Re: Manipulating External Meshes
DE
David Eccles (gringer)
Wed, Jan 29, 2025 10:00 AM
The holes also happen in preview mode if the imported objects have
complex curves. Sometimes increasing the convexity parameter of the
import will help:
import("myfile.stl", convexity=20);
This will slow down the rendering a little, but it fixes up sight line
intersection problems.
  • David
The holes also happen in preview mode if the imported objects have complex curves. Sometimes increasing the convexity parameter of the import will help: import("myfile.stl", convexity=20); This will slow down the rendering a little, but it fixes up sight line intersection problems. - David
