here's my code I wanted to make the code parametric so I needed
various possible values but I hit a snag.
bearings=10;
//for smooth rods put in diameter in mm
smooth=10;
// for z-screw 5 for 5mm 8 for 8mm and 8.5 for acme
z_screw=5;
// for mechanical z=probe use 1 for yes 0 for no 2 for i3 type probe
z_probe = 1;
wall=4;
lmd=1;
lml=1;
echo(bearings,smooth,z_screw);
if (bearings==10){lmd=19.05;lml=29.05;}
echo(lmd,lml);
lmd and lml return 1 even though I thought I was assigning the actual
values with the if statement.
Respectfully,
R. Daniel Borkan
727 S. Coronado St. 201
Los Angeles, CA 90057
C: (213) 271-6721
All written content of this e-mail is confidential and only intended for
the named recipient. This message is subject to copyright and is
intellectual property of the sender. All rights reserved (c) 2018
bearings=10;
smooth=10;
z_screw=5;
z_probe = 1;
wall=4;
lmd=1;
lml=1;
echo(lmd,lml);
This might well be the most common OpenSCAD question.
OpenSCAD variables... aren't variables. They're constants, sort of,
with the last assignment winning and with inner scopes able to override
values from outer scopes. You can't change them, or at least not
exactly, and you especially can't change them inside an "if".
x=1;
echo(x=x);
x=2;
echo(x=x);
produces
ECHO: x = 2
ECHO: x = 2
and
x=1;
echo(x=x);
if (true) {
x=2;
echo (x=x);
echo (x=x);
produces
ECHO: x = 1
ECHO: x = 2
ECHO: x = 1
For your case here, you need to use the ?: operator to set the right
value when you do the initial assignment.
lmd= bearings==10 ? 19.05 : 1;
lml= bearings==10 ? 29.05 : 1;
echo(lmd,lml);
