Hello, i would like to make a fillet in a L shaped rectangular pipe
length=30;
width=4;
height=5;
thickness=0.5;
eps=0.05;
union(){
cube([width,length,height]);
translate([0,length-eps,0]) cube([length,width,height]);
translate([width-thickness,length+thickness,thickness])
cube([length-width+2eps,width-2thickness,height-2thickness]);
}//d1
}//u
translate([thickness,-eps,thickness])
cube([width-2thickness,length+2eps+width-thickness,height-2thickness]);
}//d2
How can i use this code to make a fillet inside and outside the bend.
View this message in context: http://forum.openscad.org/Making-a-fillet-inside-and-outside-the-bend-tp20266.html
I would suggest you create your profile in 2D,
and then assemble the L by extruding the 2D profile 3 times.
2 linear_extrudes for the straight parts.
1 rotate_extrude, 90 degrees for the bend. Translate profile to get the
required radius.
Then position and union the resulting 3d parts.
You may make a 2D Lshape with the rounded corner you want. linear_extrude()
it and subtract the inner tube volumes.
View this message in context: http://forum.openscad.org/Making-a-fillet-inside-and-outside-the-bend-tp20266p20268.html
