At effectively zero notice, Nabble (the host of the OpenSCAD Forum) has removed support for
Mailing-lists.
This means:
a. Any posts on the Forum are just that, they do not get sent to, and hence seen by, Mailing-list
members.
b. New emails to the Mailing-list, no longer get posted to the Forum.
In the interim, I recommend you use the Mailing-list and do not post to the Forum.
Basically nobody will see your post unless they specifically go looking on the Forum.
If you are desperate to see messages via a Web page, use the Mailing-list Archive:
https://lists.openscad.org/empathy/list/discuss.lists.openscad.org
If you are also desperate to post new messages via a Web page you can also use the Archive,
but you will need to https://lists.openscad.org/register to create a password for the email address
that
you subscribed with, then you can logon to the Archive and post.
Note the editor there has limitations.
The longer term arrangements will be notified in due course.
Forum Admin
