Maybe this has been suggested before.
I have an 8 core system: most of the time, I'm only using 1 or 2 cores.
Suppose that OpenSCAD was always monitoring the source code, and kept
every module pre-compiled (F6) so long as the text cursor was not inside
a module. If this was interruptible (when the source code of a module
was changed), the result could be increased responsiveness when the user
pressed F6. The feature would only be available on systems with (say)
more than 2 cores, and could be enabled and disabled.
I'm sure there are cases where this would backfire, but if the cores are
just sitting there, why not pre-compute as much as we can?
I know that render() can do this manually. I'm talking about something
automatic.
Sent from my desktop computer.
I do not receive emails while away from my desk,
nor do I receive texts on my main phone number
(which is a land line).
If you know that I am on the road, please text me.
If you know that I am home, please email me.
Compiling is pretty fast, it's the rendering that takes time, and that can't
be done in advance. Consider this module:
module screw(diameter, length, headtype)
This takes several parameters, and depending on them, returns a different
object. There is no way you can pre-render that if you don't know the
parameters it'll be called with.
Heck, I can take it one step further:
module row(distance, number)
This takes the supplied objects (children();) and places number copies in a
row, starting with the position of the first one. That will not even have
the objects until runtime.
