Ray West
Mon, Nov 9, 2020 9:00 PM
Hi Charles,
afaik, it will be bronze filled plastic filament, it may look OK when
polished, but it will be as mechanically weak as the base pla plastic
filament. If the original is bronze (unlikely), then braze up the crack,
if cast anodized aluminium, learn 'back yard foundry', and cast your
own. I would be worried that a plastic replacement could fail, and the
blade could damage something else. Perhaps you have a tame machine-shop
nearby, who could mill you a replacement?
Best wishes,
Ray
On 09/11/2020 16:28, charles meyer wrote:
Hi All,
I hope you're all well.
I'm trying to find a ceiling blade fan holder .STL file but found
nothing in Thingiverse and Tinkercad.
I have an old ceiling fan which works great except for this one fan
blade holder (made of some kind of metal - looks bronze-like)
which cracked.
I've visited a plethora of Home Depots, Lowe's, Ace Hardware stores,
fan and ceiling light stores but can't find the correct ceiling fan
blade holder (bracket?) to fit the holes distances in the fan motor.
The fan manufacturer no longer makes that model so they have no parts
for it.
We got a new dual Tool Head for the Lulzbot TAZ 6 (able to
print metal) at the library so we wanted to see if we could print a
metal fan blade holder with the 3D printer.
Thank you for your thoughts/suggestions.
Best,
Charles.
Hi Charles,
Best wishes,
Ray
> Hi All,
> which cracked.
> for it.
> Best,
> Charles.
Mon, Nov 9, 2020 9:34 PM
Plastic can be quite strong and may be strong enough for the application.
But I probably wouldn't bet on it myself. I think bronze filled PLA will
actually be weaker, since the plastic matrix is interrupted by metal
particles. You would be better off choosing a plastic like nylon or some
other printable plastic that is stronger than PLA.
Lastly you can prototype your part in PLA and then send it to a service like
Shapeways and have it printed in actual metal (aluminum). I think that's
their strongest material. Or maybe the bronze filled stainless steel.
You'll find this option is rather expensive, though. (Might cost as much
as a new ceiling fan.)
mondo wrote
Hi Charles,
Best wishes,
Ray
Hi All,
which cracked.
for it.
Best,
Charles.
mondo wrote
> Hi Charles,
> Best wishes,
> Ray
>> Hi All,
>> which cracked.
>> for it.
>> Best,
>> Charles.
> Discuss@.openscad
> Discuss@.openscad
Mon, Nov 9, 2020 9:38 PM
Printed nylon or polycarbonate might be strong enough.
like
mondo wrote
Hi Charles,
Best wishes,
Ray
Hi All,
which cracked.
for it.
Best,
Charles.
> like
> mondo wrote
> > Hi Charles,
> > Best wishes,
> > Ray
> >> Hi All,
> >> which cracked.
> >> for it.
> >> Best,
> >> Charles.
> > Discuss@.openscad
> > Discuss@.openscad
JW
Jan Wieck
Mon, Nov 9, 2020 10:16 PM
Second that. Carbon Fiber reinforced Nylon is probably your best bet. I
would replace all of them and maybe give them some spray paint for the
looks. Had good results spray painting plastic parts with Rust-Oleum, all
the way to the side panels of my BMW C650GT (after laying her down at zero
speed in the most clumsy way possible).
Good luck, Jan
application.
like
mondo wrote
Hi Charles,
Best wishes,
Ray
Hi All,
which cracked.
for it.
Best,
Charles.
Jan Wieck
Principal Database Engineer
Good luck, Jan
>> application.
>> like
>> mondo wrote
>> > Hi Charles,
>> crack,
>> > Best wishes,
>> > Ray
>> >> Hi All,
>> >> which cracked.
>> >> for it.
>> >> Best,
>> >> Charles.
>> > Discuss@.openscad
>> > Discuss@.openscad
Jan Wieck
trygve@totallytrygve.com
Tue, Nov 10, 2020 1:25 PM
No, no, NO!
Not spray paint!
Use 'Mirror - the world's mirroriest mirror Chrome paint' from Culture Hustle.
Trygve
Den 9. november 2020 kl. 23.16.13 +01.00 skrev Jan Wieck jan@wi3ck.info:
Second that. Carbon Fiber reinforced Nylon is probably your best bet. I would replace all of them and maybe give them some spray paint for the looks. Had good results spray painting plastic parts with Rust-Oleum, all the way to the side panels of my BMW C650GT (after laying her down at zero speed in the most clumsy way possible).
Good luck, Jan
mondo wrote
Hi Charles,
Best wishes,
Ray
Hi All,
which cracked.
for it.
Best,
Charles.
No, no, NO!
Not spray paint!
Trygve
Den 9. november 2020 kl. 23.16.13 +01.00 skrev Jan Wieck <jan@wi3ck.info>:
> Good luck, Jan
> > > mondo wrote
> > > > Hi Charles,
> > > > Best wishes,
> > > > Ray
> > > >> Hi All,
> > > >> which cracked.
> > > >> for it.
> > > >> Best,
> > > >> Charles.
> > > > Discuss@.openscad
> > > >> <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org>
> > > > Discuss@.openscad
> > > Sent from: <http://forum.openscad.org/>
> > > <Discuss@lists.openscad.org>
> Jan Wieck
Tue, Nov 10, 2020 1:35 PM
I have been printing parts using TPU, specifically NinjaTek's Cheetah,
and it it an amazing material. It is a bit rubbery, but it does not
give much when printed in large pieces. The main point is that it is
indestructible. If you print a sheet that is 2 layers thick, you cannot
tear the sheet apart with your hands. I would trust Cheetah for a job
like this.
On 11/10/2020 8:25 AM, trygve@totallytrygve.com wrote:
No, no, NO!
Not spray paint!
Hustle.
Trygve
Good luck, Jan
application.
filled PLA will
by metal
nylon or some
a service like
think that's
stainless steel.
cost as much
mondo wrote
Hi Charles,
Best wishes,
Ray
Hi All,
which cracked.
for it.
Best,
Charles.
Jan Wieck
like this.
> No, no, NO!
> Not spray paint!
> Hustle.
> Trygve
>> Good luck, Jan
>> application.
>> filled PLA will
>> by metal
>> nylon or some
>> a service like
>> think that's
>> stainless steel.
>> cost as much
>> mondo wrote
>> > Hi Charles,
>> look OK when
>> pla plastic
>> up the crack,
>> cast your
>> fail, and the
>> machine-shop
>> > Best wishes,
>> > Ray
>> >> Hi All,
>> but found
>> this one fan
>> >> which cracked.
>> Hardware stores,
>> correct ceiling fan
>> fan motor.
>> have no parts
>> >> for it.
>> could print a
>> >> Best,
>> >> Charles.
>> > Discuss@.openscad
>> > Discuss@.openscad
>> Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org>
>> Jan Wieck
lar3ry@sasktel.net
Fri, Nov 13, 2020 4:33 AM
Better and cheaper would be to have the part cast in aluminum, using a lost
wax technique (actually lost PLA in this case).
