Suppressing "search term not found" warning in search( ) ???
runsun
Mon, Apr 13, 2015 9:39 PM
When using search( ), the console pops out a "Warning: search term not found:
..." when the searched term not found.
Is there any way to suppress this warning ?
Here is the story:
I wanna use search( ) to build up a hash( ) function for parameter settings.
Users have the freedom to set some parameters, or not.
When a parameter is not set by users, the hash( ) function has a default
mechanism to handle it. This is considered normal (so shouldn't be
"warned").
With the warning, however, no matter whether the not-found is dealt with, it
always pops up the warning. As a result, it could end up a long list of
unnecessary warnings in the console. This is unacceptable in my case.
$  Runsun Pan, PhD
$ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse  )
View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359.html
When using search( ), the console pops out a "Warning: search term not found: ..." when the searched term not found. Is there any way to suppress this warning ? Here is the story: I wanna use search( ) to build up a hash( ) function for parameter settings. Users have the freedom to set some parameters, or not. When a parameter is not set by users, the hash( ) function has a default mechanism to handle it. This is considered normal (so shouldn't be "warned"). With the warning, however, no matter whether the not-found is dealt with, it always pops up the warning. As a result, it could end up a long list of unnecessary warnings in the console. This is unacceptable in my case. ----- $ Runsun Pan, PhD $ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse ) $ -- hash parameter model: here , here $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly -- View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Mon, Apr 13, 2015 10:08 PM
+1
View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359p12360.html
+1 ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359p12360.html Sent from the OpenSCAD mailing list archive at Nabble.com.
AP
Andrew Plumb
Mon, Apr 13, 2015 10:48 PM
Sounds reasonable.
Simple fix+pull request created: https://github.com/openscad/openscad/pull/1312 https://github.com/openscad/openscad/pull/1312
Andrew.
Here is the story:
"warned").
$  Runsun Pan, PhD
Sounds reasonable. Simple fix+pull request created: https://github.com/openscad/openscad/pull/1312 <https://github.com/openscad/openscad/pull/1312> Andrew. > On Apr 13, 2015, at 5:39 PM, runsun <runsun@gmail.com> wrote: > > When using search( ), the console pops out a "Warning: search term not found: > ..." when the searched term not found. > > Is there any way to suppress this warning ? > > Here is the story: > > I wanna use search( ) to build up a hash( ) function for parameter settings. > Users have the freedom to set some parameters, or not. > > When a parameter is not set by users, the hash( ) function has a default > mechanism to handle it. This is considered normal (so shouldn't be > "warned"). > > With the warning, however, no matter whether the not-found is dealt with, it > always pops up the warning. As a result, it could end up a long list of > unnecessary warnings in the console. This is unacceptable in my case. > > > > > > ----- > > $ Runsun Pan, PhD > > $ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse ) > > $ -- hash parameter model: here , here > > $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly > > > > > -- > View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
runsun
Tue, Apr 14, 2015 4:35 AM
Thanks a million, Andrew. This would be a significant aid to my code. Am I
right that it won't be available in the nightly-build until it's merged to
the master ?
$  Runsun Pan, PhD
View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359p12364.html
Thanks a million, Andrew. This would be a significant aid to my code. Am I right that it won't be available in the nightly-build until it's merged to the master ? ----- $ Runsun Pan, PhD $ -- OpenScad_DocTest: doc and unit test ( Github , Thingiverse ) $ -- hash parameter model: here , here $ -- Linux Mint 17.1 Rebecca x64 + OpenSCAD 2015.03.15/2015.04.01.nightly -- View this message in context: http://forum.openscad.org/Suppressing-search-term-not-found-warning-in-search-tp12359p12364.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Apr 14, 2015 11:44 AM
the master ?
Yes, the nightly-builds are based on master.
But actually those are not really "nightly" builds, they are triggered after
commit / merge on github. So if you subscribe on the pull request, you'll
get a mail about 30 minutes before the builds are ready ;-).
On 04/14/2015 06:35 AM, runsun wrote: > Thanks a million, Andrew. This would be a significant aid to my code. Am I > right that it won't be available in the nightly-build until it's merged to > the master ? > Yes, the nightly-builds are based on master. But actually those are not really "nightly" builds, they are triggered after commit / merge on github. So if you subscribe on the pull request, you'll get a mail about 30 minutes before the builds are ready ;-). ciao, Torsten.
lar3ry
Tue, Jun 8, 2021 3:21 PM
Strange. I get no warning. I am running version 2021.01
Strange. I get no warning. I am running version 2021.01 -- Sent from: http://forum.openscad.org/
