Sun, Apr 27, 2025 3:31 PM
On Sat, 2025-04-26 at 14:35 -0400, gene heskett via Discuss wrote:
SOLVED!
On 4/26/25 13:59, Todd Allen via Discuss wrote:
I'm running OpenSCAD under linux. Adding the following to my .profile
scales my interface fonts.
export QT_SCALE_FACTOR=1.5
Added that to my .profile, stopped OpenSCAD, did a . .profile and
restarted OpenSCAD.
Hmm... that did not work on mine.
Running
Distributor ID: Ubuntu (MATE)
Description: Ubuntu 22.04.5 LTS
Release: 22.04
Codename: jammy
All fonts, including editor were expanded, about 3 ctl -'s to restore
editor window to normal. All other fonts AND icons now 500% more
readable to these tired old eyes.
Thank you, Todd Allen.
I'm current using the current weekly build and just got chased around
the mulberry tree by the teeny font used in the save menu.
Making braces to support the controller board and a bananapi-m5 in the
3d printer, I just saved a corrected 3mf file and printed 3 identical
copies that won't fit despite my corrections because the font wasn't big
enough to show me an extra and wrong character is the save menu, not
discovered until I got out a magnifying glass and read the saved
filename in the log window. It appears I need to get a new glasses
'script, if its fixable. I've had cataracts removed, but diabetes, 90
years & macular degeneration are combining to make this difficult to see.
How can I adjust the the size of the font used in those popup file
requestor's?.
Thanks.
Cheers, Gene Heskett, CET.
- Louis D. Brandeis
> SOLVED!
> restarted OpenSCAD.
Running
Release: 22.04
Codename: jammy
> > On Sat, Apr 26, 2025 at 3:04 AM gene heskett via Discuss <
> > > requestor's?.
> > > Thanks.
> > > "There are four boxes to be used in defense of liberty:
> > > soap, ballot, jury, and ammo. Please use in that order."
> > > -Ed Howdershelt (Author, 1940)
> > > If we desire respect for the law, we must first make the law respectable.
> > > - Louis D. Brandeis
> > > _______________________________________________
> > > OpenSCAD mailing list
> > > To unsubscribe send an email to discuss-leave@lists.openscad.org
K
Ken
Sun, Apr 27, 2025 11:23 PM
Thanks Jordan, but while that would help a bit with openscad, it will also screw up every other program I use as it is a global setting, not a "per program" setting. I have been through that particular minefield before...
On 2025-04-27 09:11, Jordan Brown wrote:
On 4/26/2025 3:41 PM, Ken via Discuss wrote:
Sadly I'm running windows so that doesn't solve my problem.
Under Windows try these settings:
Settings > System > Display > Scale
Settings > Accessibility > Text Size
They may or may not help, depending on which text you need larger and your tolerance for mangled displays.
Restart the program after making a change.
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Mon, Apr 28, 2025 12:01 AM
before...
What is it that makes OpenSCAD need special treatment? Why does scaling
everything up make OpenSCAD better but make other applications worse?
> before...
Mon, Apr 28, 2025 9:58 AM
As I mentioned before, use the start key and + - it'll double the size
(or more), start and - to get back to normal. Use it when needed.
In openscad there are four or five areas that have different fonts. Only
the editor window gives simple user control.
before...
> before...
> Cheers, Ken
> bats059@gmail.com
> https://vk7krj.com
> https://vk7krj.com/running.html
> A baby can be defined as an ego with a noise at one end and a smell at the other.
> Your job as parents is to teach them to control all three.
> My job as a grandad is to tell you how you are doing it all wrong!
K
Ken
Mon, Apr 28, 2025 10:21 AM
Sounds good Raymond- but which is the start key?
On 2025-04-28 19:58, Raymond West via Discuss wrote:
As I mentioned before, use the start key and + - it'll double the size (or more), start and - to get back to normal. Use it when needed.
In openscad there are four or five areas that have different fonts. Only the editor window gives simple user control.
>> Cheers, Ken
>> bats059@gmail.com
>> https://vk7krj.com
>> To unsubscribe send an email todiscuss-leave@lists.openscad.org
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
Mon, Apr 28, 2025 2:07 PM
Its the physical button, between ctrl and alt, I and others call it the
windows key, but Microsoft, being silly as usual call, it start key. It
is also on screen, to the left of the search on the task bar.
>>> Cheers, Ken
>>> bats059@gmail.com
>>> https://vk7krj.com
> Cheers, Ken
> bats059@gmail.com
> https://vk7krj.com
K
Ken
Wed, Apr 30, 2025 3:03 AM
Thanks Raymond- but that's just windows magnifier, which really plays up with my ocd- messes up all the windows across all three monitors, not just the one bit of text I want magnifying.
I guess I will just have to put up with the very tiny fonts for now, as being the lesser of the evils🙂
Maybe that will change when I move everything over to Linux before October.
On 2025-04-29 00:07, Raymond West via Discuss wrote:
Its the physical button, between ctrl and alt, I and others call it the windows key, but Microsoft, being silly as usual call, it start key. It is also on screen, to the left of the search on the task bar.
>>>> Cheers, Ken
>>>> bats059@gmail.com
>>>> https://vk7krj.com
>> Cheers, Ken
>> bats059@gmail.com
>> https://vk7krj.com
Cheers, Ken
bats059@gmail.com
https://vk7krj.com
