Two very easy, backwards-compatible changes to the lookup() builtin that would be very helpful:
lookup() searches into, could have vectors as payload values. ie:table = [
[0, [-50,0,0]],
[0.3, [-20,-10,25]],
[0.7, [ 20,10,25]],
[1, [ 50,0,0]],
for (u = [0:1/32:1])
move(lookup(u, table))
sphere(d=1);
This can (and has) been done in user-space using `search()`, but at a severe cost of efficiency.
table = [
[0, [-50,0,0]],
[0.7, [ 20,10,25]],
[1, [ 50,0,0]],
for (pt = lookup([0:1/32:1], table))
move(pt)
sphere(d=1);
This also can be done in user-space using a simple list comprehension, but there are obvious optimizations by doing it built-in, that take the efficiency from O(n^2) in user-space to O(n) in C++. There are actually quite a few places in my library that could take great advantage of that.
For example, enveloping worm creation could be made a lot faster. I suspect bezier surfaces could be optimized a lot, albeit with a minor loss of accuracy.
These changes should be fairly trivial to implement. I'd do it myself, but my submissions have had a 0% acceptance rate into the mainline code, so far.
-Revar
PR#4274 is exactly that. I'm not sure why it stalled - probably because
reviewers (notably including me) asked for a fair number of minor checks
and test cases. I don't think any of them are hard, but they are
tedious and take time and effort, and like all of us the submitter
probably has serious limits on both.
If the search value given is a range type, return a list of
results, one for each value of the range:
table = [
[0, [-50,0,0]],
[0.7, [ 20,10,25]],
[1, [ 50,0,0]],
move(pt)
sphere(d=1);
Is this semantically the same as
for (i = [0:1/32:1]) {
pt = lookup(i, table);
move(pt)
sphere(d=1);
Is the gain only that the second iteration can search less of the table?
I think lookup is a binary search, O(log(n)), so this is already
O(n*log(m)); eliminating half of the entries is only a 1/log(m)
improvement, and k is pretty small.
On Oct 4, 2023, at 5:16 PM, Jordan Brown openscad@jordan.maileater.net wrote:
I think lookup is a binary search, O(log(n)), so this is already O(n*log(m)); eliminating half of the entries is only a 1/log(m) improvement, and k is pretty small.
Looking at the code, it is definitely NOT doing a binary search. It's doing a linear search to find the largest key that is <= the searched for key, and the smallest key that is >= the searched for key, then interpolates using those two keys and their associated values.
OMG that's terrifying. I don't know why anybody would define it that way.
But then I'm not sure how your range construct would help, because for
each step in the range the matching two entries might be anywhere in the
table. (For a large enough number of steps it might be better off
internally sorting the table and then using a binary search, but yuck.)
On Oct 4, 2023, at 6:15 PM, Jordan Brown openscad@jordan.maileater.net wrote:
On Oct 4, 2023, at 5:16 PM, Jordan Brown openscad@jordan.maileater.net mailto:openscad@jordan.maileater.net wrote:
But then I'm not sure how your range construct would help, because for each step in the range the matching two entries might be anywhere in the table. (For a large enough number of steps it might be better off internally sorting the table and then using a binary search, but yuck.)
Well, apparently it allows for out-of-order entries in the lookup table, without incurring the expense of a sort. But yes, this precludes the optimization I was hoping for, unless range searches just required that the table keys increased monotonically.
Note that interpolation was always the intent of lookup(), judging by the original examples. Search() is for searching.
It's not the interpolation that we're being surprised by. It's the fact
that the entries aren't required to be in order.
t = [
[2, 20],
[0, 0],
[1, 10],
[3, 20]
echo(lookup(1.5, t));
You can rearrange the entries all you like, and the result is still 15
because it finds the "1" entry and the "2" entry and interpolates
between them.
Perhaps we could add a ordered=true flag argument to lookup() that could tell it that it can do a binary search of the table, and if it stumbles on an out of order entry it can assert an error.
I take this statement back. In looking though the OpenSCAD dev release sources, it seems like object() and has_key() made it into the code. 🎉🎊🍾
As an aside, roof() is a neat experimental feature. It still has a bug or two using method="voronoi", though:
roof(method="voronoi") star(n=5, step=2, d=20);
ERROR: Skeleton computation error. /Users/distiller/project/src/geometry/roof_vd.cc line 140: error in parabolic arc discretization in file foo.scad, line 8 <8,/Users/gminette/Documents/OpenSCAD/libraries/BOSL2/foo.scad>
