Is there an elegant way to do pseudo-OO stuff.
N
NateTG
Sun, Mar 14, 2021 5:55 PM
I've been musing on ways to do object-oriented kinds of stuff in OpenSCAD and
came up with the approach below, but it's pretty clunky.  Is there a more
elegant method that someone can suggest?
To be clear, I'm asking about OpenSCAD syntax kind of stuff, and not about
to implement a particular kind of data structure.
I've been musing on ways to do object-oriented kinds of stuff in OpenSCAD and came up with the approach below, but it's pretty clunky. Is there a more elegant method that someone can suggest? To be clear, I'm asking about OpenSCAD syntax kind of stuff, and not about to implement a particular kind of data structure. -- Sent from: http://forum.openscad.org/
C
caterpillar
Mon, Mar 15, 2021 1:46 AM
The simple way is using a group functions that share the same data, such as
the way I does with my  hashmap
https://openhome.cc/eGossip/OpenSCAD/lib3x-hashmap.html  .
Simulating class-based oo, however, is riveting and here is my attempt to do
it.
// require dotSCAD 3.0 https://github.com/JustinSDK/dotSCAD
use <util/map/hashmap.scad>;
use <util/map/hashmap_get.scad>;
function methods(mths) = hashmap(mths);
function clz_list(data) =
methods([
["get", function(i) data[i]],
["append", function(n) clz_list(concat(data, [n]))]
function _(instance, name) = hashmap_get(instance, name);
lt1 = clz_list([10, 20]);
assert((lt1, "get")(0) == 10);
assert(
(lt1, "get")(1) == 20);
lt2 = (lt1, "append")(30);
assert(
(lt2, "get")(0) == 10);
assert((lt2, "get")(1) == 20);
assert(
(lt2, "get")(2) == 30);
https://openhome.cc
The simple way is using a group functions that share the same data, such as the way I does with my hashmap <https://openhome.cc/eGossip/OpenSCAD/lib3x-hashmap.html> . Simulating class-based oo, however, is riveting and here is my attempt to do it. // require dotSCAD 3.0 https://github.com/JustinSDK/dotSCAD use <util/map/hashmap.scad>; use <util/map/hashmap_get.scad>; function methods(mths) = hashmap(mths); function clz_list(data) = methods([ ["get", function(i) data[i]], ["append", function(n) clz_list(concat(data, [n]))] ]); function _(instance, name) = hashmap_get(instance, name); lt1 = clz_list([10, 20]); assert(_(lt1, "get")(0) == 10); assert(_(lt1, "get")(1) == 20); lt2 = _(lt1, "append")(30); assert(_(lt2, "get")(0) == 10); assert(_(lt2, "get")(1) == 20); assert(_(lt2, "get")(2) == 30); ----- https://openhome.cc -- Sent from: http://forum.openscad.org/
C
caterpillar
Mon, Mar 15, 2021 2:14 AM
You can encapsulate the instance even further. But the code is more complex
when defining a class.
function _(name, instance) = hashmap_get(instance, name);
function clz_list(data) = function(name) _(name,
methods([
assert(lt1("get")(0) == 10);
assert(lt2("get")(1) == 20);
lt2 = lt1("append")(30);
assert(lt2("get")(0) == 10);
assert(lt2("get")(2) == 30);
https://openhome.cc
You can encapsulate the instance even further. But the code is more complex when defining a class. use <util/map/hashmap.scad>; use <util/map/hashmap_get.scad>; function methods(mths) = hashmap(mths); function _(name, instance) = hashmap_get(instance, name); function clz_list(data) = function(name) _(name, methods([ ["get", function(i) data[i]], ["append", function(n) clz_list(concat(data, [n]))] ]) ); lt1 = clz_list([10, 20]); assert(lt1("get")(0) == 10); assert(lt2("get")(1) == 20); lt2 = lt1("append")(30); assert(lt2("get")(0) == 10); assert(lt2("get")(1) == 20); assert(lt2("get")(2) == 30); ----- https://openhome.cc -- Sent from: http://forum.openscad.org/
N
NateTG
Mon, Mar 15, 2021 12:49 PM
assert(lt1("get")(1) == 20);
Thanks for the answers.  That syntax still seems a little clunky, but I
guess that's going to happen when pushing the language to do things it's not
designed to.
caterpillar wrote > ... > lt1 = clz_list([10, 20]); > assert(lt1("get")(0) == 10); > assert(lt1("get")(1) == 20); > > lt2 = lt1("append")(30); > assert(lt2("get")(0) == 10); > assert(lt2("get")(1) == 20); > assert(lt2("get")(2) == 30); > .... Thanks for the answers. That syntax still seems a little clunky, but I guess that's going to happen when pushing the language to do things it's not designed to. -- Sent from: http://forum.openscad.org/
