I bought up this module in another discussion and Adrian suggested some simplification. I think it illustrates a point of OS that confuses me and probably a lot of other people too. Hopefully this explanation will allow people to get to this understanding faster than I did. 2D geometry seems like it is the same as 2D data, but it’s not. This module takes a 2D path (list of points) and returns 3D geometry.
The OS native modules like circle produce only geometry and once something is geometry its characteristics are pretty opaque. This module illustrates the difference pretty clearly. The argument path is a list of points in 3D space, that must be coplanar. Move, rot and path2d are all BOSL2 functions that work on data, so the result pathInXY is still data, a list of points, but now points in 2D space. The object of each function is put into an argument because functions don’t have children.
Polygon turns pathInXY into geometry. It can now be operated on by modules, which do take children. The BOSL2 modules rot and move are equivalent to the functions by the same name, but the object of each is a child and must be geometry.
One of the secrets to using BOSL2 is that it has a vast number of ways to manipulate data and the characteristics of the data are findable. Often staying in the data realm as long as possible is best. At some point, you start to turn your data into geometry. BOSL2s transformations are generally available in both realms, but the syntax will be sightly different. That shows clearly in the code. Two transformations are applied to the data, then they are reversed, but reversed in the realm of geometry. Polygon_normal and centroid are examples of characteristics you can get from data that are unavailable in geometry AFAIK.
-Bob
module linear_extrude3d(path, h) {
d0 = assert(is_coplanar(path),
"Path Is Not Coplanar (from linear_extrude3d)");
r = polygon_normal(path);
c = centroid(path);
// Move the path to the XY plane centered on the origin
pathInXY = path2d( // remove Z
rot(from = r, to = UP, p = // Rotate into XY
move(-c, p = // Move centroid to origin
path)));
// Extrude it, then move it back
move(c) // Move the centroid back
rot(from = UP, to = r) // Rotate back to original angle
linear_extrude(h) // Do the extrusion
polygon(pathInXY); // Make into a 2D shape
path = [[0, 0, 0], [0, 3, 4], [0, 3, 0]];
linear_extrude3d(path, 10);
p0 = move([4, -5, 2], p = path);
linear_extrude3d(p0, 10);
p1 = rot(from = RIGHT, to = UP + RIGHT + FRONT, p = p0);
linear_extrude3d(p1, 10);
