How do you convert your STL to step so it can be manufactured?
F
fred
Tue, Dec 31, 2019 8:39 PM
One method to convert STL to step or stp or many other formats is to use Fusion 360 (free for hobbyists) and import mesh (STL).
Turn off tracking/history, then right click on the mesh and convert to BREP.
Export in the format of your choice.
On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven <kerryhall@gmail.com> wrote:
I have a bunch of complex parts I've modeled in OpenSCAD. I converted these
to STL and sent them to a metal shop to be fabricated. However, the rep from
the shop says he "Can't pull any dimensions off the STL" and thus cannot
help me. How do you get your parts manufactured at shops that only use
Solidworks?
One method to convert STL to step or stp or many other formats is to use Fusion 360 (free for hobbyists) and import mesh (STL). Turn off tracking/history, then right click on the mesh and convert to BREP. Export in the format of your choice. On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven <kerryhall@gmail.com> wrote: I have a bunch of complex parts I've modeled in OpenSCAD. I converted these to STL and sent them to a metal shop to be fabricated. However, the rep from the shop says he "Can't pull any dimensions off the STL" and thus cannot help me. How do you get your parts manufactured at shops that only use Solidworks? -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
G
Tue, Dec 31, 2019 8:50 PM
Solidworks?
S
Serge
Wed, Jan 1, 2020 4:58 AM
what? 3D Builder shows STL dimensions. Sli3er too. Always. Maybe run
from that fabricator
BREP.
these
from
Solidworks?
what? 3D Builder shows STL dimensions. Sli3er too. Always. Maybe run from that fabricator On 12/31/19, fred via Discuss <discuss@lists.openscad.org> wrote: > One method to convert STL to step or stp or many other formats is to use > Fusion 360 (free for hobbyists) and import mesh (STL). > Turn off tracking/history, then right click on the mesh and convert to > BREP. > Export in the format of your choice. > > On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven > <kerryhall@gmail.com> wrote: > > I have a bunch of complex parts I've modeled in OpenSCAD. I converted > these > to STL and sent them to a metal shop to be fabricated. However, the rep > from > the shop says he "Can't pull any dimensions off the STL" and thus cannot > help me. How do you get your parts manufactured at shops that only use > Solidworks? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
F
fred
Wed, Jan 1, 2020 10:53 AM
From the reference of a machine shop constructing a part from a drawing, STL files are not suitable, especially if the parts are to be created by a CNC machine. Even though many programs provide bounding box dimensions, I know of no program that could, for example, provide the diameter of a hemisphere mounted on a truncated cone, if the source file is an STL.
By converting a file to .step or .stp or one of a few other machine-shop-friendly formats, the shop can use the file to program the CNC for production, rather than use valuable and expensive manual labor to examine every aspect of model provided in STL format.
On Tuesday, December 31, 2019, 11:59:21 PM EST, Serge <moneyforidea@gmail.com> wrote:
BREP.
these
from
Solidworks?
From the reference of a machine shop constructing a part from a drawing, STL files are not suitable, especially if the parts are to be created by a CNC machine. Even though many programs provide bounding box dimensions, I know of no program that could, for example, provide the diameter of a hemisphere mounted on a truncated cone, if the source file is an STL. By converting a file to .step or .stp or one of a few other machine-shop-friendly formats, the shop can use the file to program the CNC for production, rather than use valuable and expensive manual labor to examine every aspect of model provided in STL format. On Tuesday, December 31, 2019, 11:59:21 PM EST, Serge <moneyforidea@gmail.com> wrote: what? 3D Builder shows STL dimensions. Sli3er too. Always. Maybe run from that fabricator On 12/31/19, fred via Discuss <discuss@lists.openscad.org> wrote: >  One method to convert STL to step or stp or many other formats is to use > Fusion 360 (free for hobbyists) and import mesh (STL). > Turn off tracking/history, then right click on the mesh and convert to > BREP. > Export in the format of your choice. > >    On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven > <kerryhall@gmail.com> wrote: > >  I have a bunch of complex parts I've modeled in OpenSCAD. I converted > these > to STL and sent them to a metal shop to be fabricated. However, the rep > from > the shop says he "Can't pull any dimensions off the STL" and thus cannot > help me. How do you get your parts manufactured at shops that only use > Solidworks? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Wed, Jan 1, 2020 11:03 AM
Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from an
STL. If they don't like the segmentation and want true curves then
converting STL to STP will not do that.
If they are doing manual fabrication then I can see STL is not good because
you can't drill polygonal holes, etc. So manual fabrication can never
exactly match an STL file.
On Wed, 1 Jan 2020 at 10:53, fred via Discuss discuss@lists.openscad.org
BREP.
these
from
Solidworks?
Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from an STL. If they don't like the segmentation and want true curves then converting STL to STP will not do that. If they are doing manual fabrication then I can see STL is not good because you can't drill polygonal holes, etc. So manual fabrication can never exactly match an STL file. On Wed, 1 Jan 2020 at 10:53, fred via Discuss <discuss@lists.openscad.org> wrote: > From the reference of a machine shop constructing a part from a drawing, > STL files are not suitable, especially if the parts are to be created by a > CNC machine. Even though many programs provide bounding box dimensions, I > know of no program that could, for example, provide the diameter of a > hemisphere mounted on a truncated cone, if the source file is an STL. > > By converting a file to .step or .stp or one of a few other > machine-shop-friendly formats, the shop can use the file to program the CNC > for production, rather than use valuable and expensive manual labor to > examine every aspect of model provided in STL format. > > On Tuesday, December 31, 2019, 11:59:21 PM EST, Serge < > moneyforidea@gmail.com> wrote: > > > what? 3D Builder shows STL dimensions. Sli3er too. Always. Maybe run > from that fabricator > > On 12/31/19, fred via Discuss <discuss@lists.openscad.org> wrote: > > One method to convert STL to step or stp or many other formats is to use > > Fusion 360 (free for hobbyists) and import mesh (STL). > > Turn off tracking/history, then right click on the mesh and convert to > > BREP. > > Export in the format of your choice. > > > > On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven > > <kerryhall@gmail.com> wrote: > > > > I have a bunch of complex parts I've modeled in OpenSCAD. I converted > > these > > to STL and sent them to a metal shop to be fabricated. However, the rep > > from > > the shop says he "Can't pull any dimensions off the STL" and thus cannot > > help me. How do you get your parts manufactured at shops that only use > > Solidworks? > > > > > > > > -- > > Sent from: http://forum.openscad.org/ > > > > _______________________________________________ > > OpenSCAD mailing list > > Discuss@lists.openscad.org > > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
F
fred
Wed, Jan 1, 2020 11:19 AM
I have a friend who worked in a machine shop and eventually (as a youth) became a shop owner. His experience in the industry lasted as many years as I've been alive. I learned quite a bit from him before he retired.
One aspect of the business is that if it's not within certain parameters, it's not a job to be taken. Qualified machinists have no problem getting work. They (he) won't necessarily take on a job that requires new investment in learning programs other than that which is currently in use at the shop.
If the OPs resource has requested .step or .stp files, that shop will not take an STL file in its stead. My answer provides a conversion process, to permit the OP to provide the required file format.
If the OP cared to cast about for a shop that can handle an STL file, I suspect he would not have posted the question.
Regarding my now-retired friend; his requirement was three-view drawings. If a computer file was provided in any format, it had to be DXF and had to be accompanied by at least a PDF or a printed set in order for the job to be accepted. This was because he created the g-code to run the CNC mill. He did not use any intermediate software, although that was attempted in the past. When one has decades of experience writing g-code, even a computer can't do it better!
On Wednesday, January 1, 2020, 6:04:57 AM EST, nop head <nop.head@gmail.com> wrote:
On Wed, 1 Jan 2020 at 10:53, fred via Discuss discuss@lists.openscad.org wrote:
BREP.
these
from
Solidworks?
I have a friend who worked in a machine shop and eventually (as a youth) became a shop owner. His experience in the industry lasted as many years as I've been alive. I learned quite a bit from him before he retired. One aspect of the business is that if it's not within certain parameters, it's not a job to be taken. Qualified machinists have no problem getting work. They (he) won't necessarily take on a job that requires new investment in learning programs other than that which is currently in use at the shop. If the OPs resource has requested .step or .stp files, that shop will not take an STL file in its stead. My answer provides a conversion process, to permit the OP to provide the required file format. If the OP cared to cast about for a shop that can handle an STL file, I suspect he would not have posted the question. Regarding my now-retired friend; his requirement was three-view drawings. If a computer file was provided in any format, it had to be DXF and had to be accompanied by at least a PDF or a printed set in order for the job to be accepted. This was because he created the g-code to run the CNC mill. He did not use any intermediate software, although that was attempted in the past. When one has decades of experience writing g-code, even a computer can't do it better! On Wednesday, January 1, 2020, 6:04:57 AM EST, nop head <nop.head@gmail.com> wrote: Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from an STL. If they don't like the segmentation and want true curves then converting STL to STP will not do that.  If they are doing manual fabrication then I can see STL is not good because you can't drill polygonal holes, etc. So manual fabrication can never exactly match an STL file. On Wed, 1 Jan 2020 at 10:53, fred via Discuss <discuss@lists.openscad.org> wrote: From the reference of a machine shop constructing a part from a drawing, STL files are not suitable, especially if the parts are to be created by a CNC machine. Even though many programs provide bounding box dimensions, I know of no program that could, for example, provide the diameter of a hemisphere mounted on a truncated cone, if the source file is an STL. By converting a file to .step or .stp or one of a few other machine-shop-friendly formats, the shop can use the file to program the CNC for production, rather than use valuable and expensive manual labor to examine every aspect of model provided in STL format. On Tuesday, December 31, 2019, 11:59:21 PM EST, Serge <moneyforidea@gmail.com> wrote: what? 3D Builder shows STL dimensions. Sli3er too. Always. Maybe run from that fabricator On 12/31/19, fred via Discuss <discuss@lists.openscad.org> wrote: >  One method to convert STL to step or stp or many other formats is to use > Fusion 360 (free for hobbyists) and import mesh (STL). > Turn off tracking/history, then right click on the mesh and convert to > BREP. > Export in the format of your choice. > >    On Tuesday, December 31, 2019, 3:33:01 PM EST, guaranteed_interwoven > <kerryhall@gmail.com> wrote: > >  I have a bunch of complex parts I've modeled in OpenSCAD. I converted > these > to STL and sent them to a metal shop to be fabricated. However, the rep > from > the shop says he "Can't pull any dimensions off the STL" and thus cannot > help me. How do you get your parts manufactured at shops that only use > Solidworks? > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
N
NateTG
Fri, Jan 17, 2020 2:33 PM
STL. ...
But you know the dimensions and tolerances that you want.  They're not in
the STL.
> Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from an STL. ... But you know the dimensions and tolerances that you want. They're not in the STL. -- Sent from: http://forum.openscad.org/
Fri, Jan 17, 2020 5:17 PM
Well as there are no tolerances in OpenSCAD how can any file format
generated by it have tolerances?
On Fri, 17 Jan 2020 at 14:33, NateTG nate-openscadforum@pedantic.org
an
STL. ...
the STL.
Well as there are no tolerances in OpenSCAD how can any file format generated by it have tolerances? On Fri, 17 Jan 2020 at 14:33, NateTG <nate-openscadforum@pedantic.org> wrote: > > Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from > an > STL. ... > > But you know the dimensions and tolerances that you want. They're not in > the STL. > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
ER
Ezra Reynolds
Fri, Jan 17, 2020 5:41 PM
Some step files can have tolerances - either global or on a per-part basis.
I guess a dividing line is the quality needed and how professional you need to be.  Military and heavy industrial uses, for example, often have very tight tolerances and if it’s out of spec it fails the quality control and you won’t be paid for the job.  Catia ($25000 /seat) can  include tolerances and step files like this, I think solid works as well.  My 30 year old CNC router is probably accurate to  0.5 millimeter or so (which is pretty sloppy) but I don’t need it to be more accurate than that for anything I’m doing.
A moot point for openscad, as it doesn’t have tolerances in the first place .
STL. ...
the STL.
Some step files can have tolerances - either global or on a per-part basis. I guess a dividing line is the quality needed and how professional you need to be. Military and heavy industrial uses, for example, often have very tight tolerances and if it’s out of spec it fails the quality control and you won’t be paid for the job. Catia ($25000 /seat) can include tolerances and step files like this, I think solid works as well. My 30 year old CNC router is probably accurate to 0.5 millimeter or so (which is pretty sloppy) but I don’t need it to be more accurate than that for anything I’m doing. A moot point for openscad, as it doesn’t have tolerances in the first place . > On Jan 17, 2020, at 12:17 PM, nop head <nop.head@gmail.com> wrote: > > Well as there are no tolerances in OpenSCAD how can any file format generated by it have tolerances? > >> On Fri, 17 Jan 2020 at 14:33, NateTG <nate-openscadforum@pedantic.org> wrote: >> > Why are they not suitable for CNC? I can use PyCAM to mill 3D parts from an >> STL. ... >> >> But you know the dimensions and tolerances that you want. They're not in >> the STL. >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
FV
Frank van der Hulst
Fri, Jan 17, 2020 6:37 PM
I use FreeCAD to convert STL to other formats (usually STEP). Check for
mesh errors and fix, convert the mesh to an object, convert the object to a
solid, export.
basis.
anything I’m doing.
place .
from an
STL. ...
the STL.
I use FreeCAD to convert STL to other formats (usually STEP). Check for mesh errors and fix, convert the mesh to an object, convert the object to a solid, export. On Sat, Jan 18, 2020 at 6:42 AM Ezra Reynolds <shadowwynd@gmail.com> wrote: > Some step files can have tolerances - either global or on a per-part > basis. > > I guess a dividing line is the quality needed and how professional you > need to be. Military and heavy industrial uses, for example, often have > very tight tolerances and if it’s out of spec it fails the quality control > and you won’t be paid for the job. Catia ($25000 /seat) can include > tolerances and step files like this, I think solid works as well. My 30 > year old CNC router is probably accurate to 0.5 millimeter or so (which is > pretty sloppy) but I don’t need it to be more accurate than that for > anything I’m doing. > > A moot point for openscad, as it doesn’t have tolerances in the first > place . > > > > On Jan 17, 2020, at 12:17 PM, nop head <nop.head@gmail.com> wrote: > > Well as there are no tolerances in OpenSCAD how can any file format > generated by it have tolerances? > > On Fri, 17 Jan 2020 at 14:33, NateTG <nate-openscadforum@pedantic.org> > wrote: > >> > Why are they not suitable for CNC? I can use PyCAM to mill 3D parts >> from an >> STL. ... >> >> But you know the dimensions and tolerances that you want. They're not in >> the STL. >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
