I am trying to get some parts produced and the manufacturer is asking for a
STEP file, is it possible to export to a STEP file?
If you load the STL file into FreeCAD, you can export it as a STEP. Better
yet, you can use a plugin so that FreeCAD can read OpenSCAD files.
Thanks, that works really good. I was able to open the scad file in FreeCAD
and export it to a STEP file. Will wait and see what the manufacturer says
about the STEP file.
I am not sure exporting an STL file is a good idea. STL files are made up of
three sided elements which are okay for 3D printing, but not for many other
manufacturing processes
FreeCAD has an OpenSCAD workbench and one of its functions is to all import
of scad files. You need to make sure that the OpenSCAD preference has
details of where the OpenSCAD executable is. If you have 2D hull or
minkowski requests you need to make sure that the option to update and load
a DXF library is enabled. It is an option of import-export on the main
FreeCAD preferences.
If you want support for the OpenSCAD offset function then you need FreeCAD
0.17
If you experience problems then please report them in the FreeCAD forum
https://forum.freecadweb.org
I opened my scad file in FreeCAD instead of exporting a STL file an opening
that in FreeCAD and generated a STEP file but the manufacturer said that the
STEP file has "65 separate shells" and "It is still not showing as one
piece".
I really have no idea about STEP files. So am I doing something wrong with
my scad file or I am doing something wrong when generating the STEP file in
FreeCAD.
Ideas?
I would try asking in the FreeCAD forum https://forum.freecadweb.org
If you're willing to share, either a STL, or the .scad code I can have a
look, it could easily be a geometry issue, not a STEP issue.
What do people use to view STEP files?
