Re: [OpenSCAD] Odd artifacts when generating gears
Fri, Apr 21, 2017 7:53 AM
Have you ever thought that an involute gear with this specs might not be
well-defined? You'd better go for hypocycloid gears, if want pressure angles
36°.
View this message in context: http://forum.openscad.org/Odd-artifacts-when-generating-gears-tp21295p21342.html
Have you ever thought that an involute gear with this specs might not be well-defined? You'd better go for hypocycloid gears, if want pressure angles >36°. -- View this message in context: http://forum.openscad.org/Odd-artifacts-when-generating-gears-tp21295p21342.html Sent from the OpenSCAD mailing list archive at Nabble.com.
