How do you measure your Model
ats3788
Thu, Mar 26, 2020 9:01 AM
Hello
I do a lot of cases with OpenSCAD
for this purpose OpenSCAD is perfect.
I use NetFabb to measure my models precise.
How you are doing this ?
Hello I do a lot of cases with OpenSCAD for this purpose OpenSCAD is perfect. I use NetFabb to measure my models precise. How you are doing this ? -- Sent from: http://forum.openscad.org/
Thu, Mar 26, 2020 10:55 AM
In general I don't. I code my models to be the size I want and they are.
I did once make a typo and print something that was stupidly oversized but
fortunately it was only the internal dimensions that mattered.
I do sometimes use NetFabb to double check.
On Thu, 26 Mar 2020 at 09:02, ats3788 ats3788@gmail.com wrote:
Hello
In general I don't. I code my models to be the size I want and they are. I did once make a typo and print something that was stupidly oversized but fortunately it was only the internal dimensions that mattered. I do sometimes use NetFabb to double check. On Thu, 26 Mar 2020 at 09:02, ats3788 <ats3788@gmail.com> wrote: > Hello > I do a lot of cases with OpenSCAD > for this purpose OpenSCAD is perfect. > I use NetFabb to measure my models precise. > How you are doing this ? > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
