Hi Thomas,
degenerate faces and degenerate polyhedra are quite useful for what you want
to do.
A flat, degenerate polyhedron can be generated from even more degenerate
triangles like this:
module polyhedrify_points(points) {
faces = [for(i=[0:len(points)-1]) [i,i,i]];
hull()
polyhedron(points, faces);
polyhedrify_points([[2,2,2], [2,8,8], [7,2,2], [7,8,8]]);
// Or for a non-degenerate result:
//polyhedrify_points([[2,2,2], [2,8,8], [7,2,2], [7,8,8], [0,0,10]]);
From the above it is trivial to linear extrude by some vector v.
One way for this is to hull with the translated result:
hull()
for(i=[0,1])
translate(i*[-2,-6,0])
Degenerate faces and degenerate polyhedra are not documented in OpenSCAD.
So I am not sure if the above will remain possible in all future versions.
Maybe someone can tell. I am using 2015.03-2.
Martin
www.panohero.de
