Mon, Sep 4, 2023 10:18 AM
If want the y,z plane, what then? [,2,3]?
if a 2d represents an apple, and 3d a pear. You can't add them to make
pears or apples. You can concat, to make them fruit.
It depends if you're buying or selling.
Mon, Sep 4, 2023 10:41 AM
They are not apples and pears. 2D is XY and 3D is XYZ so a superset, so if
they are representing geometry they can be added. If they are representing
something else then it might not make sense. It is for the programmer to
decide if it makes sense, not the language.
To move an XY translation into the YZ plane you would need to rotate around
the X axis which isn't a simple addition, you would need to swizzle.
Fri, Sep 8, 2023 5:43 PM
And if you have 2 apples and 3 pears represented by [2,3] and you add
another apple, a pear and a banana then you would have [3,4,1] assuming z
represents bananas.
And in OpenSCAD you can do:
apples = 2;
pears = 3;
mixed_fruit = apples + pears;
The language has no consent of type, it is up to the programmer to keep
track of it.
around the X axis which isn't a simple addition, you would need to swizzle.
represents bananas.
apples = 2;
pears = 3;
track of it.
Sat, Sep 9, 2023 10:52 AM
that's a different representation of apples and pears.
I think you are saying that x=number of apples, y = number of pears, z =
number of bananas
I was implying that apples= x,y and pears = x,y,z to show that a 2d
should not be added into a 3d to make 2 off 3d (or 2 off 2d)
Also, it just happens that xy is favoured over yz, or xz , since
translate([1,1]) is accepted, but translate ([,1,1]) or ([1,,1]) are not
assuming z represents bananas.
apples = 2;
pears = 3;
keep track of it.
superset, so if they are representing geometry they can be added.
If they are representing something else then it might not make
sense. It is for the programmer to decide if it makes sense, not
the language.
rotate around the X axis which isn't a simple addition, you would
need to swizzle.
to make
number of bananas
> apples = 2;
> pears = 3;
> keep track of it.
> the language.
> need to swizzle.
> to make
Sat, Sep 9, 2023 11:37 AM
XY is favoured because it is a subset and x in x,y,x is the same as x in
x.y, etc, so no reason not to add them.
number of bananas
represents bananas.
apples = 2;
pears = 3;
track of it.
if they are representing geometry they can be added. If they are
representing something else then it might not make sense. It is for the
programmer to decide if it makes sense, not the language.
> number of bananas
> represents bananas.
> apples = 2;
> pears = 3;
> track of it.
Sat, Sep 9, 2023 3:18 PM
I agree that apples and pears are different. I agree that 2D vectors
are not 3D vectors.
However, as 2D vectors can be "upgraded" with a 0 third component to
a 3D vector, I think that the operation add (2D-vector, 3D-vector) can
reasonably return a 3D vector.
The current behaviour of the 3D vector being DOWNgraded... I don't
like it. That is not the proper behaviour. However given that this
behaviour has been "in the field" for... over a decade? it has become
impossible to change existing behaviour.
number of bananas
I was implying that apples= x,y and pears = x,y,z to show that a 2d should
apples = 2;
pears = 3;
track of it.
the language.
need to swizzle.
to make
are not 3D vectors.
> number of bananas
> > apples = 2;
> > pears = 3;
> > track of it.
> > the language.
> > need to swizzle.
> > to make
> > To unsubscribe send an email todiscuss-leave@lists.openscad.org
Sat, Sep 9, 2023 4:24 PM
Depends if you regard it as a bug as I do. If we are not going to fix bugs
due to backwards compatibility then there is no hope for OpenSCAD
getting better, just more complicated.
are not 3D vectors.
number of bananas
apples = 2;
pears = 3;
track of it.
the language.
need to swizzle.
to make
> are not 3D vectors.
> Roger.
> > number of bananas
> should
> > > apples = 2;
> > > pears = 3;
> > > track of it.
> > > the language.
> > > need to swizzle.
> > > to make
> ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110
> f equals m times a. When your f is steady, and your m is going down
Sat, Sep 9, 2023 5:06 PM
The problem is that you regard it as a bug but propose a conflicting
behavior that is not obviously right. If the current behavior (which is
actually useful for certain situations) is changed it can break existing
code in a way that is hard to find and fix. Your position is not
universal: I think most people agree that the current behavior is a bug,
but I suspect that most people also believe that the correct behavior is to
behave like "every other good language" (as another poster put it) and
issue a warning when adding vectors of different length. Probably undef
should be returned like what happens if you multiply incompatible
vectors/matrices.
are not 3D vectors.
number of bananas
apples = 2;
pears = 3;
track of it.
the language.
need to swizzle.
to make
vectors/matrices.
>> are not 3D vectors.
>> Roger.
>> > number of bananas
>> should
>> not
>> assuming
>> > > apples = 2;
>> > > pears = 3;
>> keep
>> > > track of it.
>> > > the language.
>> > > need to swizzle.
>> > > to make
Sat, Sep 9, 2023 9:42 PM
So you also regard it as a bug but have written code to make use of it that
would be broken! I think you deserve to have yourcode broken.
I am forever getting my code broken by the increase in warnings. The one
that annoys me most was len() warning for use on scalars when it was
documented to return undef, which I made use of. Other changes are things
like zero dimensions used to not produce geometry, which made sense to me
but now it gives warnings. All these things make my code longer and slower.
Is that progress, I think not.
vectors/matrices.
bugs due to backwards compatibility then there is no hope for OpenSCAD
are not 3D vectors.
number of bananas
apples = 2;
pears = 3;
track of it.
the language.
need to swizzle.
to make
> vectors/matrices.
>>> are not 3D vectors.
>>> Roger.
>>> > number of bananas
>>> should
>>> not
>>> assuming
>>> > > apples = 2;
>>> > > pears = 3;
>>> keep
>>> > > track of it.
>>> > > the language.
>>> > > need to swizzle.
>>> them
>>> > > to make
>>> +31-15-2049110 **
Sat, Sep 9, 2023 10:08 PM
It's not a bug to have written code that exploits defects in the language.
It may be a bad idea. And I have not made use of this behavior
myself---basically it would never occur to me in a million years that it
would make sense to add vectors of different length---but I think code in
BOSL2 that handles 2d and 3d cases together does make use of it. That
said, I have no objection to changing it to the right behavior, which is a
warning and undef return. When you get a warning, the problem is reported,
hence its exact location is easy to identify, and the code can be fixed. A
silent change of the buggy behavior to different (but arguably still buggy)
behavior is harder to deal with.
One issue I've seen with OpenSCAD is that "is documented" means nothing
because there's actually no documentation. What we have is a wiki that
describes current behavior, not a document that specifies OpenSCAD behavior
as a standard. If behavior "being documented" precludes it from being
changed, then no bugs that manage to get into the wiki can ever get fixed.
You apparently write perfect code the first time. For those of us without
this ability, proper error handling in the language is a godsend, and saves
far more time than it costs.
that would be broken! I think you deserve to have yourcode broken.
vectors/matrices.
are not 3D vectors.
number of bananas
apples = 2;
pears = 3;
track of it.
the language.
need to swizzle.
to make
It may be a bad idea. And *I* have not made use of this behavior
>> vectors/matrices.
>>>> are not 3D vectors.
>>>> Roger.
>>>> z =
>>>> > number of bananas
>>>> should
>>>> not
>>>> add
>>>> assuming
>>>> > > apples = 2;
>>>> > > pears = 3;
>>>> keep
>>>> > > track of it.
>>>> added.
>>>> > > the language.
>>>> would
>>>> > > need to swizzle.
>>>> them
>>>> > > to make
>>>> +31-15-2049110 **
>>>> shuttle.
