OpenSCAD is complex enough that I usually stick to a subset of all of
the features. I'm sure this has been discussed in the past, but I
ignored it, since it was unnecessary at the time. Times change.
I want to create 3 variants on some geometry. The key difference
between the 3 variants lies in 3 different 2D shapes that are
rotate_extruded inside the main module(). At the moment, I have three
lines of code, and I carefully comment out 2 of the 3 each time I run
the program. It works but is awkward.
I tried passing the 2D geometry in as a parameter, but that failed. I
am pretty sure that passing in modules that generate the 2D geometry
will also fail.
What is the best current approach please?
Thanks!
In OpensCAD geometries are no 1st class objects, yo cannot pass geometry as
arguments, but there is a workaround
you can do:
module mymodule(a,b)
square(a,b);
child(1); // accessing 1st child here
mymodule(a,b) {
circle(1); // geometry passed as child
hope that helps
On Thu, Jan 16, 2025 at 2:27 PM Jon Bondy via Discuss <
will also fail.
Thanks!
geometry as arguments, but there is a workaround
It's not a workaround. It's a designed feature for achieving this exact
goal. It's just not using geometry-as-data-values.
And functions are first-class objects, or close to it. A function
declared with
function foo(arg) = ...;
can't be passed around as data, but a function expression can:
myfunc = function (args) ...;
Modules are not (yet) first class. PR#4478 has first-class geometry and
modules.
child() is deprecated; children() is the preferred name.
