I have some Java code that reads an STL and outputs it as text to include
in a .SCAD file, if that would be useful to anyone.
On Thu, Mar 4, 2021 at 10:02 AM Jordan Brown openscad@jordan.maileater.net
On 3/3/2021 8:41 AM, Torsten Paul wrote:
On 03.03.21 17:32, Jordan Brown wrote:
I'd say the language design is neutral on such a concept.
Yes, it has nothing at all to do with the language.
Also considering there are already functions that do such
a thing, I'm not sure how that is even controversial.
Which functions are you thinking of? I don't see any functions on the
cheat sheet that read files. There are modules, but that's a little
different.
For STL, the data returned would necessarily be triangle
soup, because that's what STL contains.
I don't think that would be acceptable. The return data
structure should be the same for all the file formats (well,
maybe one for 2d and one for 3d, but not different for STL
vs. OBJ).
If one file format includes connectivity information and another doesn't,
it's hard to see how the two can be represented the same.
Perhaps the data returned for OBJ would be a superset of the data returned
for STL, with a triangle soup plus connectivity data.
That suggests that the returned structures should be designed for
extensibility. The "object" mechanism would be helpful there.
polyhedron() could error just in F6 or render(). That is when it matters
and would stop the endless list of why does my STL preview but not render?
On Thu, 4 Mar 2021 at 03:49, Frank van der Hulst drifter.frank@gmail.com
On Thu, Mar 4, 2021 at 10:02 AM Jordan Brown <
different.
vs. OBJ).
returned for STL, with a triangle soup plus connectivity data.
