Differencing failing
Thu, Aug 3, 2017 11:09 PM
The way I get around that is to have a global.scad that I include in all my
other files. I can then define a variable in that that will affect them all.
On 3 August 2017 at 23:14, david vanhorn kc6ete@gmail.com wrote:
Ok, dialing back the convexity got it.  I found that as an example
somewhere. It was working so I didn't mess with it.
I have rebuilt all my files to "use" rather than "Include" but I'm having
one issue.
I have a variable called CrossSection which is either true or undefined.
If undefined the modules are supposed to be complete, and if true they are
supposed to difference with a large cube to create a cross section view.
Apparently the value of CrossSection isn't being passed down to the
modules. I can clip it in the main view, but then all the faces are green,
and there is a bunch of artifacting where parts of the model that were
differenced out are allowing me to see through the model.
K1FZY (WA4TPW) SK  9/29/37-4/13/15
The way I get around that is to have a global.scad that I include in all my other files. I can then define a variable in that that will affect them all. On 3 August 2017 at 23:14, david vanhorn <kc6ete@gmail.com> wrote: > > Ok, dialing back the convexity got it. I found that as an example > somewhere. It was working so I didn't mess with it. > > I have rebuilt all my files to "use" rather than "Include" but I'm having > one issue. > I have a variable called CrossSection which is either true or undefined. > If undefined the modules are supposed to be complete, and if true they are > supposed to difference with a large cube to create a cross section view. > Apparently the value of CrossSection isn't being passed down to the > modules. I can clip it in the main view, but then all the faces are green, > and there is a bunch of artifacting where parts of the model that were > differenced out are allowing me to see through the model. > > > > -- > K1FZY (WA4TPW) SK 9/29/37-4/13/15 > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
