Please can someone explain to me what a degenerate facet actually is,
and why they arise? I ask because I have what I think is a simple
run-of-the-mill model and I was surprised when PrusaSlicer told me that
there are degenerate facets.
It's not a big deal because PrusaSlicer fixes them and I can print my
model, but it got me wondering about the root of the issue.
I'm using OpenSCAD version 2024.02.11 on Windows 10. My model's source
code is given below. By trial and error, I found that the number of
degenerate facets depends of the value of $fn, but that bit of
information hasn't actually helped me understand why these things arise.
Cheers,
Steve
$fn = 30;
rotate([13.65, 0, 0]) translate([0, 0, -12.5]) difference() {
hull() for(i = [18, -18], j = [18, -18]) translate([i, j, 0])
cylinder(r = 10, h = 20);
for(i = [20, -20], j = [20, -20]) translate([i, j, 0])
cylinder(r = 1.4, h = 60, center = true);
translate([0, -0.15, 0]) union() {
for(i = [0, 180]) rotate(i) translate([18, 0, 2]) cylinder(r =
4, h = 30);
for(i = [0, 180]) rotate(i) translate([18, 0, 0]) cylinder(r =
1.4, h = 30, center = true);
for(i = [90, 270]) rotate(i) translate([14, 0, 2]) cylinder(r
= 4, h = 30);
for(i = [90, 270]) rotate(i) translate([14, 0, 0]) cylinder(r
= 1.4, h = 30, center = true);
translate([0, 0, -50]) cube(100, center = true);
cube([0.4, 100, 2.1], center = true);
Hi Steve,
On Sun, Feb 18, 2024 at 05:57:38PM -0800, Steve Lelievre via Discuss wrote:
Please can someone explain to me what a degenerate facet actually is, and
It's not a big deal because PrusaSlicer fixes them and I can print my model,
I'm using OpenSCAD version 2024.02.11 on Windows 10. My model's source code
is given below. By trial and error, I found that the number of degenerate
facets depends of the value of $fn, but that bit of information hasn't
Here's the code that detects degenerate facets in Prusa Slicer:
// If any two of the three vertices are found to be exactally the same, call them degenerate and remove the facet.
// Do it before the next step, as the next step stores references to the face indices in the hash tables and removing a facet
// will break the references.
for (uint32_t i = 0; i < stl->stats.number_of_facets;) {
stl_facet &facet = stl->facet_start[i];
if (facet.vertex[0] == facet.vertex[1] || facet.vertex[1] == facet.vertex[2] || facet.vertex[0] == facet.vertex[2]) {
// Remove the degenerate facet.
facet = stl->facet_start[-- stl->stats.number_of_facets];
stl->facet_start.pop_back();
stl->neighbors_start.pop_back();
stl->stats.facets_removed += 1;
stl->stats.degenerate_facets += 1;
} else
++ i;
To summarize:
a facet in an STL is a triangle, so it should have three
vertices/points.
if two points in the "triangle" are identical, it's no longer a
triangle, hence it's "degenerate".
I'm not actually able to reproduce the degenerate facets issue that
you're facing from the code you attached on my machine (OpenSCAD
20240215 snapshot, Ubuntu 23.10), but I suspect that what's happening is
that you have small circles with too many facets in them ($fn too high
for a given radius), causing rounding errors to occur during the export,
resulting in STL triangles that are actually lines or single points.
Consider replacing $fn = 30; with $fs = 0.4; $fa = 1;, which would
give you a more even quality bump (large curves get more vertices, small
curves/circles get fewer vertices, so you no longer end up with points
too close to each other).
Kind regards,
Loong Jin
Thank you for your very clear, informative, and helpful explanation.
I followed your advice and, sure enough, there are no longer any
degenerate facets in the output.
Thank you!
Steve
On 2024-02-18 7:51 p.m., Chow Loong Jin wrote:
Hi Steve,
} else
++ i;
To summarize:
vertices/points.
On 2024-02-19 04:51, Chow Loong Jin via Discuss wrote:
That is one possibility, but not the only one. You can have a degenerate
triangle also without two points being identical. If the 3 triangle
points all lie on a straight line, the triangle is degenerate.
A triangle is degenerate if its area is zero.
triangle also without two points being identical. If the 3 triangle points
Ooh yeah, thanks for catching that. It doesn't look like the logic in
admesn (embedded in Prusa Slicer) does that check though.
Kind regards,
Loong Jin
I am confused. If it is as simple as not exporting triangles with zero
area, how is it that ANY STL exporter still creates degenerate facets?
Is this something we could add to STL export, trivially? What am I missing?
As long as there are no self intersections it isn't too hard to remove
degenerate triangles. It isn't trivial though because if you simply omit
them you have a hole in the mesh, so you have to fix that. Since they are
generated by collapsing vertices due to truncating accuracy you always have
the possibility of creating self intersections.
On Sat, 24 Feb 2024 at 22:41, jon via Discuss discuss@lists.openscad.org
missing?
Many CAD related software packages deal with what are called mathematical
"manifolds" (see: https://en.wikipedia.org/wiki/Manifold). Manifolds have
interesting properties like they are completely closed (sometimes called
"water tight"), and that every face either points outward, or inward (see:
https://www.youtube.com/watch?v=zGyfiOqiR4s and
https://cmichel.io/understanding-front-faces-winding-order-and-normals).
So, if you have a single triangle has a normal that points outwards, and
all the rest of them point inward, then it is ill formed or degenerate.
There are other potentially degenerate cases where two corners touch and
share an edge - mathematically you cannot tell if it is a single object or
two. It is likely that others will have more to say, but I hope that this
helps.
On Sat, Feb 24, 2024 at 5:41 PM jon via Discuss discuss@lists.openscad.org
missing?
omit them you have a hole in the mesh, so you have to fix that.
Removing a triangle with zero area does not leave a hole, because the
'hole' has zero area. If you are thinking topological hole, it doesn't
apply to STL files because they don't contain any topology in the first
place, STL files are 'triangle soups'. With other formats, such as OBJ,
it is a different matter, you could be left with a zero area topological
hole.
ITS Not that easy. Removing a Zero area Triangel might make the Solid
non-manifold. ...
Carsten Arnholm via Discuss discuss@lists.openscad.org schrieb am So.,
25. Feb. 2024, 09:56:
hole.
