$vpr not set in command line mode
Wed, May 22, 2019 10:15 PM
I made some text face the camera with rotate($vpr) but it only works in the
GUI. $vpr seems to be [0, 0, 0] when run from the command line. Any reason
why this shouldn't be set from the camera in command line mode?
I made some text face the camera with rotate($vpr) but it only works in the GUI. $vpr seems to be [0, 0, 0] when run from the command line. Any reason why this shouldn't be set from the camera in command line mode?
Sat, May 25, 2019 11:05 PM
Sounds like a bug to me.
Sounds like a bug to me. ----- Admin - email* me if you need anything, or if I've done something stupid... * click on my MichaelAtOz label, there is a link to email me. Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- Sent from: http://forum.openscad.org/
Sat, May 25, 2019 11:17 PM
It's not a bug, it simply was never intended to be
used in command line mode. In addition there were ways
to define the camera position on command line which did
not easily translate into those variables.
That might have changed now with the camera code updates.
So if we can calculate the values for all combinations
that are possible via command line, it makes sense to
add that feature.
On 26.05.19 01:05, MichaelAtOz wrote: > Sounds like a bug to me. It's not a bug, it simply was never intended to be used in command line mode. In addition there were ways to define the camera position on command line which did not easily translate into those variables. That might have changed now with the camera code updates. So if we can calculate the values for all combinations that are possible via command line, it makes sense to add that feature. ciao, Torsten.
