Hello,
I was wondering if there is a way in OpenSCAD to get the projection volume
of a shape.
Let's say I have an imported mesh, I want the volume generated by projecting
it onto a plane (xy in my case). Thanks!
View this message in context: http://forum.openscad.org/Projection-volume-tp19885.html
You cannot measure the volume in OpenSCAD, but you can create the shape like this:
module MyShape() translate([0,0,30]) sphere(20);
hull() {
MyShape();
linear_extrude(height=1) projection() MyShape();
On Jan 3, 2017, at 08:58, emmanueliarussi emmanueliarussi@gmail.com wrote:
Hello,
of a shape.
Right, that's the way I'm doing it now, but only works for convex shapes (as
the sphere). Otherwise, the hull() destroys the non-convexities and holes in
the original shape. I was looking for a more general solution.
View this message in context: http://forum.openscad.org/Projection-volume-tp19885p19887.html
A very slow solution that works with non-convex shapes is:
module MyShape() { translate([0,0,30]) sphere(20); translate([0,15,20])
sphere(20); }
minkowski() {
MyShape();
translate([0,0,-100]) cylinder(d=0.001,h=100);
translate([0,0,50]) cube([100,100,100],center=true);
2017-01-03 12:52 GMT-02:00 emmanueliarussi emmanueliarussi@gmail.com:
(as
in
tp19885p19887.html
That did the trick. Thanks a lot Ronaldo! I'll now try to run my code in a
faster computer.
sphere(20); }
minkowski() {
MyShape();
2017-01-03 12:52 GMT-02:00 emmanueliarussi <
emmanueliarussi@
(as
in
tp19885p19887.html
Discuss@.openscad
Discuss@.openscad
View this message in context: http://forum.openscad.org/Projection-volume-tp19885p19891.html
Just another good reason for generalizing the implementation of
linear_extrude() to operate over 3D-objects. We had some discussion about
this, see
http://forum.openscad.org/Non-Linear-Transformations-tp14539p16673.html
View this message in context: http://forum.openscad.org/Projection-volume-tp19885p19892.html
I think this gives the correct result in a timely manner:
sphere(20); }
eps = 1/80;
inf = 100;
hull() {
MyShape();
linear_extrude(height = eps, convexity = 2)
projection()
MyShape();
linear_extrude(height = inf, convexity = 2)
projection()
MyShape();
this, see
tp19885p19892.html
Or perhaps not, sorry!
sphere(20); }
eps = 1/80;
inf = 100;
hull() {
MyShape();
projection()
MyShape();
projection()
MyShape();
this, see
this, see
Or a good reason to generalize minkowski to accept 1D and 2D objects as well
defined in mathematics. The minkowski of a line segment and a solid is much
easier to compute.
View this message in context: http://forum.openscad.org/Projection-volume-tp19885p19895.html
well defined in mathematics. The minkowski of a line segment and a solid
is much easier to compute.
This would mean to include 1D objects into OpenSCAD first and
redefine/expand/reimplement all operations and so on, as already discussed.
A lot of work.
BTW, letting scale and twist aside linear_extrude() IS a minkowski_z()
operator. While it is easy to implement for 2D objects, implementing it on
general 3D objects can get nasty.
View this message in context: http://forum.openscad.org/Projection-volume-tp19885p19906.html
