CN
Csaba Nagy
Tue, Dec 14, 2021 6:09 PM
My framework can be turned into a PyCharm plugin with code
completion/viewing/refactoring of the parameter hierarchy and Part
library management. It can be extended to document parameters visually
as annotations over renderings of each Part. It can already generate
complex extrusions, can handle Bezier paths and some more - but none of
that will be published soon if I don't get help. I'm still working out
the details of how to handle aliases (happens a lot that different
parts with similar shape want to name their parameters differently),
orientation/alignment/attaching parts in an assembly. I contemplate
getting rid of the openscad translate/rotate functions and replace them
with versions which are stored on each part, that would allow automated
kinematic chain calculations. There's a lot of work which would
radically change what I currently have, and I don't have the motivation
to do all that alone in a short term... I will eventually do it for my
own sake, but gradually as I need it for my own modeling.
Cheers,
Csaba
On Tue, 2021-12-14 at 18:48 +0100, edmund ronald wrote:
Here is a Medium post where John Clark Craig describes his wrapper.
He seems to have a userbase of sorts, and to be a smart cookie so
there is probably a need for something like this, and I expect sooner
or later someone will make an integrated 3D system of their own
similar to this as the openScad crowd don't like the idea.
Edmund
Hi David,
at first I thought I was looking for the same, a python 3D
programming
language. So I started using SolidPython:
https://github.com/SolidCode/SolidPython
It is a fairly straightforward wrapper around OpenSCAD, allowing
you to
write your 3D model in python, which is then translated to
OpenSCAD.
But soon I realized that what I needed is a better way to express
parameters of a complex model.
So I wrote my own python framework to process JSON descriptors,
with
meta-class magic that merges the parameters across the inheritance
hierarchy. That way I can define sub-classes which basically
inherit
the parameters of their base class, and can override just that
single
one they actually change. The framework messes with the
setters/getters
too so parameters defined in that decriptor are available with the
attribute access syntax as well as dictionary entries (the "Part"
class
extends an ordered dictionary). Class instantiation can override
any of
the parameters, the ones not set are left at the default value.
That
overall makes for a hierarchical access of all parameters - in
simple
cases simplifies the code a lot, in complex ones makes for
spaghetti-
like names, but I think it is still the better way to handle 100+
variables.
Working with PyCharm I also have some magic built in the Part class
which allows me to render the current file and open it in OpenSCAD
view
with the press of a key-combination. Same can be done for any file
in
the project view, or for a class highlighted in the editor. That
makes
for fairly streamlined work-flow where coding and preview
alternate.
The catch with all this is that at the moment it is tailored for
exactly what I needed to model and it is less then pre-alpha
quality
for public release. I also can't find the motivation to spend the
time
necessary to improve it for the sake of publishing, real life and
my
own modeling tasks are what finally win.
I will include an OpenSCAD file and the top level python class
which
generated it for a sample of what can be done. I will not publish
code as I'm not satisfied with it and will surely radically change
it
still in the future - but if somebody is interested enough in it to
help preparing a publishable version, I'm ready to do a few on-line
sessions to explain what I have and discuss what and how to
publish.
Without help, it will take me a few more years with the speed I'm
progressing now.
The project is hosted on gitlab.com, at the moment private and it
seems
gitlab will not allow me to change that (bug I assume). Anybody
wanting
to check the code, ask me and I will give you access.
Cheers,
Csaba
P.S. the scad file is a table-tennis ball machine I'm working on
right
now. All elements you see are fully configurable, almost no hard-
coded
number outside the CONFIG_DESCRIPTOR of each used Part/Assembly.
The
iter_components method in the python file will generate a list of
3D-
printable components, processing is bound to a PyCharm key
combination
too. Any class name extending Part/Assembly in the python file can
be
highlighted and previewed using a key-press too (of course only in
my
local setup, I would need to package the key shortcuts in a PyCharm
plugin).
On Tue, 2021-12-14 at 10:14 -0600, David Schooley wrote:
Thank you everyone for the comments up to the point. Even the
that’s not going to happen” type of feedback is useful.
To put things in context: I was a contributor to gnuplot years
(I did a really nice Mac version.) I’ve made a lot of 2D plots
Perl-generated gnuplot scripts. After playing with flex and bison
bit, I started thinking about a new plotting program using a more
modern interpreter. Python was still relatively new, I hadn’t
Python at all at the time, but the syntax for this never-written
plotting software would have been very Python-like. I started
Python a short time later, abandoned by software project, and now
things that would have been Perl+gnuplot are Python with
Life is good.
When I started 3D printing, I started with FreeCAD (which has a
Python workbench) and then moved to OpenSCAD. I have a large
of OpenSCAD scripts laying around.
OpenSCAD meets my needs for almost everything I do. (It does fall
down when it comes to things such as fillets around complex
There are times when I need real variables and there are times
the design needs to change depending on the size or something
i.e., the hole pattern changes depending on the size of the
The next step would be data-driven designs, which I can visualize
can’t really do at this point without using Python to create
scripts.
An example might be a 3D printed map using GIS data. You could
perhaps do this with the OpenSCAD language by extruding a bitmap
generated using Python. It would be cleaner, and you would have
control, if you did the whole thing in Python.
Thinking of OpenSCAD (the software) as a wrapper for OpenSCAD
language) is perfectly reasonable. It’s not the answer I wanted,
it’s the answer I got.
So that’s where I am at. I’ll take a look at the book that Harm
suggested. I think I can get the Kindle version for free.
On Dec 14, 2021, at 1:44 AM, edmund ronald <
Everybody and their dog seems to have done Python covers of
OpenSCAD.
Which seems to indicate that there is a perceived need in the
Print userbase.
My guess is sooner or later another project will mature enough
serve that population, at which point the question will go
Hi David,
Do you know this book :
Python for 3D Printing openSCAD by Craig, John Clark
I got it and seems interesting, but had no time read it at
If you'reinterested I can give you more info.
Regards,
Harm Jeurink
David Schooley schreef op 2021-12-12 10:43:
I have a feeling this has come up before…
I’m curious about any thoughts/previous discussions have
regarding incorporating Python as an embedded scripting
OpenSCAD. Some work has been done with Python and CSG, so
entirely impossible, but it could be a lot of work; I get
The OpenSCAD language isn’t bad, but it’s no great shakes
interesting to see work happening to make structures a
maybe it would be better to incorporate a language that has
variables and objects. There was a recent discussion around
calculating parameters on the fly, which is easy with
more difficult or impossible using the OpenSCAD language.
I’m not at all interested in generating OpenSCAD code from
just adds another layer of “Why doesn’t this work?” I think
to write some Python code that generates an object that
display and turn into something I can 3D print or cut using
would be amazing.
Cheers,
Csaba
> Edmund
https://jccraig.medium.com/yes-you-can-use-python-for-3d-design-and-printing-508b1791c863
> Edmund
> On Tuesday, December 14, 2021, Csaba Nagy <ncsaba@javampire.com>
> wrote:
> > Hi David,
> > programming
> > you to
> > OpenSCAD.
> > with
> > inherit
> > single
> > setters/getters
> > class
> > any of
> > That
> > simple
> > spaghetti-
> > variables.
> > view
> > in
> > makes
> > alternate.
> > quality
> > time
> > my
> > which
> > the
> > it
> > publish.
> > progressing now.
> > seems
> > wanting
> > Cheers,
> > Csaba
> > right
> > coded
> > The
> > 3D-
> > combination
> > be
> > my
> > plugin).
> > “no,
> > ago.
> > using
> > a
> > used
> > using
> > matplotlib.
> > > Life is good.
> > number
> > shapes.)
> > when
> > else,
> > object.
> > but
> > OpenSCAD
> > > scripts.
> > more
> > (the
> > but
> > edmundronald@gmail.com>
> > > > OpenSCAD.
> > 3d
> > > > Print userbase.
> > to
> > away.
> > > > Edmund
> > > > On Mon, Dec 13, 2021 at 11:34 AM <info@hjcreations.nl> wrote:
> > > > > Hi David,
> > all.
> > > > > Regards,
> > > > > Harm Jeurink
> > > > > happened
> > > > > language to
> > this
> > > > > isn’t
> > that.
> > > > > either. It’s
> > reality,
> > > > > but
> > > > > real
> > Python
> > > > > but is
> > > > > Python that
> > > > > being able
> > > > > OpenSCAD can
> > a
> > > > > laser
> > > > > > would be amazing.
> > > > > > _______________________________________________
> > > > > > OpenSCAD mailing list
> > > > > > To unsubscribe send an email to
> > > > > discuss-leave@lists.openscad.org
> > > To unsubscribe send an email to discuss-leave@lists.openscad.org
Tue, Dec 14, 2021 6:44 PM
I looked into this a bit a year or two ago, more from the perspective of
wanting to reduce the number of languages that I keep in my head, and to
make it easier for newcomers, than from any specific problem with
OpenSCAD functionality. Why reinvent the wheel, but a little differently?
I got far enough to have a toolchain based on Carsten's AngelCAD
environment. You could type a Python program like
cu = Cube(size=45,center=True);
sp = Sphere(r=30)
cusp = cu.intersect(sp)
## union of 3 cylinders
cy = Cylinder(r=17,h=50,center=True)
cy2 = cy.union(cy.rotatex(90))
cy3 = cy2.union(cy.rotatey(90))
## difference of the 2 above
cusp.subtract(cy3).add()
into the IDE and my toolchain would turn that into xcsg that could then
be viewed using Carsten's xcsg viewer - basically the same flow as
Carsten's AngelScript flow. No OpenSCAD in the process - not
specifically to avoid it, but to directly emit a lower-level result.
I stopped working on it for a couple of reasons:
- I was offended by the need to explicitly add objects to the model
(the .add() method above), and couldn't figure out how to get rid of
it. The minimum OpenSCAD program is "cube();" and I wanted to get
down to that level of simplicity.
- Python is not sandboxable. Python programs can do anything. You
could not take somebody's Python-based SCAD program and run it,
without risking that it would trash your system.
Note also that designing in a "real language" doesn't automatically
solve some of the OpenSCAD complaints. In particular, just because
you've got a real language and real objects doesn't mean that you've got
access to the geometry. My toolchain operated by generating an xcsg
https://github.com/arnholm/xcsg file to be fed into a geometry
engine. It has no idea what, for instance, a sphere is; it just knows
that it's a geometric object that can be generated and operated on by
the geometry engine.
It was really pretty easy to write - it's only about 300 lines of Python
plus a one line batch file to glue it together. I'd be happy to forward
it to anybody who wants to play with it.
sp = Sphere(r=30)
* I was offended by the need to explicitly add objects to the model
* Python is not sandboxable. Python programs can do anything. You
<https://github.com/arnholm/xcsg> file to be fed into a geometry
CA
Thu, Dec 16, 2021 4:17 PM
Correct. This implies one could reimplement the engine to use CGAL or
OpenCascade instead of Carve,
You could probably use Python operator overloading
https://www.pythontutorial.net/python-oop/python-operator-overloading/
solid = Cube(100) + Sphere(50);
Thu, Dec 16, 2021 5:05 PM
Yes, I could do that, but that's not what I was offended by.
In OpenSCAD, you can say
cube();
and that's a complete and valid program that yields a model of a cube.
In Python, if cube() is a function that returns a cube, saying
cube()
will create a geometric object that's a cube... and then will drop it on
the floor, because nothing consumes it.
You have to have a method or function that consumes the cube and adds it
to the model. In my library, that's the .add() method, but it could
equally well be an add(obj) function. Or maybe the program is required
to return the object (which also requires you to explicitly union the
various components of the model, another thing that OpenSCAD doesn't
require you to do explicitly). In any event, the required minimum
program is more than just c u b e ( ).
I was hoping that I could find a hook akin to what the REPL
https://en.wikipedia.org/wiki/Read%E2%80%93eval%E2%80%93print_loop
does, so that if the result of a statement was a geometric object that
would otherwise be dropped on the floor, it would instead be added to
the model, in the same way that the REPL would print it, but I couldn't
find such a hook.
I also looked at JavaScript as the base for a 3D modeling environment,
and ran into similar issues. I think there was something else that I
didn't like about JavaScript for the purpose, but I don't remember
what. Perhaps it was simply that command-line JavaScript interpreters
are not as ubiquitous as command-line Python interpreters. (Yes, I know
about Node.js and use it extensively, but it's not ubiquitous. Yes,
every browser has a JavaScript interpreter, but you can't hook them into
a toolchain, at least not without also creating an xscg processor that
runs in a browser.)
cube();
cube()
<https://en.wikipedia.org/wiki/Read%E2%80%93eval%E2%80%93print_loop>
find such a hook.
a toolchain, at least not without *also* creating an xscg processor that
runs in a browser.)
