On 2024-02-25 16:42, nop head wrote:
If you export an STL file from OpenSCAD then the vertices of triangles
that meet have exactly the same numerical value.
Read what I said "You can get away with 'feeling' as long as the
software(s) you are using all apply the same rules, but chances are they
are not exactly the same and hence you get many threads like this."
You are applying additional constraints that serves your purpose using
only one software, and that is fine. But what you claim is not generally
valid. As you explain, you still have some issues even with using only
OpenSCAD and you have to apply even more rules to get around it.
Even in your special case you would be better off using something else
than STL. But whatever.
On 2024-02-25 16:48, Chun Kit LAM via Discuss wrote:
The problem is that even if some vertices are distinct topologically,
they are considered the same if you look at their coordinates, e.g.
when two objects touch each other. And this can happen even if
OpenSCAD exports the exact numerical representation without any
truncation/rounding/snapping whatever.
That is a very good point. An additional argument why coordinate
matching is bad practice, leads to errors while at the same time
completely unnecessary given already existing alternatives.
On Mon, Feb 26, 2024, 12:50 AM Rogier Wolff via Discuss <
Binary STL by the way uses an array of vertices and indexes into the
vertex-array. So you could distinguis between different points in a
geometry that happen to have the same coordinates.
Do you have any reference to this? I don't see this on Wikipedia, nor from
the implementation of export_stl.cc in openscad.
vertex-array.
This is not correct. I have implemented binary STL.
OK. It seems I was wrong. Sorry.
I recently did the math: does this strategy save space in the file. It
100% guaranteed does! Apparently when this was designed they didn't
think this was important. (because they DID find it important, the binary
variant was designed...)
So, looking for a common denominator in my OpenSCAD->Chitubox:Basic
workflow, the only other alternative is .obj. I've just tried an
export/import, works just fine. Looking through the file definition in
Wikipedia, no mention of triangles rather, definition of polygons and
their constituent vertices. Am I making progress getting off .stl?
they are not exactly the same and hence you get many threads like this."
generally valid. As you explain, you still have some issues even with
using only OpenSCAD and you have to apply even more rules to get
around it.
