Quit or Exit function?
Mon, Aug 31, 2015 12:39 PM
Is there any way to say "if these parameters are bad, quit immediately"?
Is there any way to say "if these parameters are bad, quit immediately"? Jon
Mon, Aug 31, 2015 1:27 PM
Von: jon jon@jonbondy.com
Currently there is no such thing (except implementing it manually using flags).
There is a request to add something like assert() in:
https://github.com/openscad/openscad/issues/381
which is a bit awkward to implement as it would be useful to handle both
functions and modules.
Von: jon <jon@jonbondy.com> > Is there any way to say "if these parameters are bad, quit immediately"? > Currently there is no such thing (except implementing it manually using flags). There is a request to add something like assert() in: https://github.com/openscad/openscad/issues/381 which is a bit awkward to implement as it would be useful to handle both functions and modules. ciao, Torsten.
N
Neon22
Tue, Sep 1, 2015 3:15 AM
I had an issue like this in a Customizer script where users could choose
values that could make a nonsense result. Because of the lack of a feedback
or reporting loop, I chose to detect the conditoin and replace the generated
object with a text object containing a message.
So I executed normally but exposed a different object.
View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13669.html
I had an issue like this in a Customizer script where users could choose values that could make a nonsense result. Because of the lack of a feedback or reporting loop, I chose to detect the conditoin and replace the generated object with a text object containing a message. So I executed normally but exposed a different object. -- View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13669.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Sep 1, 2015 3:19 AM
Yeh, but it would be handy to have something deep in your code like
exit("you idiot!");
View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13672.html
Yeh, but it would be handy to have something deep in your code like exit("you idiot!"); ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13672.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Tue, Sep 1, 2015 3:32 AM
Add an option to my theoretical  echof()
https://github.com/openscad/openscad/issues/741  - who's name can be just
echo() but proposed within functions. And echo() the module too of course.
echo("You idiot!", $exit=true);
// $exit, to try to reduce backward compatibility conflict with normal
variable names.
View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13673.html
tp3 wrote > which is a bit awkward to implement as it would be useful to handle both > functions and modules. Add an option to my theoretical echof() <https://github.com/openscad/openscad/issues/741> - who's name can be just echo() but proposed within functions. And echo() the module too of course. echo("You idiot!", $exit=true); // $exit, to try to reduce backward compatibility conflict with normal variable names. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13673.html Sent from the OpenSCAD mailing list archive at Nabble.com.
GW
G. Wade Johnson
Tue, Sep 1, 2015 3:43 AM
On Mon, 31 Aug 2015 20:32:19 -0700 (MST)
too of course.
variable names.
I would prefer an exit() function, or, if we want a message a different
function like die() or fatal().
I really don't like functions/methods/subroutines with flag parameters.
G. Wade
Always hold a grudge. Keeps the memory sharp. -- Hagar the Horrible
On Mon, 31 Aug 2015 20:32:19 -0700 (MST) MichaelAtOz <oz.at.michael@gmail.com> wrote: > tp3 wrote > > which is a bit awkward to implement as it would be useful to handle > > both functions and modules. > > Add an option to my theoretical echof() > <https://github.com/openscad/openscad/issues/741> - who's name can > be just echo() but proposed within functions. And echo() the module > too of course. > > echo("You idiot!", $exit=true); > // $exit, to try to reduce backward compatibility conflict with normal > variable names. I would prefer an exit() function, or, if we want a message a different function like die() or fatal(). I really don't like functions/methods/subroutines with flag parameters. G. Wade > ----- > Unless specifically shown otherwise above, my contribution is in the > Public Domain; To the extent possible under law, I have waived all > copyright and related or neighbouring rights to this work. This work > is published globally via the internet. :) Inclusion of works of > previous authors is not included in the above. > > The TPP is no simple “trade agreement.” Fight it! > http://www.ourfairdeal.org/ -- > View this message in context: > http://forum.openscad.org/Quit-or-Exit-function-tp13659p13673.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org -- Always hold a grudge. Keeps the memory sharp. -- Hagar the Horrible
Tue, Sep 1, 2015 4:01 AM
True, I was trying an extra push for echof() ;) ...
View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13677.html
G. Wade Johnson wrote > I would prefer an exit() function, or, if we want a message a different > function like die() or fatal(). > > I really don't like functions/methods/subroutines with flag parameters. True, I was trying an extra push for echof() ;) ... ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/Quit-or-Exit-function-tp13659p13677.html Sent from the OpenSCAD mailing list archive at Nabble.com.
