Here is a new version that does something of what I want.
$fn=16;
cube([5,5,5], center=true);
wire(which=2); // part A
wire(which=-1); // part B
module wire(which=1)
if (which==-1)
cylinder(d=1, h=15, center=true); // part B
else
#cylinder(d=1.5, h=7, center=true); // part A
This page refers to children, but I don't see how to change the module to use children(0) or children(1)
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Object_modules
Sent: Monday, November 30, 2015 4:22 PM
Subject: Re: [OpenSCAD] combine a union child and a difference child inoneobject.
No you can't do that in one operation in OpenScad. You need to subtract the hole and add the rod. You could subtract a tube, which would leave a hole with a rod in it but it couldn't protrude out of the cube without adding it.
On 1 December 2015 at 00:08, Leef_me Leef_me@cox.net wrote:
You have all the essentially information.
The cube has a cylindrical hole cut vertically through it.
Inside this is a thinner rod.
They are not connected together in any place.
We can't work out what sort of object you are trying to make.
I want the "cylindrical hole" to be in the same module as the "thinner rod".
Wherever the "thinner rod" is placed, the "cylindrical hole" follows.
If I build a union of all the "thinner rods", their companion holes are cut from some shape that I specify.
Sent: Monday, November 30, 2015 2:32 PM
Subject: Re: [OpenSCAD] combine a union child and a difference child in oneobject.
You could add a flattened cube at the bottom and thereby make a mold kind-of
object to perhaps pour goop into to make tubes, but not sure what this
object is trying to acheive so not sure how to answer your question.
View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14846.html
How about this:
cyl_res = 16;
module wire() {
// outer block
cube(size=[5,5,5], center=true);
// subtract this
children(0);
wire() cylinder(d=1.5, h=7, center=true, $fn=cyl_res);
cylinder(d=1, h=15, center=true, $fn=cyl_res);
View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14854.html
Passing a parameter to a module to make it do two completely different
things doesn't make sense from a programming point of view. It is better to
stop pretending it is a single thing and make two modules: wire_inner() and
wire_outer(). That is a lot more descriptive than wire(which=2) and
wire(which=-1) and since they can be single line modules it is actually
less code.
module wire_inner()cylinder(d = 1, h = 15, center = true);
module wire_outer()cylinder(d = 1.5, h = 7, center = true);
$fn=16;
cube([5, 5, 5], center = true);
wire_outer(); // part A
wire_inner(); // part B
It is more readable but it still doesn't get around the fact you can't have
negative objects outside of a difference.
You could make a module that does both an add and a subtract but it makes
these code more obscure.
module add_and_subtract()
children(0);
children(1);
children(2);
$fn=16;
add_and_subtract() {
wire_outer();
wire_inner();
And you could to a truly horrible hack like this: -
module wire()
if($negative)
wire_outer();
else
wire_inner();
children(0);
$negative = true;
children(1);
$negative = false;
children(1);
$fn=16;
wire();
But I think it is just obscuration.
$fn=16;
if (which==-1)
else
inoneobject.
adding it.
rod".
oneobject.
kind-of
to
and
less code.
This is not a programming issue but a matter of organization. Those are not
two completely different things. It makes perfect sense to throw several
highly
related things (with inter-related dimensions, e.g.) into a module and pass
sensible arguments to it to retrieve various part of that thing or variant
incarnations of the same thing.
However I would not use numeric arguments. Rather use strings:
You can even write a more elaborate if () ... else ... statements using
search()
that would allow the calling routine to pass a vector of strings, so that
any
number of parts can be retrieved by a single call e.g.
View this message in context: http://forum.openscad.org/combine-a-union-child-and-a-difference-child-in-one-object-tp14834p14864.html
