0-360 : ang2>ang0 ? ang2-ang0 : ang2-ang0+360 ) [ for(i=[0:fn-1]) let( ang = ang0 + idang/(fn-1) ) center + radius*[cos(ang),sin(ang)] ];//======== Slut 3points_arc
---================//====== Wall som ett "L"
---=======================// Normal vägghöjdfunction wall() = let( b = 4, // botten - tjocklek f = 8, // Foten h = 15, // Höjd t = 3.5, // Top x = (b+(t/2) - (h - ( (-h / (f-t)) *t) )) / (-h / (f-t)) ) let( points = [[0,0], [f,0], [t,h], [0,h]] , top = move([t/2, h, 0], circle(d=t, $fn=20)), sqr = square([10, b]), diff = difference([ move([x, b], square([t/2, t/2])), move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) ) union([points, top, sqr, diff]);//======== Slut Wall
---================//====== Wall1 som ett "L"
---======================// En högre väggfunction wall1() = let( b = 4, // botten - tjocklek f = 7, // Foten h = 25, // Höjd t = 3, // Top x = (b+(t/2) - (h - ((-h / (f-t)) *t))) / (-h / (f-t)) ) let( points = [[0,0], [f,0], [t,h], [0,h]] , top = move([t/2, h, 0], circle(d=t, $fn=20)), sqr = square([10, b]), diff = difference([ move([x, b], square([t/2, t/2])), move([x+(t/2), b+(t/2), 0], circle(d = t, $fn=20) ) ]) ) union([points, top, sqr, diff]);//======== Slut Wall1
---================//====== Plåt på släp
---===========================module mountingPlate(posX=0, posY=0, posZ=0, mountSide="left", colorName="#C0C0C0", $fn=50){ // Hörnpositionerna posX1 = 120; posY1 = 0; posX2 = posX1; posY2 = -200; posX3 = 120 - 75; posY3 = -200; posX4 = 0; posY4 = 0; thick=2; // tjocklek side = mountSide == "left" ? 0 : mountSide == "right" ? 1 : assert(false,"invalid moutSide value"); // message if no case worked xpos = mountSide == "left" ? 20 : mountSide == "right" ? -20 : assert(false,"invalid moutSide value"); // message if no case worked/* ypos = mountSide == "left" ? 85 : mountSide == "right" ? 85 : assert(false,"invalid moutSide value"); // message if no case worked zpos = mountSide == "left" ? -thick : mountSide == "right" ? -thick : assert(false,"invalid moutSide value"); // message if no case worked*/ color(colorName) { translate([posX, posY, posZ]) translate([xpos, 85, -thick]) { mirror([side, 0, 0]) { linear_extrude(thick) hull() { translate([posX1, posY1, 0]) square(0.1, center = true); translate([posX2, posY2, 0]) square(0.1, center = true); translate([posX3, posY3, 0]) square(0.1, center = true); translate([posX4, posY4, 0]) square(0.1, center = true); } } } }}
Den tisdag 3 maj 2022 01:49:27 CEST, Father Horton fatherhorton@gmail.com skrev:
On Mon, May 2, 2022 at 5:23 PM Jan Öhman via Discuss discuss@lists.openscad.org wrote:
Cc:
Bcc:
Thought to check out what a 3D print from openSCAD would cost.The company can only handle .stl, .3mf, stpThe openSCAD can export to .stl and .3mf
I press "F6"
The following message is displayed .:"WARNING: No top level geometry to render"
Why / What to do?
Bcc:
