Tool like OpenSCAD, but for 2D images?
arnholm@arnholm.org
Fri, Oct 20, 2017 1:19 PM
On 2017-10-20 14:31, shadowwynd wrote:
The issue has to do with OpenSCAD's top-level union, which is
automatically
applied.  This means it can do 3D well, 2.5D with limitations (great as
long
as the "D" are the same (e.g. a plate with holes and slots)), and is
very
poor at 2D.
OpenSCAD is a CSG (Constructive Solid Geometry) modeller for 2D or 3D.
It is not a line drawing program, neither in 2D nor 3D.
If you needed
three concentric circles for a drawing (with no filled areas) (such as
for a
graphic), you are out of luck.
In OpenSCAD, everything is a solid (in 2D or 3D). If what you want is a
line drawing tool, then OpenSCAD is the wrong choice.
On 2017-10-20 14:31, shadowwynd wrote: > The issue has to do with OpenSCAD's top-level union, which is > automatically > applied. This means it can do 3D well, 2.5D with limitations (great as > long > as the "D" are the same (e.g. a plate with holes and slots)), and is > very > poor at 2D. OpenSCAD is a CSG (Constructive Solid Geometry) modeller for 2D or 3D. It is not a line drawing program, neither in 2D nor 3D. > If you needed > three concentric circles for a drawing (with no filled areas) (such as > for a > graphic), you are out of luck. In OpenSCAD, everything is a solid (in 2D or 3D). If what you want is a line drawing tool, then OpenSCAD is the wrong choice. Carsten Arnholm
TO
Trevor Orr
Fri, Oct 20, 2017 3:47 PM
I have use this SVG JavaScript library on several projects.
http://snapsvg.io/
automatically
long
as the "D" are the same (e.g. a plate with holes and slots)), and is very
poor at 2D.
If you needed
for a
I have use this SVG JavaScript library on several projects. http://snapsvg.io/ On Fri, Oct 20, 2017 at 6:19 AM, <arnholm@arnholm.org> wrote: > On 2017-10-20 14:31, shadowwynd wrote: > >> The issue has to do with OpenSCAD's top-level union, which is >> automatically >> applied. This means it can do 3D well, 2.5D with limitations (great as >> long >> as the "D" are the same (e.g. a plate with holes and slots)), and is very >> poor at 2D. >> > > OpenSCAD is a CSG (Constructive Solid Geometry) modeller for 2D or 3D. It > is not a line drawing program, neither in 2D nor 3D. > > If you needed >> three concentric circles for a drawing (with no filled areas) (such as >> for a >> graphic), you are out of luck. >> > > In OpenSCAD, everything is a solid (in 2D or 3D). If what you want is a > line drawing tool, then OpenSCAD is the wrong choice. > > Carsten Arnholm > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
ashuan
Fri, Oct 20, 2017 3:57 PM
Perhaps you could use D3.js library.
It's graph oriented but there's many other kind of example :
https://github.com/d3/d3/wiki/Gallery
It's use SVG model.
Perhaps you could use D3.js library. It's graph oriented but there's many other kind of example : https://github.com/d3/d3/wiki/Gallery It's use SVG model. -- Sent from: http://forum.openscad.org/
CS
Colin Smart
Fri, Oct 20, 2017 7:48 PM
Or consider using a programmatic 2D tool such as Processing...
https://en.m.wikipedia.org/wiki/Processing_(programming_language)
Colin Smart (07968 049660)
On 20 Oct 2017, at 12:07, Troberg troberg.anders@gmail.com wrote:
I'd say that what I'm looking for is something like "script controlled
PaintShop", much like one could say that OpenSCAD is a "script controlled
SketchUp" (and don't nitpick that definition, I'm just trying to get a
general idea across here...).
Or consider using a programmatic 2D tool such as Processing... https://en.m.wikipedia.org/wiki/Processing_(programming_language) --------------------------------- Colin Smart (07968 049660) On 20 Oct 2017, at 12:07, Troberg <troberg.anders@gmail.com> wrote: I'd say that what I'm looking for is something like "script controlled PaintShop", much like one could say that OpenSCAD is a "script controlled SketchUp" (and don't nitpick that definition, I'm just trying to get a general idea across here...). -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
moshel
Sat, Oct 21, 2017 3:48 AM
Processing looks promising! I'll give it a try. Thanks!
Processing looks promising! I'll give it a try. Thanks! -- Sent from: http://forum.openscad.org/
mbugert
Sun, Oct 22, 2017 7:26 AM
moshel wrote > Processing looks promising! I'll give it a try. Thanks! I recently wrote a library which could help for your problem. It's about lasercutting stuff with OpenSCAD, see http://forum.openscad.org/laserscad-A-library-for-efficient-lasercutting-with-OpenSCAD-td22429.html <http://forum.openscad.org/laserscad-A-library-for-efficient-lasercutting-with-OpenSCAD-td22429.html> ). Cheers, mbugert -- Sent from: http://forum.openscad.org/
TLC123
Mon, Oct 23, 2017 2:05 PM
ImageMagick can do scripting for 2d bitmaps
ImageMagick can do scripting for 2d bitmaps -- Sent from: http://forum.openscad.org/
Troberg
Mon, Oct 23, 2017 3:14 PM
Imagemagick is good for some types of processing, but not for creating images
from scratch.
I'm looking for a tool where I can script things like this:
Start with a blank bitmap. Load another bitmap from disk. Draw a circle on
it, then invert what's in the circle. Paint the modified bitmap in several
positions on the screen. Draw a border of evenly spaced circles. Load a logo
bitmap from disk and put in the corner. Add some text in a new layer, set to
semitransparent and add to the main picture as a water mark. Convert the
result to greyscale.
Basically, a combined bitmap and vector tool, like a bunch of paint programs
out there, but with the mindset of OpenSCAD, where everything is scripted
and there is no GUI for drawing. Basically, scripted drawing for engineers.
Imagemagick is good for some types of processing, but not for creating images from scratch. I'm looking for a tool where I can script things like this: Start with a blank bitmap. Load another bitmap from disk. Draw a circle on it, then invert what's in the circle. Paint the modified bitmap in several positions on the screen. Draw a border of evenly spaced circles. Load a logo bitmap from disk and put in the corner. Add some text in a new layer, set to semitransparent and add to the main picture as a water mark. Convert the result to greyscale. Basically, a combined bitmap and vector tool, like a bunch of paint programs out there, but with the mindset of OpenSCAD, where everything is scripted and there is no GUI for drawing. Basically, scripted drawing for engineers. -- Sent from: http://forum.openscad.org/
TLC123
Mon, Oct 23, 2017 8:29 PM
Guess one can do most of that with a hand coded svg with embedded bitmaps and
possibly even scriptable canvas tag.
Guess one can do most of that with a hand coded svg with embedded bitmaps and possibly even scriptable canvas tag. -- Sent from: http://forum.openscad.org/
Tue, Oct 24, 2017 1:12 AM
There’s always maker.js: https://maker.js.org/
There’s always maker.js: https://maker.js.org/ -Marius
