Broydens method
K
kitwallace
Sun, Apr 1, 2018 9:13 AM
I'm doing some work on geometric tiling (the 15 shades of pentagon) and need
to numerically solve 2 variable functions. Fortunately they are
well-behaved:
http://forum.openscad.org/file/t229/2dfunction.jpg
Broyden's method (and refinements) seems to be the thing to use but I wonder
if anyone has an implementation already  - or a different approach to
function optimisation
Chris
I'm doing some work on geometric tiling (the 15 shades of pentagon) and need to numerically solve 2 variable functions. Fortunately they are well-behaved: <http://forum.openscad.org/file/t229/2dfunction.jpg> Broyden's method (and refinements) seems to be the thing to use but I wonder if anyone has an implementation already - or a different approach to function optimisation Chris -- Sent from: http://forum.openscad.org/
Sun, Apr 1, 2018 11:51 AM
Broyden's method looks tricky to me. Would it be easier to use gradient
descent?
need
well-behaved:
wonder
Chris
Broyden's method looks tricky to me. Would it be easier to use gradient descent? On 1 April 2018 at 05:13, kitwallace <kit.wallace@gmail.com> wrote: > I'm doing some work on geometric tiling (the 15 shades of pentagon) and > need > to numerically solve 2 variable functions. Fortunately they are > well-behaved: > > <http://forum.openscad.org/file/t229/2dfunction.jpg> > > Broyden's method (and refinements) seems to be the thing to use but I > wonder > if anyone has an implementation already - or a different approach to > function optimisation > > Chris > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
K
kitwallace
Sun, Apr 1, 2018 5:10 PM
Indeed so although its performance is not so good. There are a range of
algorithms implemented in other languages like scipy for Python and the gnu
C libraries. Code for any of these optimisation algorithms would be useful.
Looking around a bit more it looks like the downhill Simplex
https://en.wikipedia.org/wiki/Nelder%E2%80%93Mead_method looks quite good
and not too difficult to implement .  For a 2D function it needs 3 initial
points -  I'll give that a go.
Of course the problem with using such functions as you well know is the
inability to pass functions as parameters- I must checkout Curv!
Indeed so although its performance is not so good. There are a range of algorithms implemented in other languages like scipy for Python and the gnu C libraries. Code for any of these optimisation algorithms would be useful. Looking around a bit more it looks like the downhill Simplex https://en.wikipedia.org/wiki/Nelder%E2%80%93Mead_method looks quite good and not too difficult to implement . For a 2D function it needs 3 initial points - I'll give that a go. Of course the problem with using such functions as you well know is the inability to pass functions as parameters- I must checkout Curv! -- Sent from: http://forum.openscad.org/
K
kitwallace
Mon, Apr 2, 2018 7:07 AM
I implemented the simplex method as per
It's been tested on the Rosenbrock function (for degree 2 at least) and on
my own problem in geometry and convergence looks good.
https://github.com/KitWallace/openscad/blob/master/simplex-method.scad
I implemented the simplex method as per https://en.wikipedia.org/wiki/Nelder%E2%80%93Mead_method It's been tested on the Rosenbrock function (for degree 2 at least) and on my own problem in geometry and convergence looks good. https://github.com/KitWallace/openscad/blob/master/simplex-method.scad -- Sent from: http://forum.openscad.org/
