The optimizer is optimizing out some of the key variables I want to watch. I
found this section in openscad.pro:
and changed it to -O0, which I fantasized would turn off optimization (at
the risk of the error above.
Some of the vars I was interested in appeared, so I must have changed
something, but others, e.g. the length of the axes, l, were optimized out.
I had imagined that nothing should be optimized out with -O0, but nope.
Any idea of a simple (or preferred) way to turn optimization off? I'd
prefer something system rather than a function pragma or volatile for a var,
but I"ll take anything that works.
View this message in context: http://forum.openscad.org/Debugging-optimized-out-vars-on-Windows-tp11040.html
I should apologize to those reading via the mail list. I used raw tags to
format my code segment. The section that disappeared in the mail was:
mingw* {
debug: QMAKE_CXXFLAGS += -O1
I replaced the -O1 with -O0.
View this message in context: http://forum.openscad.org/Debugging-optimized-out-vars-on-Windows-tp11040p11041.html
Is the debug build still broken on msys?
I'm getting a successful build with both -O options. I haven't run the
entire test suite, but the app is running fine and working with the Qt
debugger. I just can't see the values for significant variables.
View this message in context: http://forum.openscad.org/Debugging-optimized-out-vars-on-Windows-tp11040p11043.html
I was referring to the actual debug build. On Unix systems, we build debug version using "qmake CONFIG+=debug”.
I know that was not working properly on Windows, but not sure about the state of that.
state of that.
Sorry, yes, this is the debug build. I set up a new build kit in Qt using:
qmake.exe C:\msys64\home\tdeagan\openscad\openscad.pro -r -spec win32-g++
"CONFIG+=debug"
Worked like a champ (I did follow the instructions for the QScintilla debug
libs.)
I did have to do a rebuild all to get past some initial linking issues. But
it worked great after that.
View this message in context: http://forum.openscad.org/Debugging-optimized-out-vars-on-Windows-tp11040p11047.html
