Re: [OpenSCAD] make an object hollow with constant wall thickness
rew
Sun, Nov 15, 2015 11:37 AM
Michael,
The "generate a hollow object" is a difficult problem in general.
But if you want to print the hull of an object, it may be easier to just set
"infill" to zero on your slicing program.
View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14507.html
Michael, The "generate a hollow object" is a difficult problem in general. But if you want to print the hull of an object, it may be easier to just set "infill" to zero on your slicing program. -- View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14507.html Sent from the OpenSCAD mailing list archive at Nabble.com.
plasticmonk
Mon, Nov 16, 2015 6:59 PM
zero infill is not an option. the object is going to be parametric. I'll have
a look at the other optiions tomorrrow. thanks for the replys so far.
View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14561.html
zero infill is not an option. the object is going to be parametric. I'll have a look at the other optiions tomorrrow. thanks for the replys so far. -- View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14561.html Sent from the OpenSCAD mailing list archive at Nabble.com.
plasticmonk
Mon, Nov 16, 2015 7:04 PM
@peter
what for is the //small number "e"?
View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14562.html
@peter what for is the //small number "e"? -- View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14562.html Sent from the OpenSCAD mailing list archive at Nabble.com.
plasticmonk
Mon, Nov 16, 2015 7:23 PM
@peter, i understand the small number now but in general its not the solution
im looking for. let me refrase the qusetion:
cube([50-x,50-x,100]);
x=2;
translate([x/2,x/2,0])
if I could make it work that the 2nd cube gets another x value then the 1st,
i could reuse the same code for the inner and the outer object. Because we
are talking about a very complex object, this would help me a lot.
View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14564.html
@peter, i understand the small number now but in general its not the solution im looking for. let me refrase the qusetion: difference(){ cube([50-x,50-x,100]); x=2; translate([x/2,x/2,0]) cube([50-x,50-x,100]); } if I could make it work that the 2nd cube gets another x value then the 1st, i could reuse the same code for the inner and the outer object. Because we are talking about a very complex object, this would help me a lot. -- View this message in context: http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14564.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PF
Peter Falke
Tue, Nov 17, 2015 8:35 PM
Please note that in your program x is defined as 2 in all the code.
Openscad makes one pass through the code to process all the variabes.
Then it writes all the geometry in a CSG-tree.
For your code example this is:
group() {
cube(size = [48, 48, 100], center = false);
multmatrix([[1, 0, 0, 1], [0, 1, 0, 1], [0, 0, 1, 0], [0, 0, 0,
1]]) {
Then it sends this CSG-tree to the , CGAL http://cgal.org
2015-11-16 20:23 GMT+01:00 plasticmonk deurer@rocketmail.com:
solution
x=2;
1st,
Please note that in your program x is defined as 2 in all the code. Openscad makes one pass through the code to process all the variabes. Then it writes all the geometry in a CSG-tree. For your code example this is: group() { difference() { cube(size = [48, 48, 100], center = false); multmatrix([[1, 0, 0, 1], [0, 1, 0, 1], [0, 0, 1, 0], [0, 0, 0, 1]]) { cube(size = [48, 48, 100], center = false); } } } Then it sends this CSG-tree to the , CGAL <http://cgal.org> 2015-11-16 20:23 GMT+01:00 plasticmonk <deurer@rocketmail.com>: > @peter, i understand the small number now but in general its not the > solution > im looking for. let me refrase the qusetion: > > difference(){ > > cube([50-x,50-x,100]); > x=2; > translate([x/2,x/2,0]) > cube([50-x,50-x,100]); > } > > if I could make it work that the 2nd cube gets another x value then the > 1st, > i could reuse the same code for the inner and the outer object. Because we > are talking about a very complex object, this would help me a lot. > > > > -- > View this message in context: > http://forum.openscad.org/make-an-object-hollow-with-constant-wall-thickness-tp14255p14564.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
PF
Peter Falke
Tue, Nov 17, 2015 8:42 PM
Then it resolves all the variables and calculations and  writes all the
group() {
1]]) {
engine to render. This last step is what takes so long.
So optimising the calculations in your code is almost always not effective.
The time to calculate the 3d-mesh takes way longer.
Please note that in your program x is defined as 2 in all the code. Openscad makes one pass through the code to process all the variabes. Then it resolves all the variables and calculations and writes all the geometry in a CSG-tree. For your code example this is: ( group() { difference() { cube(size = [48, 48, 100], center = false); multmatrix([[1, 0, 0, 1], [0, 1, 0, 1], [0, 0, 1, 0], [0, 0, 0, 1]]) { cube(size = [48, 48, 100], center = false); } } } Then it sends this CSG-tree to the , CGAL <http://cgal.org> engine to render. This last step is what takes so long. So optimising the calculations in your code is almost always not effective. The time to calculate the 3d-mesh takes way longer.
