Tue, Feb 23, 2016 4:46 AM
As part of the Sad Face
https://www.thingiverse.com/thing:1350837/#comments discussions, there
is mention of watermarking your photos.
I' like to talk about the equivalent for your mesh files.
Export currently flags
STL files with, "solid OpenSCAD_Model"
AMF files with, " <metadata type="producer">OpenSCAD 2016.02.09 (git
9950e6a)</metadata>"
I haven't checked the other formats.
I did a check of some other STLs, and found (for B:inary & A:SCII) these in
the wild:
A:solid t231461 ak47 netfabb (repaired)
B:binary stl file
B:STL File created by netfabb - http://www.netfabb.com UNITS=MM
A:solid Default
B:MESHMIXER-STL-BINARY-FORMAT----------------------------------------------------
B:File exported by Artec Group 3D Scanning Solutions, www.artec-group.com
B:Exported from Blender-2.74 (sub 0)
B:solid Bag Handle v1-5 Slim
B:COLOR= ...,MATERIAL=... ;SOLID
While STL and AMF are ASCII there is no problem, they can be manually
edited.
However there has been discussion on introducing binary/compressed files
which make that harder.
I think some feature to add other meta-data to the export would be good.
Binary STL seems to be the limiting factor, 80 character header. If we want
to keep the OpenSCAD branding then we need to reserve some of that for
OpenSCAD. Given the AMF string is ~30 chars, that could reserve the first 40
chars for branding, and allow user meta-data to use the last 40 chars.
You could fit a copyright symbol, a short form CC tag and a bit.ly etc URL,
or the like.
Thoughts?
View this message in context: http://forum.openscad.org/Ability-to-specify-contents-of-exported-header-tp16214.html
<https://www.thingiverse.com/thing:1350837/#comments> discussions, there
the wild:
B:binary stl file
A:solid Default
edited.
or the like.
Thoughts?
Tue, Feb 23, 2016 2:48 PM
TLDR; I think that the metadata should be a set of name/value pairs, as
that's what's most appropriate for the 7 file formats that we currently
export. Most modern file formats support metadata in the form of name/value
pairs, which means you aren't supposed to jam all the metadata into a
single short string without any tagging of the components.
Binary STL is an exception, but we don't support that yet, and there are
significant technical problems with binary STL support that might delay it
indefinitely, or place limitations on how well it works. Maybe binary STL
will be the one format for which metadata isn't supported.
Eg, PNG supports the Extensible Metadata Platform, which is a superset of
the Dublin Core metadata, which has the tags Title, Creator, Subject,
Description, Publisher, Contributor, Date, Type, Format, Identifier,
Source, Language, Relation, Coverage and Rights.
The AMF standard reserves a number of metadata types; the following are the
ones relevant to us:
name - The alphanumeric label of the entity, to be used by the
interpreter if interacting with the user.
description - A description of the content of the entity
url - A link to an external resource relating to the entity
author - Specifies the name(s) of the author(s) of the entity
company - Specifying the company generating the entity
cad - specifies the name of the originating CAD software and version
revision - specifies the revision of the entity
tolerance - specifies the desired manufacturing tolerance of the entity
in entity’s unit system
We should be using "cad" instead of "producer" for the OpenSCAD version.
Different metadata types should be used for other information.
The 3MF file format supports any of the metadata types in the Open
Packaging Conventions/Core Properties. Same idea, a set of name/value
pairs, but there's a longer list of standard types, including creation
time, modification time, search keywords, thumbnail images.
And so on. For old ascii formats like ascii STL and OFF, we can put
name/value metadata pairs into comments, one pair per line.
the wild:
B:binary stl file
A:solid Default
edited.
40
URL,
or the like.
Thoughts?
* name - The alphanumeric label of the entity, to be used by the
* description - A description of the content of the entity
* url - A link to an external resource relating to the entity
* author - Specifies the name(s) of the author(s) of the entity
* company - Specifying the company generating the entity
* cad - specifies the name of the originating CAD software and version
* revision - specifies the revision of the entity
* tolerance - specifies the desired manufacturing tolerance of the entity
> the wild:
> B:binary stl file
> A:solid Default
> edited.
> 40
> URL,
> or the like.
> Thoughts?
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
Tue, Feb 23, 2016 3:01 PM
and there are significant technical problems with binary STL support that
might delay it indefinitely
I think it is simply a matter of writing binary records instead of ASCII.
The issue of keeping it manifold after truncating the values is common to
ASCII floats and binary floats. I.e. if we simply change the output format
we are no worse off than we are now with ASCII STLs. Possibly slightly
better as it removes the conversion to string and back again that can
change the value slightly unless it is done very carefully.
For old ascii formats like ascii STL and OFF, we can put name/value
I don't think STL files have comment lines do they?
the ones relevant to us:
there
in
the wild:
B:binary stl file
A:solid Default
edited.
want
40
URL,
or the like.
Thoughts?
>> there
>> in
>> the wild:
>> B:binary stl file
>> A:solid Default
>> edited.
>> want
>> 40
>> URL,
>> or the like.
>> Thoughts?
Tue, Feb 23, 2016 3:46 PM
Oops you are correct. No comment lines in STL. Maybe could still use "solid
tag1=val1; tag2=val2; ..." in ASCII stl.
there
in
the wild:
B:binary stl file
A:solid Default
www.artec-group.com
edited.
want
first 40
URL,
or the like.
Thoughts?
javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');
>>> there
>>> in
>>> the wild:
>>> B:binary stl file
>>> A:solid Default
>>> www.artec-group.com
>>> edited.
>>> want
>>> first 40
>>> URL,
>>> or the like.
>>> Thoughts?
>>> <javascript:_e(%7B%7D,'cvml','Discuss@lists.openscad.org');>
