Sun, May 6, 2018 7:20 PM
It seems that when my project gets past a certain size simple changes cause
everything to be rendered for scratch when I hit F5. Does the geometry
cache have a finite size? And if so would new stuff overwrite the out the
old stuff so nothing is persisted?
Sun, May 6, 2018 7:29 PM
On 05/06/2018 09:20 PM, nop head wrote:
It seems that when my project gets past a certain size > simple changes cause everything to be rendered for scratch
when I hit F5. Does the geometry cache have a finite size?
Yes, it's limited. There's a setting for cache size.
And if so would new stuff overwrite the out the old stuff
I'm not 100% sure, but I think it will skip putting stuff
into the cache instead of pushing previous data out.
Sun, May 6, 2018 7:46 PM
Thanks. I added another 0 to make it 1,048,576,000 and it seems to be quick
again.
again.
> ciao,
> Torsten.
Sun, May 6, 2018 11:30 PM
Torsten, is it reasonable to set the caches in bytes? Why not MB?
Mon, May 7, 2018 2:19 AM
Perhaps it should report hits v's misses?
Mon, May 7, 2018 7:27 AM
Nope, that looks a bit silly to me too. Why? No idea.
Mon, May 7, 2018 7:29 AM
It does in debug builds. I'm not sure it's generally useful
in that form though. It does spam the console window quite
a bit.
a bit.
TV
Tim V. Shaporev
Mon, May 7, 2018 12:35 PM
Ideally this should allow to specify units: kb, Mb, Gb - whatever.
Not sure if it is worth troubles to implement though.
> ciao,
> Torsten.
Mon, May 7, 2018 12:47 PM
Since 100MB is not big enough for me I don't think kb would be useful.
Not sure why it needs a limit as when it isn't big enough OpenSCAD becomes
unusable.
unusable.
>> ciao,
>> Torsten.
Mon, May 7, 2018 2:17 PM
unusable.
Perhaps not everyone can add a zero?
I have had render grow the OS commit memory to consume swap & bring the
system to it's knees, I think some limit is called for.
@tp cache hit/miss could be just a percent, not necessarily ultra-detail?
> unusable.
