Node editing systems for 3D and drawing
W
WillAdams
Sun, Oct 27, 2019 11:01 AM
My thanks to Doug Moen for pointing out Blender's node functionality which I
was not previously aware of.
To ensure that my ignorance becomes less, I would appreciate anything which
folks could share to expand/correct the following:
  • Rhino has an optional node system, Grasshopper which affords full control
    of models?
  • Blender --- in addition to the native node system (for materials only?)
    there is an add-on modeled on Grasshopper:
    http://nikitron.cc.ua/sverchok_en.html
For OpenSCAD and similar tools there is:
  • OpenJSCAD --- version of this in the Microsoft Store, also available on
    the web
  • BlockSCAD
  • https://github.com/studiotc/NodeGraphInterface
  • clikscad
  • Antimony/Kokopelli --- I wish this ran on Windows --- I may break down
    and get a Mac at some point, or find time to set up a Linux box, but it's
    unfortunate that access to it is so limited
For 2D similar tools include:
  • Processing --- programming based on JavaScript --- its use for
    CNC/CAD/CAM is described in the book Make: Design for CNC Furniture
    Projects and Fabrication Technique
  • Nodebox --- elegant programmatic 2D drawing with nodes --- unfortunately,
    units in graphics (PDFs or SVGs) are rounded off, so only suited to
    decorative use, or use with single-piece projects (a sundial has been done)
CAM-specific tools include:
  • Maker.JS --- a Microsoft Garage project extending node.js for making
    things
  • Tool Path Language --- an opensource extension of JavaScript to create
    G-Code for directly controlling machines
Is there anything else which I've missed? I'd welcome any additions or
corrections. It's all going on:
For my part, things I'd like to see:
OpenSCAD support for drawing in 2D --- I'm currently re-creating projects in
METAPOST using lualatex:
https://wiki.shapeoko.com/index.php/Design_into_3D:_box:_fitted and
https://github.com/WillAdams/Design_Into_3D/tree/master/box/fitted --- maybe
there's a better way to do this? I was successful with modeling a Chinese
Checkers board and projecting it into 2D so as to export a DXF:
https://community.carbide3d.com/t/design-into-3d-games-chinese-checkers/16056
My thanks to Doug Moen for pointing out Blender's node functionality which I was not previously aware of. To ensure that my ignorance becomes less, I would appreciate anything which folks could share to expand/correct the following: - Rhino has an optional node system, Grasshopper which affords full control of models? - Blender --- in addition to the native node system (for materials only?) there is an add-on modeled on Grasshopper: http://nikitron.cc.ua/sverchok_en.html For OpenSCAD and similar tools there is: - OpenJSCAD --- version of this in the Microsoft Store, also available on the web - BlockSCAD - https://github.com/studiotc/NodeGraphInterface - clikscad - Antimony/Kokopelli --- I wish this ran on Windows --- I may break down and get a Mac at some point, or find time to set up a Linux box, but it's unfortunate that access to it is so limited For 2D similar tools include: - Processing --- programming based on JavaScript --- its use for CNC/CAD/CAM is described in the book _Make: Design for CNC Furniture Projects and Fabrication Technique_ - Nodebox --- elegant programmatic 2D drawing with nodes --- unfortunately, units in graphics (PDFs or SVGs) are rounded off, so only suited to decorative use, or use with single-piece projects (a sundial has been done) CAM-specific tools include: - Maker.JS --- a Microsoft Garage project extending node.js for making things - Tool Path Language --- an opensource extension of JavaScript to create G-Code for directly controlling machines Is there anything else which I've missed? I'd welcome any additions or corrections. It's all going on: - https://wiki.shapeoko.com/index.php/OpenSCAD - https://wiki.shapeoko.com/index.php/CAD - https://wiki.shapeoko.com/index.php/Programming For my part, things I'd like to see: - BlockSCAD available as an alternate interface in OpenSCAD: https://github.com/openscad/openscad/issues/3108 - BlockSCAD support for the Customizer: https://github.com/EinsteinsWorkshop/BlocksCAD/issues/48 - a formal technique/site for placing OpenSCAD projects online which isn't Thingiverse OpenSCAD support for drawing in 2D --- I'm currently re-creating projects in METAPOST using lualatex: https://wiki.shapeoko.com/index.php/Design_into_3D:_box:_fitted and https://github.com/WillAdams/Design_Into_3D/tree/master/box/fitted --- maybe there's a better way to do this? I was successful with modeling a Chinese Checkers board and projecting it into 2D so as to export a DXF: https://community.carbide3d.com/t/design-into-3d-games-chinese-checkers/16056 William -- Sent from: http://forum.openscad.org/
W
WillAdams
Sun, Oct 27, 2019 11:34 AM
And it turns out I missed a node editor for FreeCAD:
https://forum.freecadweb.org/viewtopic.php?t=36299
And it turns out I missed a node editor for FreeCAD: https://forum.freecadweb.org/viewtopic.php?t=36299 -- Sent from: http://forum.openscad.org/
Robin2
Sun, Oct 27, 2019 2:44 PM
Forgive my ignorance but what is a "Node editing system" and in what context
is it relevant to OpenSCAD ?
...R
Forgive my ignorance but what is a "Node editing system" and in what context is it relevant to OpenSCAD ? ...R -- Sent from: http://forum.openscad.org/
W
WillAdams
Sun, Oct 27, 2019 3:09 PM
It's the description of connected block diagramming/programming tools --- the
discussion of your program spurred the mention of Blender having such an
interface, and I'd like to fill in any gaps on such systems.
Is there some other terminology you feel would be better, or which you would
prefer for describing Clikscad?
It's the description of connected block diagramming/programming tools --- the discussion of your program spurred the mention of Blender having such an interface, and I'd like to fill in any gaps on such systems. Is there some other terminology you feel would be better, or which you would prefer for describing Clikscad? William -- Sent from: http://forum.openscad.org/
Sun, Oct 27, 2019 5:11 PM
On 27.10.19 12:01, WillAdams via Discuss wrote:
That repo seems to be dead for 3 years.
On 27.10.19 12:01, WillAdams via Discuss wrote: > - BlockSCAD support for the Customizer: > https://github.com/EinsteinsWorkshop/BlocksCAD/issues/48 That repo seems to be dead for 3 years. ciao, Torsten.
Robin2
Sun, Oct 27, 2019 5:50 PM
would
The word "node" conjured up in my mind the point where two sides of a
polygon intersect so I thought you were referring to something that would
make it easy to create or edit a polygon or its 3D equivalent.
I don't really have any suggestion for the terminology.
I use the word "element" to describe the parts in one of my ClikScad models.
An element could be a cube, a sphere, a difference, a module etc.  When
ClikScad creates the OpenSCAD code every one of those will be in an OpenSCAD
module as that seemed to me the simplest way for my Python code to do
things.
...R
OpenSCAD mailing list-2 wrote > It's the description of connected block diagramming/programming tools --- > the > discussion of your program spurred the mention of Blender having such an > interface, and I'd like to fill in any gaps on such systems. > > Is there some other terminology you feel would be better, or which you > would > prefer for describing Clikscad? The word "node" conjured up in my mind the point where two sides of a polygon intersect so I thought you were referring to something that would make it easy to create or edit a polygon or its 3D equivalent. I don't really have any suggestion for the terminology. I use the word "element" to describe the parts in one of my ClikScad models. An element could be a cube, a sphere, a difference, a module etc. When ClikScad creates the OpenSCAD code every one of those will be in an OpenSCAD module as that seemed to me the simplest way for my Python code to do things. ...R -- Sent from: http://forum.openscad.org/
Doug Moen
Sun, Oct 27, 2019 10:17 PM
Instead of "Node editing system", I would suggest the more general term "Visual programming language".
https://en.wikipedia.org/wiki/Visual_programming_language
There is a (very incomplete) list of visual programming languages in that Wikipedia article.
For example, Sketch-n-sketch belongs in your list: it is a programming language for generating SVG models, which also lets you edit your source code by direct manipulation of the SVG model that is produced as the output. But, it isn't a node-editing system. The authors call it a "direct manipulation programming system", but I think it belongs in the category of visual programming languages.
https://ravichugh.github.io/sketch-n-sketch/
Instead of "Node editing system", I would suggest the more general term "Visual programming language". https://en.wikipedia.org/wiki/Visual_programming_language There is a (very incomplete) list of visual programming languages in that Wikipedia article. For example, Sketch-n-sketch belongs in your list: it is a programming language for generating SVG models, which also lets you edit your source code by direct manipulation of the SVG model that is produced as the output. But, it isn't a node-editing system. The authors call it a "direct manipulation programming system", but I think it belongs in the category of visual programming languages. https://ravichugh.github.io/sketch-n-sketch/
WF
William F. Adams
Sun, Oct 27, 2019 10:50 PM
Thanks! That one is new to me and looks quite promising. Adding and looking into it now.
Doug Moen <doug@moens.org> wrote: >Instead of "Node editing system", I would suggest the more general term "Visual programming language". https://en.wikipedia.org/wiki/Visual_programming_language Agreed. >.... For example, Sketch-n-sketch belongs in your list: it is a programming language for generating SVG models, which also lets you edit your source code by direct manipulation of the SVG model that is produced as the output. But, it isn't a node-editing system. The authors call it a "direct manipulation programming system", but I think it belongs in the category of visual programming languages. https://ravichugh.github.io/sketch-n-sketch/ Thanks! That one is new to me and looks quite promising. Adding and looking into it now. William _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
HJ
Hugo Jackson
Sun, Oct 27, 2019 11:09 PM
I've been working with OpenSCAD for a couple of years now, and while frustrating I appreciate problematic nature of the inherent
limitations, like being unable to interrogate values.
I have been playing around with ways in which the basic syntax might be extended that would provide more
flexibility and power in creating 3D models. I'm no computer language expert, but I think the extensions
I propose would ease a lot of frustrations with some of the inherent limitations of the language without
breaking any of the rules.
To start, I would propose an extension of the "dot" notation, that would allow one to refer to a value declaration and/or
function or module component of another module with a dot.
e.g.
module foo() {
valueA = 7;
valueB = 3;
function myFunc(num) = valueA + num;
cube([valueA, valueB, valueB]);
module bar() {
valueB = 8;
valueC = foo.valueA + foo.myFunc(valueB); // use the myFunc function of foo to calculate valueC
cube([valueA, valueB, valueC])
foo();
Scoping rules would remain as they are, in that value declarations would be at the scope of the called module or module part. i.e. for the
above example the cube created in module bar, valueB would = 8 but it would be 3 in foo.
The second extension would be the election of three operations as 'reserved' functions, union, difference and intersection such that one
could explicitly call that part of a module without calling the others:
module foo() {
valueA = 7;
intersection : {
	cylinder(d = 7, h = 4);
difference : {
	cube([8,3,2]);
union : {
	translate([9,3,3])
		cube([3,1,1]);
module bar() {
valueG = foo.valueA;
foo.union(); // would only execute foo.union;
foo(); // would execute intersection(){difference(){union(){<union code>}<difference code>}<intersection code>}
One could select the execution of nested module definitions in another module as well… not just the ‘reserved’ functions.
This would allow for a tighter coupling of a module's attributes to it's basic geometry. Simplistically, say one wants a walled cylinder but it will
this part would have differing bases depending on where the cylinder was used in a design. As it stands, one would need to either create
cumbersome code for the cylinder base to avoid the base cylinder definition to avoid 'filling' up the cylinder where the base was, or decouple
the difference operation from the declaration of the cylinder so it will clear out any of the base geometry that is placed in the
way of the shaft.
These two extensions of the syntax would also allow for comparatively effortless calculation of boundary regions where desired without
creating a performance penalty where it is not needed and provide for pseudo polling of an objects characteristics without actually
requiring access to unreachable object values.
I hope that what I see as a manifold increase in the expressive power and abstraction in creating openSCAD programs with these
suggestions for an extended syntax or self-evident... and I'd be interested in what the rest of you might think. If what I’m suggesting is unclear
Please let me know… I didn’t want to bog this proposal down with details if it’s obvious, but in doing that I have taken the risk that the improvement
And benefits of such extensions may not be evident.
I've been working with OpenSCAD for a couple of years now, and while frustrating I appreciate problematic nature of the inherent limitations, like being unable to interrogate values. I have been playing around with ways in which the basic syntax might be extended that would provide more flexibility and power in creating 3D models. I'm no computer language expert, but I think the extensions I propose would ease a lot of frustrations with some of the inherent limitations of the language without breaking any of the rules. To start, I would propose an extension of the "dot" notation, that would allow one to refer to a value declaration and/or function or module component of another module with a dot. e.g. module foo() { valueA = 7; valueB = 3; function myFunc(num) = valueA + num; cube([valueA, valueB, valueB]); } module bar() { valueB = 8; valueC = foo.valueA + foo.myFunc(valueB); // use the myFunc function of foo to calculate valueC cube([valueA, valueB, valueC]) foo(); } Scoping rules would remain as they are, in that value declarations would be at the scope of the called module or module part. i.e. for the above example the cube created in module bar, valueB would = 8 but it would be 3 in foo. The second extension would be the election of three operations as 'reserved' functions, union, difference and intersection such that one could explicitly call that part of a module without calling the others: module foo() { valueA = 7; intersection : { cylinder(d = 7, h = 4); } difference : { cube([8,3,2]); } union : { translate([9,3,3]) cube([3,1,1]); } } module bar() { valueG = foo.valueA; foo.union(); // would only execute foo.union; foo(); // would execute intersection(){difference(){union(){<union code>}<difference code>}<intersection code>} } One could select the execution of nested module definitions in another module as well… not just the ‘reserved’ functions. This would allow for a tighter coupling of a module's attributes to it's basic geometry. Simplistically, say one wants a walled cylinder but it will this part would have differing bases depending on where the cylinder was used in a design. As it stands, one would need to either create cumbersome code for the cylinder base to avoid the base cylinder definition to avoid 'filling' up the cylinder where the base was, or decouple the difference operation from the declaration of the cylinder so it will clear out any of the base geometry that is placed in the way of the shaft. These two extensions of the syntax would also allow for comparatively effortless calculation of boundary regions where desired without creating a performance penalty where it is not needed and provide for pseudo polling of an objects characteristics without actually requiring access to unreachable object values. I hope that what I see as a manifold increase in the expressive power and abstraction in creating openSCAD programs with these suggestions for an extended syntax or self-evident... and I'd be interested in what the rest of you might think. If what I’m suggesting is unclear Please let me know… I didn’t want to bog this proposal down with details if it’s obvious, but in doing that I have taken the risk that the improvement And benefits of such extensions may not be evident.
Mon, Oct 28, 2019 12:13 AM
First note that the function literals are now
implemented, so the snapshot version of OpenSCAD
has functions as first class values which means
support for higher order functions.
(https://github.com/openscad/openscad/pull/3077)
I hope to find some time to collect notes and post
an article about it. Meanwhile the minimalist docu
can be found at
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Function_Literals
Yes, having access to a nested data structure is
definitely something that would help a lot. The
core changes to the parser implementation that are
required for this are now done and merged to the
development snapshot.
But I don't think it will be possible to link to
the existing function and/or module definitions.
Slightly modified example, just adding a parameter
to module foo():
module foo(offset) {
valueA = 7 + offset;
module bar() {
valueB = 8;
foo(10);
translate([10, 10, 0]) foo(20);
bar(); // <- now what is valueC ?
I'm not sure I understand how this will work. Why
select specifically those 3 special cases?
Is that meant just as names or would that also mean
intersection() { bar(); foo(); } a bit like operator
overloading?
Where's the nesting coming from? From the order of
the definitions?
Yes, more details are always good in that discussion.
See also https://github.com/openscad/openscad/pull/3087
which is implementing a similar proposal mostly as
reference for discussion.
More discussion can be found in
https://github.com/openscad/openscad/issues/3088
It would be great if we can find a definition that
works nicely as addition without breaking existing
scripts.
First note that the function literals are now implemented, so the snapshot version of OpenSCAD has functions as first class values which means support for higher order functions. (https://github.com/openscad/openscad/pull/3077) I hope to find some time to collect notes and post an article about it. Meanwhile the minimalist docu can be found at https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/User-Defined_Functions_and_Modules#Function_Literals On 28.10.19 00:09, Hugo Jackson wrote: > To start, I would propose an extension of the "dot" > notation, that would allow one to refer to a value > declaration and/or function or module component of > another module with a dot. Yes, having access to a nested data structure is definitely something that would help a lot. The core changes to the parser implementation that are required for this are now done and merged to the development snapshot. But I don't think it will be possible to link to the existing function and/or module definitions. Slightly modified example, just adding a parameter to module foo(): module foo(offset) { valueA = 7 + offset; function myFunc(num) = valueA + num; } module bar() { valueB = 8; valueC = foo.valueA + foo.myFunc(valueB); } foo(10); translate([10, 10, 0]) foo(20); bar(); // <- now what is valueC ? > The second extension would be the election of three > operations as 'reserved' functions, union, difference > and intersection such that one could explicitly call > that part of a module without calling the others: I'm not sure I understand how this will work. Why select specifically those 3 special cases? Is that meant just as names or would that also mean intersection() { bar(); foo(); } a bit like operator overloading? > foo(); // would execute intersection(){difference(){union(){<union code>}<difference code>}<intersection code>} Where's the nesting coming from? From the order of the definitions? > Please let me know… I didn’t want to bog this > proposal down with details if it’s obvious, but in > doing that I have taken the risk that the improvement > And benefits of such extensions may not be evident. Yes, more details are always good in that discussion. See also https://github.com/openscad/openscad/pull/3087 which is implementing a similar proposal mostly as reference for discussion. More discussion can be found in https://github.com/openscad/openscad/issues/3088 It would be great if we can find a definition that works nicely as addition without breaking existing scripts. ciao, Torsten.
