OpenSCAD doesn't have the "project" thinking of typical dev environments,
it's just one file (and possible includes).
This is fine and keeps things clean, but a typical project still has a bunch
or related files. Photos, drawings, spreadsheets with measurements,
todo-lists and so on.
A very simple way to keep all this neat and organized would be to let the
editor parse links in comments, and open them when clicked (probably through
a context menu).
So, for example, these comments would be a clickable links:
//file://x:\proj\myproj\todo.txt
//file://x:\proj\myproj\oldpartphoto.jpg
//http://www.somesite.com/specs.html
When clicked, simply use whatever program the user has associated with the
content type, which, in all OS's I've tried, is a simple API call.
If it would make parsing easier, it's OK to add some extra syntax, such as,
for example:
//relatedfile<file://x:\proj\myproj\todo.txt)
I would find this immensely useful when things start getting big and
complicated.
I have implemented that in my python framework. Comments that start with
//! get extracted and put in the readme.md markdown document that gets
rendered to HTML. So links and pictures work and any other markdown syntax.
bunch
through
a context menu).
for example:
complicated.
syntax.
Hmm, I already do something like that, though I don't render it in HTML, and
I only use it to generate documentation for my parts libraries. I might
adapt that code...
Still, it would be nice to have it directly in the code editor. OpenSCAD
tends to become cumbersome when projects become large and complicated, as
I'm sure you've noticed, given the stuff you do.
I don't use the internal editor for my projects. I only use it for code
snippets appearing on this mailing list, or perhaps to locate a syntax
error when I am being dense.
syntax.
and
adapt that code...
Good point. Maybe this can all be solved by using an external IDE. Perhaps,
say, Eclipse could be cusomized for the purpose...
