Making parametric curves is fairly easy in OpenSCAD now that it supports list
comprehesions and concatenation:
http://forum.openscad.org/file/n15743/parametric_spiral.png
View this message in context: http://forum.openscad.org/2dgraph-equation-based-2-D-shapes-in-openSCAD-tp15722p15743.html
What does the code to create the spiral look like?
Carsten, have a look at this github repo:
https://github.com/openscad/list-comprehension-demos
At the bottom is a 2d sprial example.
On Mon, Jan 18, 2016 at 11:36 AM, Carsten Arnholm arnholm@arnholm.org
list
Interesting, I normally view this mailing list through my gmail account.
David Eccles' post does not show any code here. However I just viewed this
thread through nabble, and there is openscad code in his post.
Any ideas why the mailing list cuts that out?
list
I believe that the code uses <raw> tag, which will not be sent to
mailing list.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
offline doc ( git ),
runscad.py( 1 , 2 , git ),
synwrite( 1 , 2 );
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision( 1 , 2 ),
xl-control
View this message in context: http://forum.openscad.org/2dgraph-equation-based-2-D-shapes-in-openSCAD-tp15722p15756.html
If you use the < code > tags (under More button), that gets cut by nabble, a
supposed security feature I think.
Best to use < quote > ...code... < / quote >, that gets thru.
DO NOT CLICK the Quote button, that will insert the previous post.
If you didn't get the graphic, it is the plain v's MIME setting on the
mailing list.
Go here <http:// discuss@lists.openscad.org> login (email in field at
bottom) to change your options. Or ask me to (PM).
View this message in context: http://forum.openscad.org/2dgraph-equation-based-2-D-shapes-in-openSCAD-tp15722p15757.html
oops...yes < raw >< /raw > not < code >
View this message in context: http://forum.openscad.org/2dgraph-equation-based-2-D-shapes-in-openSCAD-tp15722p15758.html
Reproduced here for completeness (without any special tags):
r=1;
thickness=2;
loops=3;
linear_extrude(height=1) polygon(points= concat(
[for(t = [90:360*loops])
[(r-thickness+t/90)*sin(t),(r-thickness+t/90)cos(t)]],
[for(t = [360loops:-1:90])
[(r+t/90)*sin(t),(r+t/90)*cos(t)]]
View this message in context: http://forum.openscad.org/2dgraph-equation-based-2-D-shapes-in-openSCAD-tp15722p15759.html
r=1;
thickness=2;
loops=3;
Thank you for sharing! It is rather "dense" syntax, I find it hard to
follow.
Before you posted it, I tried the spiral using AngelScript CSG, here is
the code for comparison
http://arnholm.org/software/as_csg/sweep_spiral.as
OpenSCAD csg file generated
http://arnholm.org/software/as_csg/sweep_spiral.csg
OpenSCAD view
http://arnholm.org/software/as_csg/sweep_spiral.png
The two include files:
http://arnholm.org/software/as_csg/lib_sweep.as
http://arnholm.org/software/as_csg/lib_degrees.as
Is this easier to follow?
r = 1;
thickness = 2;
loops = 3;
start_angle = 90;
end_angle = 360 * loops;
function spiral(r, t) = let(r = (r + t / 90)) [r * sin(t), r * cos(t)];
inner = [for(t = [start_angle : end_angle]) spiral(r - thickness, t) ];
outer = [for(t = [end_angle : -1 : start_angle]) spiral(r, t) ];
polygon(concat(inner, outer));
r=1;
thickness=2;
loops=3;
follow.
OpenSCAD view
