DV
david vanhorn
Tue, Aug 1, 2017 4:36 PM
I am modeling an object that consists of four parts, two of which are
fairly complicated shapes.
In the final view, I need to see all four parts at various degrees of
separation.
The two complicated parts are both differenced by a common "core" which
creates internal space.
When I view either one in it's own file, they are fine.
When I view one of the two complicated parts in the assembly, it appears as
if the "core"
difference didn't happen.
It's complicated, and I wouldn't want to have people trying to thread
through it.
Here's generally what I'm trying to do:
First file:
module PartA () {
difference () {
WholeA();
Core();
PartA();
Part A displays properly with Core cut out of it.
Now comment out the invocation of part A and save the file.
Next file:
module PartB () {
difference () {
WholeB();
Core();
PartB();
Part B displays properly with Core cut out of it.
Now comment out the invocation of part B and save the file.
Whole assembly:
include the files for part A and part B
Z=2;
module Project(){
union(){
translate ([0,0,(Z*1)]){
PartA();
translate ([0,0,(Z*2)]){
PartB();
Project();
Part A and Part B display.
Part A displays correctly, and part B looks like the core didn't get
subtracted.
If I # the core, I see it in this view.
I don't understand why part B is acting this way.
Any ideas?
K1FZY (WA4TPW) SK 9/29/37-4/13/15
separation.
if the "core"
through it.
First file:
module PartA () {
difference () {
WholeA();
Core();
PartA();
Next file:
module PartB () {
difference () {
WholeB();
Core();
PartB();
Whole assembly:
Z=2;
module Project(){
union(){
PartA();
PartB();
Project();
subtracted.
Any ideas?
DV
david vanhorn
Tue, Aug 1, 2017 8:33 PM
If I # the core, I see it in this view. even if I only include part B. (as
expected)
separation.
as if the "core"
through it.
First file:
module PartA () {
difference () {
WholeA();
Core();
PartA();
Next file:
module PartB () {
difference () {
WholeB();
Core();
PartB();
Whole assembly:
Z=2;
module Project(){
union(){
PartA();
PartB();
Project();
subtracted.
Any ideas?
expected)
> separation.
> as if the "core"
> through it.
> First file:
> module PartA () {
> difference () {
> WholeA();
> Core();
> PartA();
> Next file:
> module PartB () {
> difference () {
> WholeB();
> Core();
> PartB();
> Whole assembly:
> Z=2;
> module Project(){
> union(){
> PartA();
> PartB();
> Project();
> subtracted.
> Any ideas?
Wed, Aug 2, 2017 12:43 AM
In the union do the A & B parts overlap?
If one has a solid section overlapping the hollow core of the other, I'm
presuming the solid is unioned thus filling in the core. ??
View this message in context: http://forum.openscad.org/Differencing-failing-tp21984p21987.html
Wed, Aug 2, 2017 12:44 AM
BTW, as a generalisation it is always better to union positive objects, then
difference the negatives.
View this message in context: http://forum.openscad.org/Differencing-failing-tp21984p21988.html
DV
david vanhorn
Wed, Aug 2, 2017 3:08 PM
In the final file, I am simply positioning positive objects.
In the construction files, I am taking the approach of unioning up all the
constructive geometry and then differencing out the union(s) of the
subtractive parts.
The A and B parts don't overlap. They do come close, but that's part of the
design. I don't know if the core part is somehow being brought in as part
of the A and B objects and then in the construction file, it is overlapping
itself and causing issues. Not even sure if that's possible.
then
subtractive parts.
> then
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
Wed, Aug 2, 2017 3:38 PM
It's hard to say without the source code but you could try putting render()
in your PartA and PartB modules.
subtractive parts.
the design. I don't know if the core part is somehow being brought in as
part of the A and B objects and then in the construction file, it is
overlapping itself and causing issues. Not even sure if that's possible.
then
> subtractive parts.
>> then
DV
david vanhorn
Wed, Aug 2, 2017 4:23 PM
I know. and it's a big project, some dozen files, and I don't want to
inflict that on anyone.
I'll try adding the render tonight and see what happens.
If it persists, I'll try to boil it down to a simpler test case. I'm sure
I'm doing something wrong, the sheer complexity makes that virtually
certain.
Can you clarify for me though, if I difference a cube from a sphere, and
make that a module, when I use that module in another file, does the cube
"exist" in the second file, or is the complex (sphere - cube) shape passed
up?
Part of my issue may lie in the fact that there are the four major parts,
which I need working in their own files so they can be printed, and then I
need to pull them into this "exploded assembly" file to look at how things
are fitting together. I don't yet have an elegant way to say "if I'm
running from this file, then invoke the object so I can see it and create
STL file, but if I'm running from some other file then don't invoke the
object"
render() in your PartA and PartB modules.
the constructive geometry and then differencing out the union(s) of the
subtractive parts.
then
certain.
up?
object"
>> subtractive parts.
>>> then
DV
david vanhorn
Wed, Aug 2, 2017 5:29 PM
So I generated a simple test case, which isn't too painful. Of course it
works just fine.
Object C is subtracted from objects A and B, and then both A and B are used
in file D to create an "assembly view"
C.scad:
module C () {
cube (1,0);
//C(); // for working on the object itself.
A.scad:
include <c.scad>
$fn=100;
module A () {
difference (){
sphere (r=1);
C();
//A();
B.scad:
include <c.scad>
$fn=100;
module B () {
difference (){
sphere (r=1);
C();
//B();
D.scad:
include <A.scad>;
include <B.scad>;
expand = 3; // change this to "disassemble" the parts.
$fn=100;
module D () {
union(){
translate ([0,0,expand0]){
A();
translate ([0,0,expand1]){
B();
D();
Of course this is trivial and does not need to be broken up like this but
it's a far less painful version to illustrate what's happening.
In my views the bottom sphere "A" would have no section cut out of it.
The real objects and differencing objects are way more complicated, but
constructed by first unioning everything, then differencing out the parts I
don't want.
certain.
up?
object"
subtractive parts.
then
works just fine.
C.scad:
module C () {
cube (1,0);
A.scad:
include <c.scad>
$fn=100;
module A () {
difference (){
sphere (r=1);
C();
//A();
B.scad:
include <c.scad>
$fn=100;
module B () {
difference (){
sphere (r=1);
C();
//B();
D.scad:
include <A.scad>;
include <B.scad>;
$fn=100;
module D () {
union(){
translate ([0,0,expand*0]){
A();
translate ([0,0,expand*1]){
B();
D();
don't want.
> certain.
> up?
> object"
>>> subtractive parts.
>>>> then
DV
david vanhorn
Wed, Aug 2, 2017 5:33 PM
I should also say that the "C" object in the real parts is long, and would
extend far enough in + an - Z to overlap with objects above and below.
What's happening to me almost looks like the C object differencing B is
somehow overlapping with itself in the A object, and canceling itself
out... ??
out... ??
Wed, Aug 2, 2017 6:26 PM
if I difference a cube from a sphere, and make that a module, when I use
that module in another file, does the cube "exist" in the second file, or
is the complex (sphere - cube) shape passed up?
During an F5 preview all the primitive shapes (both positive and negative)
are all drawn in various rendering modes. With render(), or F6 then the
actual shape is calculated and passed up as a polyhedron.
Does it look different if you zoom far out? During F6 all the primitive
shapes, including the negative ones need to be inside the clipping volume
or they don't get drawn. That can make a difference go wrong.
I always render my top level objects, otherwise negative objects can
interfere if they line up exactly. Normally it just causes Z fighting
rather than making something disappear.
> out... ??
