dev version backtrace missing entries?
Mon, Apr 14, 2025 9:00 PM
I recently tried doing some development with a nightly build,
2025.02.25.snap,
and have been running into a significant annoyance that when there is an
error, sometimes the backtrace omits the specific line where the error
actually occurred.
For example, in the dev version I got this:
ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and
acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line
1569
TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549
TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943
TRACE: assignment to "trans_scale" in file libraries/BOSL2/skin.scad, line
1943
TRACE: called by 'path_sweep' in file ttest1.scad, line 20
But the error was not on any listed line.  To find the error I ran the
stable version which gave me this:
1569
TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line 2151
And yep, line 2151 was the problem.  So what's going on here?
I recently tried doing some development with a nightly build, 2025.02.25.snap, and have been running into a significant annoyance that when there is an error, sometimes the backtrace omits the specific line where the error actually occurred. For example, in the dev version I got this: ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line 1569 TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549 TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 TRACE: assignment to "trans_scale" in file libraries/BOSL2/skin.scad, line 1943 TRACE: called by 'path_sweep' in file ttest1.scad, line 20 But the error was not on any listed line. To find the error I ran the stable version which gave me this: ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line 1569 TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549 TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line 2151 TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 TRACE: called by 'path_sweep' in file ttest1.scad, line 20 And yep, line 2151 was the problem. So what's going on here?
Mon, Apr 14, 2025 9:48 PM
It’s possible you found a bug :)
The typical way forward would be to try to isolate the different behavior as a minimal test case, then bisect or read code to figure out when and why this changed.
This is best handled as a GitHub issue, unless someone here already knows what’s up :)
On Apr 14, 2025, at 17:00, Adrian Mariano via Discuss discuss@lists.openscad.org wrote:
I recently tried doing some development with a nightly build,2025.02.25.snap,
ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line 1569 <>
TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549 <>
TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 <>
TRACE: assignment to "trans_scale" in file libraries/BOSL2/skin.scad, line 1943 <>
TRACE: called by 'path_sweep' in file ttest1.scad, line 20 <>
TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line 2151 <>
It’s possible you found a bug :) The typical way forward would be to try to isolate the different behavior as a minimal test case, then bisect or read code to figure out when and why this changed. This is best handled as a GitHub issue, unless someone here already knows what’s up :) -Marius > On Apr 14, 2025, at 17:00, Adrian Mariano via Discuss <discuss@lists.openscad.org> wrote: > > I recently tried doing some development with a nightly build,2025.02.25.snap, > and have been running into a significant annoyance that when there is an error, sometimes the backtrace omits the specific line where the error actually occurred. > > For example, in the dev version I got this: > > ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line 1569 <> > TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549 <> > TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 <> > TRACE: assignment to "trans_scale" in file libraries/BOSL2/skin.scad, line 1943 <> > TRACE: called by 'path_sweep' in file ttest1.scad, line 20 <> > > But the error was not on any listed line. To find the error I ran the stable version which gave me this: > > ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, line 1569 <> > > TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line 1549 <> > > TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line 2151 <> > > TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 <> > > TRACE: called by 'path_sweep' in file ttest1.scad, line 20 <> > > > And yep, line 2151 was the problem. So what's going on here? > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
Mon, Apr 14, 2025 10:04 PM
It's not exactly obvious how to go about constructing a minimal test case
for behavior like this that is arising in a huge code base...so I was
hoping not to need to do that.  At the moment I don't have a test case at
all...unless I start randomly introducing errors in my code to try to
produce it again.
this changed.
what’s up :)
2025.02.25.snap,
actually occurred.
line 1569
1549
1943
line 1569
1549
It's not exactly obvious how to go about constructing a minimal test case for behavior like this that is arising in a huge code base...so I was hoping not to need to do that. At the moment I don't have a test case at all...unless I start randomly introducing errors in my code to try to produce it again. On Mon, Apr 14, 2025 at 5:48 PM Marius Kintel <marius@kintel.net> wrote: > It’s possible you found a bug :) > The typical way forward would be to try to isolate the different behavior > as a minimal test case, then bisect or read code to figure out when and why > this changed. > This is best handled as a GitHub issue, unless someone here already knows > what’s up :) > > -Marius > > On Apr 14, 2025, at 17:00, Adrian Mariano via Discuss < > discuss@lists.openscad.org> wrote: > > I recently tried doing some development with a nightly build, > 2025.02.25.snap, > and have been running into a significant annoyance that when there is an > error, sometimes the backtrace omits the specific line where the error > actually occurred. > > For example, in the dev version I got this: > > ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D > and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, > line 1569 > > TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line > 1549 > > TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 > > TRACE: assignment to "trans_scale" in file libraries/BOSL2/skin.scad, line > 1943 > > TRACE: called by 'path_sweep' in file ttest1.scad, line 20 > > But the error was not on any listed line. To find the error I ran the > stable version which gave me this: > > ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms is 3D > and acts on Z, but points are 2D" in file libraries/BOSL2/transforms.scad, > line 1569 > > TRACE: called by '_apply' in file libraries/BOSL2/transforms.scad, line > 1549 > > TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line 2151 > > TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, line 1943 > > > TRACE: called by 'path_sweep' in file ttest1.scad, line 20 > > And yep, line 2151 was the problem. So what's going on here? > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > > >
CM
Curt McDowell
Tue, Apr 15, 2025 5:56 AM
Using the "git bisect" method doesn't require constructing a minimal
example. It only requires that you can build OpenSCAD for a specific git
SHA, and you can repeatedly run the failure case with results that are
stable and pass/fail. It could be automated, but when I do it, I check
out and build OpenSCAD from scratch for each bisect iteration, and just
kind of baby the process along in the background as time permits. I'd
might be able to do it for you if given a .tar of the complete sources
and a reliable method to check for failure.
Regards,
Curt
 line where the error actually occurred. *
 line 1943
 2151
 line 1943
Using the "git bisect" method doesn't require constructing a minimal example. It only requires that you can build OpenSCAD for a specific git SHA, and you can repeatedly run the failure case with results that are stable and pass/fail. It could be automated, but when I do it, I check out and build OpenSCAD from scratch for each bisect iteration, and just kind of baby the process along in the background as time permits. I'd might be able to do it for you if given a .tar of the complete sources and a reliable method to check for failure. Regards, Curt On 4/14/2025 3:04 PM, Adrian Mariano via Discuss wrote: > It's not exactly obvious how to go about constructing a minimal test > case for behavior like this that is arising in a huge code base...so I > was hoping not to need to do that.  At the moment I don't have a test > case at all...unless I start randomly introducing errors in my code to > try to produce it again. > > On Mon, Apr 14, 2025 at 5:48 PM Marius Kintel <marius@kintel.net> wrote: > > It’s possible you found a bug :) > The typical way forward would be to try to isolate the different > behavior as a minimal test case, then bisect or read code to > figure out when and why this changed. > This is best handled as a GitHub issue, unless someone here > already knows what’s up :) > >  -Marius > >> On Apr 14, 2025, at 17:00, Adrian Mariano via Discuss >> <discuss@lists.openscad.org> wrote: >> >> I recently tried doing some development with a nightly >> build,2025.02.25.snap, >> and have been running into a significant annoyance that when >> there is an error, sometimes the backtrace omits the specific >> line where the error actually occurred. * >> * >> * >> * >> For example, in the dev version I got this: >> * >> * >> >> ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms >> is 3D and acts on Z, but points are 2D" in file >> libraries/BOSL2/transforms.scad, line 1569 >> >> TRACE: called by '_apply' in file >> libraries/BOSL2/transforms.scad, line 1549 >> >> TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, >> line 1943 >> >> TRACE: assignment to "trans_scale" in file >> libraries/BOSL2/skin.scad, line 1943 >> >> TRACE: called by 'path_sweep' in file ttest1.scad, line 20 >> >> >> But the error was not on any listed line. To find the error I ran >> the stable version which gave me this: >> >> ERROR: Assertion 'is_2d_transform(transform)' failed: "Transforms >> is 3D and acts on Z, but points are 2D" in file >> libraries/BOSL2/transforms.scad, line 1569 >> >> TRACE: called by '_apply' in file >> libraries/BOSL2/transforms.scad, line 1549 >> >> TRACE: called by 'apply' in file libraries/BOSL2/skin.scad, line >> 2151 >> >> TRACE: called by 'path_sweep' in file libraries/BOSL2/skin.scad, >> line 1943 >> >> TRACE: called by 'path_sweep' in file ttest1.scad, line 20 >> >> >> And yep, line 2151 was the problem.  So what's going on here? >> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email todiscuss-leave@lists.openscad.org
