Bump - so it goes to the mailing list.
View this message in context: http://forum.openscad.org/Creating-screw-threads-tp10306p10336.html
Try this. It's simplistic, but you should be able to adjust it to do what you're
looking for.
linear_extrude(h=20, twist=20*90)
union()
circle(r=15);
polygon([[30,0],[7.5813,13],[7.5813,-13]]);
polygon([[-30,0],[-7.5813,13],[-7.5813,-13]]);
you're looking for.
union()
circle(r=15);
If you can plot out a polygon of the thread profile for the entire length of
rotation in a circular form, you can then linear_extrude it with a certain
amount of twist and height in order to get your screw.
Basically, take a thread profile, plot it on graph paper on an X/Y axis, and
change the X/Y labels to angle/radius, and you've gotten a proper cross-section
for your thread.
I implemented this in https://github.com/openscad/MCAD, in fasteners/thread.scad
in the dev branch.
Kind regards,
Loong Jin
for your thread.
in the dev branch.
https://github.com/openscad/MCAD/blob/dev/fasteners/threads.scad#L147 for a
generic trapezoidal thread that can generate buttress, acme, and metric threads.
Doing a tapered thread this way is beyond me, though. I'm thinking of replacing
this approach with the sweep() module from the list comprehension demos, which
would be cleaner and simpler to implement.
Kind regards,
Loong Jin
