I've been using RC6 for a while now and have noticed that when I open an
.SCAD file and try to edit it sometimes my keystrokes don't do anything.
I can position the cursor but if I hit delete (say) nothing happens,
same goes for alpha-numeric key strokes.
If I keep trying, eventually it works.
It is almost as though the file is read only (it isn't - I have checked).
The files are on a remote file server if that makes any difference.
I don't recall this happening on previous releases.
Dave
I am also seeing this with version 2021.01 under 64bit Win 7 ...
I now suspect that its not a "read only" issue but the program looses access to the keyboard, I can move the cursor to change the edit point but the keyboard is not active (not even the cursor keys).
A bit further investigation seems to indicate that performing a render fixes the problem.
I have one particular project file where this happens every time I do a preview and the only way out is to perform a render.
I can let you have the sources if it would help.
Regards,
Dave
On 30/01/2021 08:11, Dave wrote:
<pre class="moz-quote-pre" wrap="">I've been using RC6 for a while now and have noticed that when I open an .SCAD file and try to edit it sometimes my keystrokes don't do anything. I can position the cursor but if I hit delete (say) nothing happens, same goes for alpha-numeric key strokes. If I keep trying, eventually it works. It is almost as though the file is read only (it isn't - I have checked). The files are on a remote file server if that makes any difference. I don't recall this happening on previous releases. Dave _______________________________________________ OpenSCAD mailing list <a class="moz-txt-link-abbreviated" href="mailto:Discuss@lists.openscad.org">Discuss@lists.openscad.org</a> <a class="moz-txt-link-freetext" href="http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org">http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org</a>
Moving the cursor, presumably by mouse click into source?
How do you initiate the render, menus/icon-button/F6?
How do you initiate the preview, menus/icon-button/F5?
Just keeping typing? It just starts to work?
What if you pause for the same amount of time (plus a bit) then hit a key?
i.e. is it just busy doing something, then gets caught up?
Does it happen if you copy them locally?
zip it.
