// Is it possible to combine the two lines marked part A and part B,
// into one object, module or whatever?
// If so, I'd appreciate an an example.
$fn=16;
cube([5,5,5], center=true);
#cylinder(d=1.5, h=12, center=true); // part A
cylinder(d=1, h=15, center=true); // part B
Thanks in advance
Leef_me
I'm not sure what you want to use the # for. Its normally only for
diagnostics.
How about this:
$fn=16;
wire(); // part A
wire();
module wire(){
color("red")cylinder(d=1.5, h=12, center=true); // part A
2015-11-30 21:12 GMT+01:00 Leef_me Leef_me@cox.net:
$fn=16;
Thanks in advance
Leef_me
Do you want to generate a pipe with those two lines A and B? Or am I missing
something...
I use this generic module to generate my tubes.
DefaultSides=90;
module Tube(Length,Dout,Din,Sides)
NSides= (Sides < 3 || Sides==undef) ? DefaultSides : Sides;
rotate_extrude(convexity=2, $fn=NSides) translate([Din/2,0,0])
square([(Dout-Din)/2,Length]);
Tube();
Regards
View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14845.html
The cube has a cylindrical hole cut vertically through it.
Inside this is a thinner rod.
They are not connected together in any place.
We can't work out what sort of object you are trying to make.
You could add a flattened cube at the bottom and thereby make a mold kind-of
object to perhaps pour goop into to make tubes, but not sure what this
object is trying to acheive so not sure how to answer your question.
View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14846.html
